Arduino IDE not showing output after upload
I'm trying to get the information provided by a ADXL335 accelerometer using the Arduino UNO board, the code is fine because it works on my friend's laptop but when i try to run it in mine it shows the following output, when instead, i should be getting the actual X, Y and Z values of the acceleration:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Ronny\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Ronny\AppData\Local\Temp\arduino\sketches\383AE9947EDE59B4BFE4AEBFCF609773/tarea2-calibracion.ino.hex"
avrdude: writing flash (4272 bytes):
Writing | ################################################## | 100% 0.70s
avrdude: 4272 bytes of flash written
avrdude done.  Thank you.
It sounds like you're trying to upload the code and not connect to it over the serial monitor. But maybe I'm missing something. Also, a code upload could work on one system and not another due to different libraries, versions, OS support, etc.
To recap, are you trying to open the serial monitor to view the values via USB serial connection?
that was it!! Thanks a looot, i'm very new to arduino so the IDE itself and the way it works is still kinf of confusing to me, the serial monitor option displays the info :slight_smile:
