Arduino IDE no longer works
I'm on a Mac OS X 10.5.8 machine.
I used to use Arduino happily -- though not very often. This weekend I wanted to try it again, and discovered that it no longer works. That was Arduino 0017, so I downloaded and installed Arduino 0018, but it still doesn't work. At launch, it bounces once, appears in the dock, and then does nothing more; no windows or menus appear.
I looked in the console, and found these errors:
3/6/10 10:22:50 PM JavaApplicationStub[7448] Apple AWT Startup Exception : *** -[NSCFArray insertObject:atIndex:]: attempt to insert nil 3/6/10 10:22:50 PM JavaApplicationStub[7448] Apple AWT Restarting Native Event Thread
...and that's it. There is the standard application menu, which (as always) contains a Quit command, but Arduino ignores it; I have to force-quit it.
Possibly relevant: "java -version" on my machine returns 1.6.0_17; this isn't standard for OS X machines. I had to enable that for some other app that wouldn't run right under 1.5. (Ye gods, this is what I hate about Java apps!)
Short of disabling Java 1.6 (breaking the other app I need to run), does anyone have an idea how to get Arduino to work on my machine?
You could try disabling Java 1.6 to see if Arduino will run - it's not a solution but may give more information about the problem. You can edit the Info.plist file inside the Arduino.app to specify a Java version; that might help.
I saw the post from Joe. I am using Windows XP pro and experience what looks to be the same issue. I click on the Icon and it flashes the Arduino IDE screen then goes away never to return.
I un-installed Java 6 with no impact. Then downloaded Arduino-0017 and it seems to be running. Also ran JAVA’s SDK Test and it apears to be okay.
Because I have just started to use the IDE and am a newbe let me know what I can do to help provide info…
  • Phil
You could try replacing the java/ folder that comes with Arduino 0018 with the one from Arduino 0017.
Ah! The sweet smell of success. I know it's success because I really did take a bath!
Actually I hadn't noticed but the first install hadn't completely installed all the files. I re-downloaded the ZIP file and re-did the unzip and it appears to be working.
Sorry to tweak your memory... Thanx for the help and reply!
  • Phil :)
