Arduino IDE compiled program flash location
Hi All,
The subject might be a bit confusing as I really didn't know what to call it.
I have been working on getting a bootloader onto the Arduino Due so I can do wireless uploads of firmware.
The bootloader is the Atmel example they have provided but I have been converting it to Atmel Studio as it is written for IAR.
The bootloader sits on both of the flash locations (flash0 0x80000, flash1 0xC0000).
I want to continue using the Arduino IDE for the time being so I made a different board type that points to a new flash.ld file shown below.
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
SEARCH_DIR(.)
/* Memory Spaces Definitions */
MEMORY
    rom (rx)    : ORIGIN = 0x00089000, LENGTH = 0x00040000 /* Flash, 512K */
    sram0 (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00010000 /* sram0, 64K */
    sram1 (rwx) : ORIGIN = 0x20080000, LENGTH = 0x00008000 /* sram1, 32K */
    ram (rwx)   : ORIGIN = 0x20070000, LENGTH = 0x00018000 /* sram, 96K */
/* Section Definitions */
SECTIONS
    .text :
        . = ALIGN(4);
        _sfixed = .;
        KEEP(*(.vectors .vectors.*))
        *(.text .text.* .gnu.linkonce.t.*)
        *(.glue_7t) *(.glue_7)
        *(.rodata .rodata* .gnu.linkonce.r.*)
        *(.ARM.extab* .gnu.linkonce.armextab.*)
        /* Support C constructors, and C destructors in both user code
           and the C library. This also provides support for C++ code. */
        . = ALIGN(4);
        KEEP(*(.init))
        . = ALIGN(4);
        __preinit_array_start = .;
        KEEP (*(.preinit_array))
        __preinit_array_end = .;
        . = ALIGN(4);
        __init_array_start = .;
        KEEP (*(SORT(.init_array.*)))
        KEEP (*(.init_array))
        __init_array_end = .;
        . = ALIGN(0x4);
        KEEP (*crtbegin.o(.ctors))
        KEEP (*(EXCLUDE_FILE (*crtend.o) .ctors))
        KEEP (*(SORT(.ctors.*)))
        KEEP (*crtend.o(.ctors))
        . = ALIGN(4);
        KEEP(*(.fini))
        . = ALIGN(4);
        __fini_array_start = .;
        KEEP (*(.fini_array))
        KEEP (*(SORT(.fini_array.*)))
        __fini_array_end = .;
        KEEP (*crtbegin.o(.dtors))
        KEEP (*(EXCLUDE_FILE (*crtend.o) .dtors))
        KEEP (*(SORT(.dtors.*)))
        KEEP (*crtend.o(.dtors))
        . = ALIGN(4);
        _efixed = .;            /* End of text section */
    } > rom
    /* .ARM.exidx is sorted, so has to go in its own output section.  */
    PROVIDE_HIDDEN (__exidx_start = .);
    .ARM.exidx :
      *(.ARM.exidx* .gnu.linkonce.armexidx.*)
    } > rom
    PROVIDE_HIDDEN (__exidx_end = .);
    . = ALIGN(4);
    _etext = .;
    .relocate : AT (_etext)
        . = ALIGN(4);
        _srelocate = .;
        *(.ramfunc .ramfunc.*);
        *(.data .data.*);
        . = ALIGN(4);
        _erelocate = .;
    } > ram
    /* .bss section which is used for uninitialized data */
    .bss ALIGN(4) (NOLOAD) :
        . = ALIGN(4);
        _sbss = . ;
        _szero = .;
        *(.bss .bss.*)
        *(COMMON)
        . = ALIGN(4);
        _ebss = . ;
        _ezero = .;
    } > ram
    . = ALIGN(4);
    _end = . ;
    /* .stack_dummy section doesn't contains any symbols. It is only
       used for linker to calculate size of stack sections, and assign
       values to stack symbols later */
    .stack_dummy :
        *(.stack*)
    } > ram
    /* Set stack top to end of ram, and stack limit move down by
     * size of stack_dummy section */
    __StackTop = ORIGIN(ram) + LENGTH(ram);
    __StackLimit = __StackTop - SIZEOF(.stack_dummy);
    PROVIDE(_sstack = __StackLimit);
    PROVIDE(_estack = __StackTop);
I only changed "rom (rx) : ORIGIN = 0x00089000, LENGTH = 0x00040000 /* Flash, 512K */" of the code to point to 0x89000 where the program gets loaded.
The problem is that this is fine when it is placed in flash0 but not if it gets loaded into flash1 as its location 0xC9000.
The problem is I wont really know which flash bank it will be loaded into so I can't really just change that value for the second flash bank.
Is there any way to have it auto change depending which location it is in.
