I downloaded the latest Arduino IDE release but it does not load past the splash screen. It has booted before but now fails to load.
Here is the log data:
Last login: Wed Mar 6 11:59:02 on ttys001
/Applications/Arduino\ IDE.app/Contents/MacOS/Arduino\ IDE ; exit;
(base) aryanavnish@IN-C02FP548MD6M ~ % /Applications/Arduino\ IDE.app/Contents/MacOS/Arduino\ IDE ; exit;
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-03-06 12:17:25.396 Arduino IDE[13497:91026] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T09:57:46.613Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T09:57:46.613Z"}
Starting backend process. PID: 13528
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/aryanavnish/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-06T06:47:26.047Z root INFO Backend Object.initialize: 4.8 ms [Finished 0.515 s after backend start]
2024-03-06T06:47:26.052Z root INFO Backend Object.configure: 3.7 ms [Finished 0.515 s after backend start]
2024-03-06T06:47:26.052Z root INFO Backend s.onStart: 1.7 ms [Finished 0.515 s after backend start]
2024-03-06T06:47:26.053Z root INFO Backend s.configure: 0.2 ms [Finished 0.541 s after backend start]
2024-03-06T06:47:26.053Z root INFO Backend d.onStart: 0.2 ms [Finished 0.541 s after backend start]
2024-03-06T06:47:26.054Z root INFO Backend d.configure: 0.1 ms [Finished 0.541 s after backend start]
2024-03-06T06:47:26.055Z root INFO Backend d.initialize: 25.6 ms [Finished 0.541 s after backend start]
2024-03-06T06:47:26.055Z root INFO Backend c.onStart: 0.2 ms [Finished 0.541 s after backend start]
2024-03-06T06:47:26.056Z root INFO Backend a.configure: 5.3 ms [Finished 0.547 s after backend start]
2024-03-06T06:47:26.057Z config INFO >>> Initializing CLI configuration...
2024-03-06T06:47:26.057Z root INFO Backend c.initialize: 0.7 ms [Finished 0.547 s after backend start]
2024-03-06T06:47:26.057Z root INFO Backend R.onStart: 0.8 ms [Finished 0.547 s after backend start]
2024-03-06T06:47:26.058Z config INFO Loading CLI configuration from /Users/aryanavnish/.arduinoIDE/arduino-cli.yaml...
2024-03-06T06:47:26.058Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-03-06T06:47:26.058Z root INFO Backend a.initialize: 0.5 ms [Finished 0.548 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend w.onStart: 1.1 ms [Finished 0.549 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend r.configure: 1.9 ms [Finished 0.549 s after backend start]
2024-03-06T06:47:26.058Z discovery-log INFO start
2024-03-06T06:47:26.058Z discovery-log INFO start new deferred
2024-03-06T06:47:26.058Z root INFO Backend d.initialize: 0.4 ms [Finished 0.550 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend y.onStart: 1.6 ms [Finished 0.551 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend r.configure: 1.3 ms [Finished 0.551 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend a.onStart: 0.4 ms [Finished 0.552 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend h.configure: 0.3 ms [Finished 0.552 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend s.configure: 0.1 ms [Finished 0.552 s after backend start]
2024-03-06T06:47:26.058Z root INFO Backend l.configure: 0.1 ms [Finished 0.552 s after backend start]
2024-03-06T06:47:26.059Z root WARN The local plugin referenced by local-dir:/Users/aryanavnish/.arduinoIDE/plugins does not exist.
2024-03-06T06:47:26.059Z root WARN The local plugin referenced by local-dir:/Users/aryanavnish/.arduinoIDE/extensions does not exist.
2024-03-06T06:47:26.069Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/aryanavnish/Library/Arduino15","downloads":"/Users/aryanavnish/Library/Arduino15/staging","user":"/Users/aryanavnish/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-06T06:47:26.069Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-06T06:47:26.069Z config INFO Loaded the CLI configuration.
2024-03-06T06:47:26.075Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/aryanavnish/Library/Arduino15","sketchDirUri":"file:///Users/aryanavnish/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-06T06:47:26.075Z config INFO Validating the CLI configuration...
2024-03-06T06:47:26.076Z config INFO The CLI config is valid.
2024-03-06T06:47:26.076Z config INFO <<< Initialized the CLI configuration.
2024-03-06T06:47:26.101Z root INFO Resolve plugins list: 43.2 ms [Finished 0.594 s after backend start]
2024-03-06T06:47:26.261Z daemon INFO time="2024-03-06T12:17:26+05:30" level=info msg="Using config file: /Users/aryanavnish/.arduinoIDE/arduino-cli.yaml"
time="2024-03-06T12:17:26+05:30" level=info msg="arduino-cli version 0.35.3"
time="2024-03-06T12:17:26+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50425
{"IP":"127.0.0.1","Port":"50425"}
2024-03-06T06:47:26.261Z daemon INFO Daemon is running.
2024-03-06T06:47:27.080Z root INFO Deploy plugins list: 43.2 ms [Finished 1.574 s after backend start]
2024-03-06T06:47:27.858Z root INFO Theia app listening on http://[::1]:50427.
2024-03-06T06:47:27.858Z root INFO Finished starting backend application: 1800.3 ms [Finished 2.352 s after backend start]
2024-03-06T06:47:27.860Z root ERROR Uncaught Exception: Error: 14 UNAVAILABLE: No connection established
2024-03-06T06:47:27.860Z root ERROR Error: 14 UNAVAILABLE: No connection established
at t.callErrorFromStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:763316)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:788632)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:784512)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:783957)
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:870079
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeUnaryRequest (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:788173)
at s.create (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:854976)
at instance (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:621843)
at new Promise (<anonymous>)
at E.createClient (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:621820)
at E.create (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:620679)
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:619557
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1062668
at i.invoke (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1062758)
at s.fire (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1064561)
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-06T06:47:33.799Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 211.7 ms [Finished 5.731 s after frontend start]
2024-03-06T06:47:33.870Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-06T06:47:33.914Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 104.0 ms [Finished 5.860 s after frontend start]
I am connected to the internet. I tried after disconnecting from the net as well, still does not work.
This is a company device hence I have Sophos installed but that did not interfere earlier as it did boot up beforeUse code tags to format code for the forum
