Arduino IDE coding error
So i am new to this whole Arduino stuff and i've got a problem.
I bought an Arduino from the internet and a SSD1331.
So to try it out i downloaded a pre-written code from Adafruit (where i ordered my stuff from)
but the code says it has an error: test:22: error: expected ',' or '...' before numeric constant
I did everything just like the website said.
I don't know how to add a code, so i'll just put as an attachment.
Its the code from here: GitHub - adafruit/Adafruit-SSD1331-OLED-Driver-Library-for-Arduino: For 0.96" OLEDs in the Adafruit shop
test.pde (8.55 KB)
Works for me. Which version of the Arduino IDE are you using?
pert:
Arduino 1.8.5
Works for me with 1.8.5. Try downloading the file you attached to your first post and open that downloaded file in the Arduino IDE to make sure you're using the same file I am.
pert:
So i downloaded it, opened it and i still get the same error.
Here's the whole error
Arduino: 1.8.5 (Windows 10), Board: "Adafruit ESP32 Feather, 80MHz, 921600, None"
#define mosi 11
C:\Program Files (x86)\Arduino\hardware\espressif\esp32\libraries\SPI\src/SPI.h:55:54: note: in expansion of macro 'mosi'
void begin(int8_t sck=-1, int8_t miso=-1, int8_t mosi=-1, int8_t ss=-1);
In file included from C:\Users\Francis\Desktop\test\test.pde:40:0:
C:\Program Files (x86)\Arduino\hardware\espressif\esp32\libraries\SPI\src/SPI.h:55:10: error: default argument missing for parameter 3 of 'void SPIClass::begin(int8_t, int8_t, int8_t)'
exit status 1
option enabled in File -> Preferences.
#define mosi 11
you are telling the preprocessor to replace every instance of the string mosi with the numeric constant 11
results in this:
 void begin(int8_t sck=-1, int8_t miso=-1, int8_t 11=-1, int8_t ss=-1);
thus:
BulldogLowell:
#define mosi 11
results in this:
thus:
So what does this mean for me?
Don't use #define or any other preprocessor directives unless absolutely necessary. It's a very useful tool when you need it but can also cause lots of confusion, as demonstrated in this thread. In this case there is no benefit to using #define. This is much better:
const byte sclk = 13;
const byte mosi = 11;
const byte cs = 10;
const byte rst = 9;
const byte dc = 8;
pert:
const byte cs = 10;
const byte rst = 9;
const byte dc = 8;
So this error is now gone, thanks, but i get a new one.
It is not possible to compile it for the Adafruit ESP32 Feather.
Is it possible to rewrite the code or something to use it on the ESP32 Feather?
If yes, what would you need to rewrite?
Here's the error:
C:\Users\Francis\Documents\Arduino\libraries\Adafruit-SSD1331\Adafruit_SSD1331.cpp: In member function 'void Adafruit_SSD1331::begin()':
C:\Users\Francis\Documents\Arduino\libraries\Adafruit-SSD1331\Adafruit_SSD1331.cpp:289:21: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'PortReg* {aka volatile unsigned char*}' in assignment
sclkportreg = portOutputRegister(digitalPinToPort(_sclk));
C:\Users\Francis\Documents\Arduino\libraries\Adafruit-SSD1331\Adafruit_SSD1331.cpp:293:20: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'PortReg* {aka volatile unsigned char*}' in assignment
sidportreg = portOutputRegister(digitalPinToPort(_sid));
C:\Users\Francis\Documents\Arduino\libraries\Adafruit-SSD1331\Adafruit_SSD1331.cpp:305:15: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'PortReg* {aka volatile unsigned char*}' in assignment
csportreg = portOutputRegister(digitalPinToPort(_cs));
C:\Users\Francis\Documents\Arduino\libraries\Adafruit-SSD1331\Adafruit_SSD1331.cpp:308:15: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'PortReg* {aka volatile unsigned char*}' in assignment
rsportreg = portOutputRegister(digitalPinToPort(_rs));
exit status 1
Error compiling for board Adafruit ESP32 Feather.
have you checked out the Adafruit forum? I'm sure that they have folks connecting a Feather to an OLED by now
BulldogLowell:
Yeah i checked there but i couldn't find any useful information on the Huzzah32.
Wow! It’s their product. They are usually awesome at documenting.
BulldogLowell:
Yeah, i was on their learn.adafruit website and used the tutorial they had up on there for the product.
But it didn't workout for me.
