I am making a code for a robot obstacle avoiding car but I have a problem with the code or specifically Arduino IDE, when I upload the code to Arduino Uno, this error appears
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 3170 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 74 bytes (3%) of dynamic memory, leaving 1974 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xac
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xac
option enabled in File -> Preferences.
And I couldn’t find any solution
My Arduino code
//LEFT MOTOR IS RIGHT MOTOR AND RIGHT MOTOR IS LEFT MOTOR
#include <Servo.h> //Servo motor library. This is standard library
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 6;
const int LeftMotorBackward = 5;
const int RightMotorForward = 3;
const int RightMotorBackward = 4;
const int EnA = 7;
const int EnB = 2;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 200
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
servo_motor.attach(8); //our servo pin
servo_motor.write(90);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
analogWrite(EnA, 255);
analogWrite(EnB, 255);
void loop(){
int distanceRight = 0;
int distanceLeft = 0;
delay(50);
if (distance <= 20){
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
distanceRight = lookRight();
delay(300);
distanceLeft = lookLeft();
delay(300);
if (distance >= distanceLeft){
turnRight();
moveStop();
else{
turnLeft();
moveStop();
else{
moveForward();
int lookRight(){
servo_motor.write(50);
int distance = readPing();
delay(100);
return distance;
int lookLeft(){
servo_motor.write(140);
delay(100);
return distance;
delay(100);
int readPing(){
delay(70);
int cm = sonar.ping_cm();
if (cm==0){
cm=250;
return cm;
void moveStop(){
digitalWrite(RightMotorForward, LOW);
digitalWrite(LeftMotorForward, LOW);
digitalWrite(RightMotorBackward, LOW);
digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
digitalWrite(LeftMotorBackward, HIGH);
digitalWrite(RightMotorBackward, HIGH);
void moveBackward(){
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(RightMotorForward, HIGH);
void turnRight(){
delay(400);
void turnLeft(){
delay(400);
