I tried to launch the arduino
i reformatted my pc. I have to reinstall everything AND I STILL can t launch arduino
It gets to preparing boards and then it closes.
arduinodebug.txt (105 KB)
Usually an antivirus or similar issue.
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
Always provide as much detail as possible to your issue it may be important.
If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
If applicable provide a schematic even if hand drawn.
How to insert a picture into your post
If applicable provide a proper LINK to the hardware / sensors etc. you are using.
COMMON ISSUES
Check you have a COMMON GROUND where required.
Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
Try other computers where possible.
Try other USB leads where possible.
You may not have the correct driver installed. CH340/341 or CP2102
There may be a problem with the board check your wiring first.
Remove any items connected to pins 0 and 1.
COMPUTER RELATED
close any other serial programs before opening the IDE.
Ensure you turn off any additional security / antivirus just to test.
There may be a problem with the PC try RESTARTING it.
You may be selecting the wrong COM port.
Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
Clear your browsers CACHE.
Close the IDE before using any other serial programs.
Preferably install IDE's as ADMINISTRATOR or your OS equivalent
Arduino specific boards
NANO (Old Types) some require you to use the OLD BOOTLOADER option.
NANO (New Types) See the specific sections lower in the forum.
NANO (New Types) Install your board CORE's.
CREATE editor install locations.
On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
On Linux ~/ArduinoCreateAgent-1.1/config.ini
On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Bob.
I disabled windows defender real time protection.
and i still have the same problem.
I don t think i have anti virus hmm
Doesn't need to be just an antivirus but some other SECURITY software can also give similar results.
Not actually seen it happen with just the windows defender but with other third party software.
We still need to see some specifics so I would refer you to the original reply.
Bob.
