I am trying out some IR code examples in the IDE.
I am running into errors compiling the unchanged code. Recently I have updated libraries, and I assume that the examples are also updated when the library changes. Perhaps not.
The two libraries I am receiving errors are
- "IRLib2" file RawSend.
I am receiving an error on line "mySender.send(RawData,RAW_DATA_LEN, 36;
Error is "RawData not declared in this scope"
2)
Also in IRremote library, Error on line - IRSender.sendNEC(.........
Error is IRSender not declared in this scope
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
rawSend example in Arduino IDE Error file
C:\Users\POP\Desktop\Arduino\arduino-1.8.13\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\POP\Desktop\Arduino\arduino-1.8.13\hardware -hardware C:\Users\POP\AppData\Local\Arduino15\packages -tools C:\Users\POP\Desktop\Arduino\arduino-1.8.13\tools-builder -tools C:\Users\POP\Desktop\Arduino\arduino-1.8.13\hardware\tools\avr -tools C:\Users\POP\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\POP\Desktop\Arduino\arduino-1.8.13\libraries -libraries C:\Users\POP\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\POP\AppData\Local\Temp\arduino_build_164231 -warnings=none -build-cache C:\Users\POP\AppData\Local\Temp\arduino_cache_696953 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\POP\Documents\Arduino\libraries\IRLib2\examples\rawSend\rawSend.ino
C:\Users\POP\Desktop\Arduino\arduino-1.8.13\arduino-builder -compile -logger=machine -hardware C:\Users\POP\Desktop\Arduino\arduino-1.8.13\hardware -hardware C:\Users\POP\AppData\Local\Arduino15\packages -tools C:\Users\POP\Desktop\Arduino\arduino-1.8.13\tools-builder -tools C:\Users\POP\Desktop\Arduino\arduino-1.8.13\hardware\tools\avr -tools C:\Users\POP\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\POP\Desktop\Arduino\arduino-1.8.13\libraries -libraries C:\Users\POP\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\POP\AppData\Local\Temp\arduino_build_164231 -warnings=none -build-cache C:\Users\POP\AppData\Local\Temp\arduino_cache_696953 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\POP\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\POP\Documents\Arduino\libraries\IRLib2\examples\rawSend\rawSend.ino
Using board 'uno' from platform in folder: C:\Users\POP\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2
Using core 'arduino' from platform in folder: C:\Users\POP\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2
Detecting libraries used...
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\sketch\\rawSend.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for IRLibSendBase.h: [IRLibProtocols@2.0.19]
ResolveLibrary(IRLibSendBase.h)
-> candidates: [IRLibProtocols@2.0.19]
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\sketch\\rawSend.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols\\IRLibHardware.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols\\IRLibProtocols.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols\\IRLibSAMD21.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols\\IRLibSAMD51.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols\\IRLibSendBase.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\sketch\\rawSend.ino.cpp" -o "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\POP\\Desktop\\Arduino\\arduino-1.8.13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\POP\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "-IC:\\Users\\POP\\Documents\\Arduino\\libraries\\IRLibProtocols" "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\sketch\\rawSend.ino.cpp" -o "C:\\Users\\POP\\AppData\\Local\\Temp\\arduino_build_164231\\sketch\\rawSend.ino.cpp.o"
C:\Users\POP\Documents\Arduino\libraries\IRLib2\examples\rawSend\rawSend.ino: In function 'void loop()':
rawSend:36:19: error: 'rawData' was not declared in this scope
mySender.send(rawData,RAW_DATA_LEN,36);//Pass the buffer,length, optionally frequency
rawSend:36:27: error: 'RAW_DATA_LEN' was not declared in this scope
C:\Users\POP\Documents\Arduino\libraries\IRLib2\examples\rawSend\rawSend.ino:36:27: note: suggested alternative: 'RAD_TO_DEG'
RAD_TO_DEG
Using library IRLibProtocols at version 2.0.19 in folder: C:\Users\POP\Documents\Arduino\libraries\IRLibProtocols
exit status 1
