Arduino IDE comport per window
Hi, How can I make it so that there is a different com port selected in every Arduino IDE window?
Open separate instances of the IDE rather than using File/New and you can assign a different COM port and/or board type to each instance
Or try IDE version 2.0 where File/New allows you to do the same thing but the implementation of the Serial monitor is terrible at the moment as it cannot be separated from the coding window
