Very new to arduino so please be kind. Im using two Adafruit feathers, an RP2040 and a VS1053. Trying to upload a modification of the VS1053 example script 'Feather_Player' which uses a voltage from the analog pin to trigger playing the music
// Specifically for use with the Adafruit Feather, the pins are pre-set here!
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <SD.h>
#include <Adafruit_VS1053.h>
// These are the pins used
#define VS1053_RESET -1 // VS1053 reset pin (not used!)
int Vsig = A1; // set A1 as the pin to read signal from alarm clock
int SigValue = 0; // variable to store value from sensor
// Feather ESP8266
#if defined(ESP8266)
#define VS1053_CS 16 // VS1053 chip select pin (output)
#define VS1053_DCS 15 // VS1053 Data/command select pin (output)
#define CARDCS 2 // Card chip select pin
#define VS1053_DREQ 0 // VS1053 Data request, ideally an Interrupt pin
// Feather ESP32
#elif defined(ESP32) && !defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
#define VS1053_CS 32 // VS1053 chip select pin (output)
#define VS1053_DCS 33 // VS1053 Data/command select pin (output)
#define CARDCS 14 // Card chip select pin
#define VS1053_DREQ 15 // VS1053 Data request, ideally an Interrupt pin
// Feather Teensy3
#elif defined(TEENSYDUINO)
#define VS1053_CS 3 // VS1053 chip select pin (output)
#define VS1053_DCS 10 // VS1053 Data/command select pin (output)
#define CARDCS 8 // Card chip select pin
#define VS1053_DREQ 4 // VS1053 Data request, ideally an Interrupt pin
// WICED feather
#elif defined(ARDUINO_STM32_FEATHER)
#define VS1053_CS PC7 // VS1053 chip select pin (output)
#define VS1053_DCS PB4 // VS1053 Data/command select pin (output)
#define CARDCS PC5 // Card chip select pin
#define VS1053_DREQ PA15 // VS1053 Data request, ideally an Interrupt pin
#elif defined(ARDUINO_NRF52832_FEATHER )
#define VS1053_CS 30 // VS1053 chip select pin (output)
#define VS1053_DCS 11 // VS1053 Data/command select pin (output)
#define CARDCS 27 // Card chip select pin
#define VS1053_DREQ 31 // VS1053 Data request, ideally an Interrupt pin
// Feather RP2040
#elif defined(ARDUINO_ADAFRUIT_FEATHER_RP2040)
#define VS1053_CS 8 // VS1053 chip select pin (output)
#define CARDCS 7 // Card chip select pin
#define VS1053_DREQ 9 // VS1053 Data request, ideally an Interrupt pin
// Feather M4, M0, 328, ESP32S2, nRF52840 or 32u4
#else
#define VS1053_CS 6 // VS1053 chip select pin (output)
#define CARDCS 5 // Card chip select pin
// DREQ should be an Int pin *if possible* (not possible on 32u4)
#endif
Adafruit_VS1053_FilePlayer musicPlayer =
Adafruit_VS1053_FilePlayer(VS1053_RESET, VS1053_CS, VS1053_DCS, VS1053_DREQ, CARDCS);
// if you're using Bluefruit or LoRa/RFM Feather, disable the radio module
//pinMode(8, INPUT_PULLUP);
// Wait for serial port to be opened, remove this line for 'standalone' operation
//while (!Serial) { delay(1); }
Serial.println("\n\nAdafruit VS1053 Feather Test");
// if (! musicPlayer.begin()) { // initialise the music player
// Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
// while (1);
Serial.println(F("VS1053 found"));
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
Serial.println("SD OK!");
// list files
printDirectory(SD.open("/"), 0);
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(4,4);
#if defined(__AVR_ATmega32U4__)
// Timer interrupts are not suggested, better to use DREQ interrupt!
// but we don't have them on the 32u4 feather...
musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
#else
// If DREQ is on an interrupt pin we can do background
// audio playing
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
#endif
Serial.print(".");
// File is playing in the background
SigValue = analogRead(Vsig); // Assign SigVal to Voltage from Analog 0
int Tripped = 0;
if (SigValue > 200) {
// Begin playing track
Serial.println(F("Playing full track 001"));
musicPlayer.playFullFile("/track001.mp3");
Serial.println(F("Playing track 002"));
musicPlayer.startPlayingFile("/track002.mp3");
Tripped = 1;
if (SigValue < 200) { //runs if Vsig drops below ~2.5 V
if (Tripped > 0 ) { //runs if music is playing
musicPlayer.stopPlaying(); // stop track
if (musicPlayer.stopped()) {
Serial.println("Done playing music");
while (1) {
delay(10); // we're done! do nothing...
if (Serial.available()) {
char c = Serial.read();
// if we get an 's' on the serial console, stop!
if (c == 's') {
// if we get an 'p' on the serial console, pause/unpause!
if (c == 'p') {
if (! musicPlayer.paused()) {
Serial.println("Paused");
musicPlayer.pausePlaying(true);
Serial.println("Resumed");
musicPlayer.pausePlaying(false);
delay(100);
/// File listing helper
void printDirectory(File dir, int numTabs) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
//Serial.println("**nomorefiles**");
for (uint8_t i=0; i<numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs+1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
When I do this, I get error 1. When I try uploading a different script to replace this, I now get the same error, until I reupload Circuit python firmware to the RP2040 using bootsel.
the first time I tried this code, I tested the switch by connecting a 3v coin battery to the A0 and GND pins. Maybe this fried the pin, but even trying to use the other analog pins, the issue remains.
