Arduino IDE responding slowly
Hi, I thought it might be a version issue. But I just installed 018, and it has exactly the same issues as I had with 017. It loads very slowly (almost the time it would take something like NetBeans to load) and it's very slow when I try to open Tools item on the main menu - the IDE gets stuck for a few seconds.
I've removed the content of "arduino-0018\java" folder like I did with 017. My Java version is 1.6.0_17 and I'm on Win7
Thanx
Any other programs on the PC having similar issues?
Nope. None that i've noticed anywayz.
Under Device Manager, what Ports are listed?
With the Arduino connected:
Standard Serial over Bluetooth link (COM5) Standard Serial over Bluetooth link (COM6) Standard Serial over Bluetooth link (COM7) USB Serial Port (COM4)
Without the Arduino:
There are known issues with blue tooth software and the Arduino IDE. Can you disable whatever bluetooth software you are using, and try the IDE without that application running?
