hallo zusammen, habe hier ein kleines Problem mit meinem tennsy board Arduino: 1.8.19 (Windows 10), TD: 1.57, Board: "Teensy 4.1, Serial, 600 MHz, Faster, US English"
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:41:0,
from C:\Users\Surface\AppData\Local\Temp\arduino_build_597164\pch\Arduino.h:6:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/avr/pgmspace.h:30:52: error: section attribute not allowed for 'fmt'
#define PROGMEM attribute((section(".progmem")))
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:171:42: note: in expansion of macro 'PROGMEM'
static void prepare (const char* fmt PROGMEM, ...);
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:240:34: note: in expansion of macro 'PROGMEM'
void emit_p (const char* fmt PROGMEM, ...);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/avr/pgmspace.h:30:52: error: section attribute not allowed for 'p'
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:252:36: note: in expansion of macro 'PROGMEM'
void emit_raw_p (const char* p PROGMEM, uint16_t n) { memcpy_P(ptr, p, n); ptr += n; }
Autosteer_UDP_v5_6: In function 'void setup()':
Autosteer_UDP_v5_6:205: warning: suggest parentheses around arithmetic in operand of '|'
TCCR2B = TCCR2B & B11111000 | B00000110; // set timer 2 to 256 for PWM frequency of 122.55 Hz
Autosteer_UDP_v5_6:206: warning: suggest parentheses around arithmetic in operand of '|'
TCCR1B = TCCR1B & B11111000 | B00000100; // set timer 1 to 256 for PWM frequency of 122.55 Hz
Autosteer_UDP_v5_6:211: warning: suggest parentheses around arithmetic in operand of '|'
TCCR1B = TCCR1B & B11111000 | B00000010; // set timer 1 to 8 for PWM frequency of 3921.16 Hz
Autosteer_UDP_v5_6:212: warning: suggest parentheses around arithmetic in operand of '|'
TCCR2B = TCCR2B & B11111000 | B00000010; // set timer 2 to 8 for PWM frequency of 3921.16 Hx
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\Autosteer_UDP_v5_6.ino:328:54: warning: invalid conversion from 'void ()(uint16_t, uint8_t, uint16_t, uint8_t*, uint16_t) {aka void ()(short unsigned int, unsigned char, short unsigned int, unsigned char*, short unsigned int)}' to 'UdpServerCallback {aka void ()(short unsigned int, unsigned char, short unsigned int, const char*, short unsigned int)}' [-fpermissive]
ether.udpServerListenOnPort(&udpSteerRecv, 8888);
In file included from C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\Autosteer_UDP_v5_6.ino:68:0:
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:489:17: note: initializing argument 1 of 'static void EtherCard::udpServerListenOnPort(UdpServerCallback, uint16_t)'
static void udpServerListenOnPort(UdpServerCallback callback, uint16_t port);
Autosteer_UDP_v5_6: In function 'void udpSteerRecv(uint16_t, uint8_t*, uint16_t, uint8_t*, uint16_t)':
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\Autosteer_UDP_v5_6.ino:682:93: warning: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'const char*' [-fpermissive]
ether.sendUdp(PGN_253, sizeof(PGN_253), portMy, ipDestination, portDestination);
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:445:17: note: initializing argument 1 of 'static void EtherCard::sendUdp(const char*, uint8_t, uint16_t, const uint8_t*, uint16_t)'
static void sendUdp (const char *data, uint8_t len, uint16_t sport,
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\Autosteer_UDP_v5_6.ino:701:101: warning: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'const char*' [-fpermissive]
ether.sendUdp(PGN_250, sizeof(PGN_250), portMy, ipDestination, portDestination);
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\Autosteer_UDP_v5_6.ino:785:115: warning: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'const char*' [-fpermissive]
ether.sendUdp(helloFromAutoSteer, sizeof(helloFromAutoSteer), portMy, ipDestination, portDestination);
from C:\Users\Surface\AppData\Local\Temp\arduino_build_597164/pch/Arduino.h:6,
from C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.h:30,
from C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:12:
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:158:38: note: in expansion of macro 'PROGMEM'
void Stash::prepare (const char* fmt PROGMEM, ...) {
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp: In static member function 'static void Stash::extract(uint16_t, uint16_t, void*)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/avr/pgmspace.h:30:52: error: section attribute cannot be specified for local variables
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:229:21: note: in expansion of macro 'PROGMEM'
const char* fmt PROGMEM = (const char*)((segs[2] << 16) | segs[1]);
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp: In static member function 'static void Stash::cleanup()':
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:297:21: note: in expansion of macro 'PROGMEM'
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp: At global scope:
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:319:43: note: in expansion of macro 'PROGMEM'
void BufferFiller::emit_p(const char* fmt PROGMEM, ...) {
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp: In member function 'void BufferFiller::emit_p(const char*, ...)':
C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\EtherCard_AOG.cpp:368:27: note: in expansion of macro 'PROGMEM'
const char* s PROGMEM = va_arg(ap, const char*);
from C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\dhcp.cpp:17:
from C:\Users\Surface\Desktop\SupportFiles\ArduinoModules\UDP\Autosteer_UDP_v5_6\dns.cpp:7:
Fehler beim Kompilieren für das Board Teensy 4.1.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
Bin recht neu noch in dem Ganzen wäre nett wenn mir jemand helfen könnte
