Arduino IDE loosing the arduino board
I have 3 spare Arduino Uno boards and I've downoaded the latest arduino ide 1.8.13.
When i connect any of the 3 boards to my pc and select the port from the IDE there is no problem, and i can upload and run a sketch. But after about 30 seconds or so the IDE has lost the connection to the board.If I unplug the board and wait for a few minutes, the connection is ok again!
This didn't happen with a previous older version of the IDE I had.
It is the same thing with all 3 boards .
What could be the problem?
Thanks
Do you have anything connected to the Unos (e.g., wiring, modules, shields)? If so, does the problem still occur with the Uno alone connected to the computer?
The Uno has a PTC fuse. When too much current is drawn through the fuse, it heats up and cuts the power. Then once it cools off it resets and closes the circuit again. This sounds like the symptoms you describe.
Could also try backing up to 1.8.12.
Thanks for the replies.
1 of the Arduino Unos did get quite warm to touch.
Now for some strange reason, because the IDE locked up, I had to reboot my pc, and now the connection to another Uno is stable.
Just say the problem is to do with the current, how do I overcome or get around that.
Presently I have a 5 mtr led strip with 150 leds connected. , and from my understanding that would need 3A to run all 150 leds.
Running just 50 leds seems cure then problem
I'm only trying a couple of things as an experiment to see what is what, so maybe that is the reason then.
Thanks
How do you power the LEDs? Time for a schematic and details.
i was trying the FastLED/examples/ Fire2012withPalette sketch, and I connected the led strip direct to the Arduino Uno.
+5v to 5v, GND to GND and data to pin 7 via a 560k resistor.
I know that the Uno wouldn't normally power 150 leds, and I would use a 6amp power supply for them. As I said it was done as an experiment because the led strip in question had a break or fault somewhere, and I wanted to see if I could find it by this method.
#include <FastLED.h>
#define LED_PIN     7
#define COLOR_ORDER GRB
#define CHIPSET     WS2811
#define NUM_LEDS    150
#define BRIGHTNESS  200
#define FRAMES_PER_SECOND 60
bool gReverseDirection = false;
CRGB leds[NUM_LEDS];
// Fire2012 with programmable Color Palette
// This code is the same fire simulation as the original "Fire2012",
// but each heat cell's temperature is translated to color through a FastLED
// programmable color palette, instead of through the "HeatColor(...)" function.
// Four different static color palettes are provided here, plus one dynamic one.
// The three static ones are:
//   1. the FastLED built-in HeatColors_p -- this is the default, and it looks
//      pretty much exactly like the original Fire2012.
//  To use any of the other palettes below, just "uncomment" the corresponding code.
//   2. a gradient from black to red to yellow to white, which is
//      visually similar to the HeatColors_p, and helps to illustrate
//      what the 'heat colors' palette is actually doing,
//   3. a similar gradient, but in blue colors rather than red ones,
//      i.e. from black to blue to aqua to white, which results in
//      an "icy blue" fire effect,
//   4. a simplified three-step gradient, from black to red to white, just to show
//      that these gradients need not have four components; two or
//      three are possible, too, even if they don't look quite as nice for fire.
// The dynamic palette shows how you can change the basic 'hue' of the
// color palette every time through the loop, producing "rainbow fire".
CRGBPalette16 gPal;
  delay(3000); // sanity delay
  FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness( BRIGHTNESS );
  // This first palette is the basic 'black body radiation' colors,
  // which run from black to red to bright yellow to white.
  gPal = HeatColors_p;
  // These are other ways to set up the color palette for the 'fire'.
  // First, a gradient from black to red to yellow to white -- similar to HeatColors_p
  //   gPal = CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::Yellow, CRGB::White);
  // Second, this palette is like the heat colors, but blue/aqua instead of red/yellow
  //   gPal = CRGBPalette16( CRGB::Black, CRGB::Blue, CRGB::Aqua,  CRGB::White);
  // Third, here's a simpler, three-step gradient, from black to red to white
  //   gPal = CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::White);
  // Add entropy to random number generator; we use a lot of it.
  random16_add_entropy( random());
  // Fourth, the most sophisticated: this one sets up a new palette every
  // time through the loop, based on a hue that changes every time.
  // The palette is a gradient from black, to a dark color based on the hue,
  // to a light color based on the hue, to white.
  //   static uint8_t hue = 0;
  //   hue++;
  //   CRGB darkcolor  = CHSV(hue,255,192); // pure hue, three-quarters brightness
  //   CRGB lightcolor = CHSV(hue,128,255); // half 'whitened', full brightness
  //   gPal = CRGBPalette16( CRGB::Black, darkcolor, lightcolor, CRGB::White);
  Fire2012WithPalette(); // run simulation frame, using palette colors
  FastLED.show(); // display this frame
  FastLED.delay(1000 / FRAMES_PER_SECOND);
// Fire2012 by Mark Kriegsman, July 2012
// as part of "Five Elements" shown here: http://youtu.be/knWiGsmgycY
// This basic one-dimensional 'fire' simulation works roughly as follows:
// There's a underlying array of 'heat' cells, that model the temperature
// at each point along the line.  Every cycle through the simulation,
// four steps are performed:
//  1) All cells cool down a little bit, losing heat to the air
//  2) The heat from each cell drifts 'up' and diffuses a little
//  3) Sometimes randomly new 'sparks' of heat are added at the bottom
//  4) The heat from each cell is rendered as a color into the leds array
//     The heat-to-color mapping uses a black-body radiation approximation.
// Temperature is in arbitrary units from 0 (cold black) to 255 (white hot).
// This simulation scales it self a bit depending on NUM_LEDS; it should look
// "OK" on anywhere from 20 to 100 LEDs without too much tweaking.
// I recommend running this simulation at anywhere from 30-100 frames per second,
// meaning an interframe delay of about 10-35 milliseconds.
// Looks best on a high-density LED setup (60+ pixels/meter).
// There are two main parameters you can play with to control the look and
// feel of your fire: COOLING (used in step 1 above), and SPARKING (used
// in step 3 above).
// COOLING: How much does the air cool as it rises?
// Less cooling = taller flames.  More cooling = shorter flames.
// Default 55, suggested range 20-100
#define COOLING  55
// SPARKING: What chance (out of 255) is there that a new spark will be lit?
// Higher chance = more roaring fire.  Lower chance = more flickery fire.
// Default 120, suggested range 50-200.
#define SPARKING 120
void Fire2012WithPalette()
// Array of temperature readings at each simulation cell
  static byte heat[NUM_LEDS];
  // Step 1.  Cool down every cell a little
    for( int i = 0; i < NUM_LEDS; i++) {
      heat[i] = qsub8( heat[i],  random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
    // Step 2.  Heat from each cell drifts 'up' and diffuses a little
    for( int k= NUM_LEDS - 1; k >= 2; k--) {
      heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
    // Step 3.  Randomly ignite new 'sparks' of heat near the bottom
    if( random8() < SPARKING ) {
      int y = random8(7);
      heat[y] = qadd8( heat[y], random8(160,255) );
    // Step 4.  Map from heat cells to LED colors
    for( int j = 0; j < NUM_LEDS; j++) {
      // Scale the heat value from 0-255 down to 0-240
      // for best results with color palettes.
      byte colorindex = scale8( heat[j], 240);
      CRGB color = ColorFromPalette( gPal, colorindex);
      int pixelnumber;
      if( gReverseDirection ) {
        pixelnumber = (NUM_LEDS-1) - j;
        pixelnumber = j;
      leds[pixelnumber] = color;
If you power the Uno from USB, it can do approx. 500mA. The 5V in that case comes from the PC and not the Uno.
If you powered the Uno with e.g. 12V, the onboard voltage regulator will bring the voltage down to 5V. But that voltage regulator can't deliver a lot of current as it has to dissipate the heat ( (12-5) * current); maybe 150 mA and after that it will start overheating and shutting down. It should recover at the moment that you take the load away though,
I'm not familiar with WS2811. For WS2812 addressable leds, your current consumption would basically be 150 * 3 * 20 = 9A (for full white).
