Arduino IDE Does Not Run on Windows 10 on My Machine
1- I performed the Arduino IDE installation
2 - After installation
3 - I try to execute
4 - Appearance screen appears after hiding
5 - And the IDE does not run
Installation as Administrator
I accept the terms
All selected drivers
Arduino IDE default installation folder
Installation process in progress
IDE on Windows 10 Start Menu
When running the Arduino IDE.
Only the presentation screen appears.
And stop there.
In the installation folder I run CMD prompt
java.io.IOException: O provedor do arquivo de nuvem não está em execução
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:255)
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
at java.io.InputStreamReader.read(InputStreamReader.java:184)
at java.io.BufferedReader.fill(BufferedReader.java:161)
at java.io.BufferedReader.readLine(BufferedReader.java:324)
at java.io.BufferedReader.readLine(BufferedReader.java:389)
at processing.app.legacy.PApplet.loadStrings(PApplet.java:270)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:100)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:74)
at processing.app.packages.UserLibrary.create(UserLibrary.java:77)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:224)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at cc.arduino.contributions.libraries.LibrariesIndexer.setLibrariesFolders(LibrariesIndexer.java:120)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:677)
at processing.app.Base.onBoardOrPortChange(Base.java:1333)
at processing.app.Base$11.actionPerformed(Base.java:1537)
at processing.app.Base.rebuildBoardsMenu(Base.java:1509)
at processing.app.Base.(Base.java:277)
at processing.app.Base.main(Base.java:150)
Is any text printed to the CMD window after the IDE fails to open when you run arduino_debug.exe? If so, copy and paste it into a reply here; as text, not as a screen shot.
Friend, I don't know what I meant. But I made a video showing the problem at the moment
1- I run arduino_debug.exe through CMD 2 - I run arduino.exe with two clicks.
Check the video, any questions, I can redo the video.
https://youtu.be/cq25mrf4Prw
I disabled Defender Anti Virus I disabled One Drive
Does Arduino IDE have problems with NVidia GTX 1060?
Not sure what the problem is, honestly :(
I run a couple of Nvidia cards here with zero issues but I do NOT use the microsoft drivers are they are pretty crappy and can cause some issues.
With hardware always stick to the manufacturers drivers and not ones Microsoft may have messed around with.
BTW I lost interest in the video about 10 seconds in as it wanders all over the place and the focus is horrible.
Lots of users will not go to youtube or similar so you really need to get the hang of posting useful information.
Could you take a few moments to Learn How To Use The Forum.
Posting tips.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Guessing is not the best way to describe an issue. Actual facts are the most important.
  • Remember that the people trying to help cannot see your problem so give as much information as you can
cyberlacs: Check the video, any questions, I can redo the video.
I guess you missed the part where I asked you to post the arduino_debug.exe output as TEXT.
