**Since 2 weeks i keep getting the issue that the arduino ide does not want to upload the sketch to the arduino mega 2560. **
The sketch was working absolutely fine but after an update it is not doing the job anymore.
**I have reinstalled the ide, reinstalled the libraries used the older version of the libraries. **
**Tried resseting the mega witth rxo txo and that works sometimes but still doesnt work frequently. ** Overall it is not working as it used to.
But when i open my laptop every morning and connect the arduino, the sketch is working fine without having to upload. But if i try again to upload the sketch than again it doesnt want to upload and it gives the message: Not connected select a board and a port to connect automatically while under the serial monitor it clearly sais that the arduino is connected, than after 2 minutes when it is trying to upload i get an error:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Failed uploading: uploading error: exit status 1
**I dont know what the issue is and i have tried a lot of methods to resolve the issue, so if someone can help me out i would really appreciate it. **
Please check the code if you think there is something wrong or bugged in the code:
#include <Wire.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_I2CRegister.h>
#include "Adafruit_MCP9600.h"
#include <Servo.h>
#define PCA9548A_ADDRESS 0x70
#define MCP9600_ADDRESS 0x60
#define FAN_PIN 50
#define SOLENOID_PIN 51
#define SERVO_PIN1 9
#define SERVO_PIN2 10
#define TEMPERATURE_THRESHOLD 30.0
#define DURATION 10000
#define MAX_ULONG 4294967295
Adafruit_MCP9600 mcp1;
Adafruit_MCP9600 mcp2;
Adafruit_MCP9600 mcp3;
Adafruit_MCP9600 mcp4;
Adafruit_MCP9600 mcp5;
Adafruit_MCP9600 mcp6;
Adafruit_MCP9600 mcp7;
Servo servo1;
Servo servo2;
unsigned long activationTime = MAX_ULONG;
Wire.begin();
setupMCP(&mcp1, 0);
setupMCP(&mcp2, 1);
setupMCP(&mcp3, 2);
setupMCP(&mcp4, 3);
setupMCP(&mcp5, 4);
setupMCP(&mcp6, 5);
setupMCP(&mcp7, 6);
pinMode(FAN_PIN, OUTPUT);
pinMode(SOLENOID_PIN, OUTPUT);
servo1.attach(SERVO_PIN1);
servo2.attach(SERVO_PIN2);
String dataString = "";
dataString += processSensor(&mcp1, millis());
dataString += ", ";
dataString += processSensor(&mcp2, 0);
dataString += ", ";
dataString += processSensor(&mcp3, 0);
dataString += ", ";
dataString += processSensor(&mcp4, 0);
dataString += ", ";
dataString += processSensor(&mcp5, 0);
dataString += ", ";
dataString += processSensor(&mcp6, 0);
dataString += ", ";
dataString += processSensor(&mcp7, 0);
Serial.println(dataString);
void setupMCP(Adafruit_MCP9600* mcp, uint8_t channel) {
selectChannel(channel);
if (!mcp->begin(MCP9600_ADDRESS)) {
Serial.print("Failed to find MCP9600 chip ");
Serial.println(channel);
while (1) {
delay(10);
mcp->setThermocoupleType(MCP9600_TYPE_K);
float processSensor(Adafruit_MCP9600* mcp, unsigned long currentTime) {
selectChannel(getChannel(mcp));
float temp = mcp->readThermocouple();
if(mcp == &mcp1) {
if(temp >= TEMPERATURE_THRESHOLD) {
digitalWrite(FAN_PIN, LOW);
digitalWrite(SOLENOID_PIN, LOW);
servo1.write(90);
servo2.write(90);
activationTime = currentTime;
} else if(activationTime != MAX_ULONG && currentTime - activationTime < DURATION) {
servo1.write(90);
servo2.write(90);
digitalWrite(FAN_PIN, HIGH);
digitalWrite(SOLENOID_PIN, HIGH);
servo1.write(0);
servo2.write(0);
return temp;
void selectChannel(uint8_t channel) {
Wire.beginTransmission(PCA9548A_ADDRESS);
Wire.write(1 << channel);
Wire.endTransmission();
uint8_t getChannel(Adafruit_MCP9600 * mcp) {
if(mcp == &mcp1) return 0;
else if(mcp == &mcp2) return 1;
else if(mcp == &mcp3) return 2;
else if(mcp == &mcp4) return 3;
else if(mcp == &mcp5) return 4;
else if(mcp == &mcp6) return 5;
else if(mcp == &mcp7) return 6;
else return 0; // default to channel 0 if unknown sensor
See errors:
