I installed Arduino IDE 2.3.2, but it is stuck on the pulsating logo screen only. I have read numerous forum posts but nothing seemed to have helped
Hi @om101. Please add a forum reply here to tell us which operating system you are using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
Hello @ptillisch, thanks for quick reply. I am using Windows 11
PS C:\Users\omtaj\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 33960
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/omtaj/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-04-20T21:42:17.919Z root INFO Backend Object.initialize: 8.2 ms [Finished 0.409 s after backend start]
2024-04-20T21:42:17.920Z root INFO Backend Object.configure: 7.8 ms [Finished 0.409 s after backend start]
2024-04-20T21:42:17.920Z root INFO Backend s.onStart: 2.0 ms [Finished 0.409 s after backend start]
2024-04-20T21:42:17.921Z root INFO Backend s.configure: 0.3 ms [Finished 0.437 s after backend start]
2024-04-20T21:42:17.921Z root INFO Backend d.onStart: 0.2 ms [Finished 0.437 s after backend start]
2024-04-20T21:42:17.922Z root INFO Backend d.configure: 0.1 ms [Finished 0.437 s after backend start]
2024-04-20T21:42:17.923Z root INFO Backend d.initialize: 28.4 ms [Finished 0.438 s after backend start]
2024-04-20T21:42:17.923Z root INFO Backend c.onStart: 0.2 ms [Finished 0.438 s after backend start]
2024-04-20T21:42:17.924Z root INFO Backend a.configure: 0.9 ms [Finished 0.439 s after backend start]
2024-04-20T21:42:17.926Z config INFO >>> Initializing CLI configuration...
2024-04-20T21:42:17.927Z root INFO Backend c.initialize: 0.4 ms [Finished 0.439 s after backend start]
2024-04-20T21:42:17.927Z root INFO Backend R.onStart: 0.7 ms [Finished 0.439 s after backend start]
2024-04-20T21:42:17.928Z config INFO Loading CLI configuration from c:\Users\omtaj\.arduinoIDE\arduino-cli.yaml...
2024-04-20T21:42:17.929Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:17.929Z root INFO Backend a.initialize: 0.5 ms [Finished 0.440 s after backend start]
2024-04-20T21:42:17.929Z root INFO Backend w.onStart: 1.4 ms [Finished 0.441 s after backend start]
2024-04-20T21:42:17.929Z root INFO Backend r.configure: 2.0 ms [Finished 0.441 s after backend start]
2024-04-20T21:42:17.930Z discovery-log INFO start
2024-04-20T21:42:17.930Z discovery-log INFO start new deferred
2024-04-20T21:42:17.930Z root INFO Backend d.initialize: 1.0 ms [Finished 0.442 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend y.onStart: 2.9 ms [Finished 0.445 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend r.configure: 2.9 ms [Finished 0.445 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend a.onStart: 1.4 ms [Finished 0.448 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend h.configure: 0.9 ms [Finished 0.448 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend s.configure: 0.2 ms [Finished 0.448 s after backend start]
2024-04-20T21:42:17.930Z root INFO Backend l.configure: 0.1 ms [Finished 0.448 s after backend start]
2024-04-20T21:42:17.933Z root INFO Theia app listening on http://127.0.0.1:54225.
2024-04-20T21:42:17.933Z root INFO Finished starting backend application: 3.2 ms [Finished 0.451 s after backend start]
2024-04-20T21:42:17.942Z root WARN The local plugin referenced by local-dir:/c%3A/Users/omtaj/.arduinoIDE/plugins does not exist.
2024-04-20T21:42:17.942Z root WARN The local plugin referenced by local-dir:/c%3A/Users/omtaj/.arduinoIDE/extensions does not exist.
2024-04-20T21:42:17.942Z root WARN The local plugin referenced by local-dir:C:\Users\omtaj\.arduinoIDE\plugins does notexist.
2024-04-20T21:42:17.951Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\omtaj\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\omtaj\\AppData\\Local\\Arduino15\\staging","user":"."},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-04-20T21:42:17.951Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-04-20T21:42:17.951Z config INFO Loaded the CLI configuration.
2024-04-20T21:42:17.954Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/omtaj/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2024-04-20T21:42:17.954Z config INFO Validating the CLI configuration...
2024-04-20T21:42:17.956Z config INFO The CLI config is valid.
2024-04-20T21:42:17.956Z config INFO <<< Initialized the CLI configuration.
2024-04-20T21:42:17.985Z root INFO Resolve plugins list: 57.7 ms [Finished 0.503 s after backend start]
2024-04-20T21:42:17.994Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:17.994Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
at Socket.<anonymous> (C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-04-20T21:42:17.994Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.000Z daemon INFO time="2024-04-21T03:12:18+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:18.011Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-21T03:12:18+05:30" level=info msg="arduino-cli.exe version 0.35.3"
2024-04-20T21:42:18.012Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:18.015Z daemon INFO Daemon is now listening on 127.0.0.1:54226
{"IP":"127.0.0.1","Port":"54226"}
2024-04-20T21:42:18.102Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.102Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.102Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.102Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54227
{"IP":"127.0.0.1","Port":"54227"}
2024-04-20T21:42:18.177Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.177Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.177Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.177Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54228
{"IP":"127.0.0.1","Port":"54228"}
2024-04-20T21:42:18.250Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.250Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.250Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.260Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54229
{"IP":"127.0.0.1","Port":"54229"}
2024-04-20T21:42:18.319Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.319Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.319Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.326Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54230
{"IP":"127.0.0.1","Port":"54230"}
2024-04-20T21:42:18.386Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.386Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.386Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.393Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54231
{"IP":"127.0.0.1","Port":"54231"}
2024-04-20T21:42:18.441Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.442Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.442Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.486Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54232
{"IP":"127.0.0.1","Port":"54232"}
2024-04-20T21:42:18.542Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.543Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.543Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.565Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54233
{"IP":"127.0.0.1","Port":"54233"}
2024-04-20T21:42:18.609Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.609Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.609Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.617Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:18.619Z daemon INFO Daemon is now listening on 127.0.0.1:54234
{"IP":"127.0.0.1","Port":"54234"}
2024-04-20T21:42:18.684Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.684Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.684Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.684Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54235
{"IP":"127.0.0.1","Port":"54235"}
2024-04-20T21:42:18.761Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.761Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.761Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.768Z daemon INFO time="2024-04-21T03:12:18+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:18.802Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54237
{"IP":"127.0.0.1","Port":"54237"}
2024-04-20T21:42:18.850Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.851Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.851Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.851Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:18.858Z daemon INFO Daemon is now listening on 127.0.0.1:54238
{"IP":"127.0.0.1","Port":"54238"}
2024-04-20T21:42:18.930Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.930Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:18.930Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:18.949Z daemon INFO time="2024-04-21T03:12:18+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:18.962Z daemon INFO Daemon is now listening on 127.0.0.1:54239
{"IP":"127.0.0.1","Port":"54239"}
2024-04-20T21:42:19.008Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.008Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.008Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.063Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-21T03:12:19+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-21T03:12:19+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:54242
{"IP":"127.0.0.1","Port":"54242"}
2024-04-20T21:42:19.132Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.132Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.132Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.140Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54243
{"IP":"127.0.0.1","Port":"54243"}
2024-04-20T21:42:19.185Z root INFO Deploy plugins list: 57.7 ms [Finished 1.703 s after backend start]
2024-04-20T21:42:19.194Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.194Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.194Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.204Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.214Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.215Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="arduino-cli.exe version 0.35.3"
2024-04-20T21:42:19.216Z daemon INFO Daemon is now listening on 127.0.0.1:54244
{"IP":"127.0.0.1","Port":"54244"}
2024-04-20T21:42:19.256Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.256Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.256Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.257Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.279Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.280Z daemon INFO Daemon is now listening on 127.0.0.1:54246
{"IP":"127.0.0.1","Port":"54246"}
2024-04-20T21:42:19.321Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.321Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.321Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.321Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.346Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.346Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:19.347Z daemon INFO Daemon is now listening on 127.0.0.1:54247
{"IP":"127.0.0.1","Port":"54247"}
2024-04-20T21:42:19.385Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.385Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.385Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.394Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.406Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.408Z daemon INFO Daemon is now listening on 127.0.0.1:54248
{"IP":"127.0.0.1","Port":"54248"}
2024-04-20T21:42:19.442Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.442Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.442Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.452Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.466Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.468Z daemon INFO Daemon is now listening on 127.0.0.1:54249
{"IP":"127.0.0.1","Port":"54249"}
2024-04-20T21:42:19.500Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.501Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.501Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.501Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.522Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.524Z daemon INFO Daemon is now listening on 127.0.0.1:54250
{"IP":"127.0.0.1","Port":"54250"}
2024-04-20T21:42:19.550Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.550Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.550Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.560Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.575Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.577Z daemon INFO Daemon is now listening on 127.0.0.1:54251
{"IP":"127.0.0.1","Port":"54251"}
2024-04-20T21:42:19.607Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.607Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.607Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.616Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.628Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.629Z daemon INFO Daemon is now listening on 127.0.0.1:54252
{"IP":"127.0.0.1","Port":"54252"}
2024-04-20T21:42:19.661Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.661Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.661Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.668Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.682Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.685Z daemon INFO Daemon is now listening on 127.0.0.1:54253
{"IP":"127.0.0.1","Port":"54253"}
2024-04-20T21:42:19.731Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.731Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.731Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.731Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.754Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.755Z daemon INFO Daemon is now listening on 127.0.0.1:54254
{"IP":"127.0.0.1","Port":"54254"}
2024-04-20T21:42:19.788Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.788Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.788Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.788Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.810Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.812Z daemon INFO Daemon is now listening on 127.0.0.1:54255
{"IP":"127.0.0.1","Port":"54255"}
2024-04-20T21:42:19.841Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.841Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.841Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.842Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.863Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.863Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:19.865Z daemon INFO Daemon is now listening on 127.0.0.1:54256
{"IP":"127.0.0.1","Port":"54256"}
2024-04-20T21:42:19.905Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.905Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.905Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
Opening channel for service path '/services/electron-window'.
2024-04-20T21:42:19.927Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:19.927Z daemon INFO time="2024-04-21T03:12:19+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:19.928Z daemon INFO Daemon is now listening on 127.0.0.1:54257
{"IP":"127.0.0.1","Port":"54257"}
2024-04-20T21:42:19.966Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.966Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:19.966Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:19.966Z daemon INFO time="2024-04-21T03:12:19+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:19.990Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-21T03:12:20+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-21T03:12:20+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:19.991Z daemon INFO Daemon is now listening on 127.0.0.1:54258
{"IP":"127.0.0.1","Port":"54258"}
2024-04-20T21:42:20.022Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.023Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.023Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.023Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
Opening channel for service path '/services/ide-updater'.
2024-04-20T21:42:20.047Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.048Z daemon INFO Daemon is now listening on 127.0.0.1:54259
{"IP":"127.0.0.1","Port":"54259"}
2024-04-20T21:42:20.087Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.087Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.087Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.105Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.106Z daemon INFO Daemon is now listening on 127.0.0.1:54261
{"IP":"127.0.0.1","Port":"54261"}
2024-04-20T21:42:20.148Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.148Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.148Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.149Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.176Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.176Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:20.178Z daemon INFO Daemon is now listening on 127.0.0.1:54262
{"IP":"127.0.0.1","Port":"54262"}
2024-04-20T21:42:20.238Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.238Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.238Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.249Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54263
{"IP":"127.0.0.1","Port":"54263"}
2024-04-20T21:42:20.300Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.300Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.300Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.308Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.323Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.324Z daemon INFO Daemon is now listening on 127.0.0.1:54264
{"IP":"127.0.0.1","Port":"54264"}
2024-04-20T21:42:20.343Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 228.2 ms [Finished 2.277 s after frontend start]
2024-04-20T21:42:20.343Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-04-20T21:42:20.362Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.362Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.362Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.363Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.383Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.384Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:20.385Z daemon INFO Daemon is now listening on 127.0.0.1:54265
{"IP":"127.0.0.1","Port":"54265"}
2024-04-20T21:42:20.420Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.420Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.420Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.420Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.440Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.442Z daemon INFO Daemon is now listening on 127.0.0.1:54267
{"IP":"127.0.0.1","Port":"54267"}
2024-04-20T21:42:20.470Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.471Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.471Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.481Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.497Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:54268
{"IP":"127.0.0.1","Port":"54268"}
2024-04-20T21:42:20.532Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.532Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.532Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.544Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.557Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.558Z daemon INFO Daemon is now listening on 127.0.0.1:54269
{"IP":"127.0.0.1","Port":"54269"}
2024-04-20T21:42:20.594Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.594Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.594Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.603Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.620Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.621Z daemon INFO Daemon is now listening on 127.0.0.1:54270
{"IP":"127.0.0.1","Port":"54270"}
2024-04-20T21:42:20.654Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.654Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.654Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.654Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.674Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.675Z daemon INFO Daemon is now listening on 127.0.0.1:54271
{"IP":"127.0.0.1","Port":"54271"}
2024-04-20T21:42:20.705Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.705Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.705Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.714Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.728Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.729Z daemon INFO Daemon is now listening on 127.0.0.1:54272
{"IP":"127.0.0.1","Port":"54272"}
2024-04-20T21:42:20.764Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.764Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.764Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.775Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.784Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.785Z daemon INFO Daemon is now listening on 127.0.0.1:54273
{"IP":"127.0.0.1","Port":"54273"}
2024-04-20T21:42:20.823Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.823Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.823Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.832Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.846Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.846Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:20.848Z daemon INFO Daemon is now listening on 127.0.0.1:54274
{"IP":"127.0.0.1","Port":"54274"}
2024-04-20T21:42:20.892Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.892Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:20.892Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:20.903Z daemon INFO time="2024-04-21T03:12:20+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:20.921Z daemon INFO time="2024-04-21T03:12:20+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:20.922Z daemon INFO Daemon is now listening on 127.0.0.1:54275
{"IP":"127.0.0.1","Port":"54275"}
2024-04-20T21:42:21.006Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.006Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.006Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.016Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.029Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-21T03:12:21+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-21T03:12:21+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:21.030Z daemon INFO Daemon is now listening on 127.0.0.1:54276
{"IP":"127.0.0.1","Port":"54276"}
2024-04-20T21:42:21.062Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.062Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.062Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.072Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.085Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.086Z daemon INFO Daemon is now listening on 127.0.0.1:54277
{"IP":"127.0.0.1","Port":"54277"}
2024-04-20T21:42:21.117Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.118Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.118Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.118Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.140Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.141Z daemon INFO Daemon is now listening on 127.0.0.1:54278
{"IP":"127.0.0.1","Port":"54278"}
2024-04-20T21:42:21.168Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.168Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.168Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.168Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.189Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.191Z daemon INFO Daemon is now listening on 127.0.0.1:54279
{"IP":"127.0.0.1","Port":"54279"}
2024-04-20T21:42:21.224Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.224Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.224Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.233Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.245Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.247Z daemon INFO Daemon is now listening on 127.0.0.1:54280
{"IP":"127.0.0.1","Port":"54280"}
2024-04-20T21:42:21.278Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.278Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.278Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.288Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.299Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.300Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:21.300Z daemon INFO Daemon is now listening on 127.0.0.1:54281
{"IP":"127.0.0.1","Port":"54281"}
2024-04-20T21:42:21.343Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.344Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.344Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.353Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.365Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.366Z daemon INFO Daemon is now listening on 127.0.0.1:54282
{"IP":"127.0.0.1","Port":"54282"}
2024-04-20T21:42:21.399Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.399Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.399Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.410Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.424Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.425Z daemon INFO Daemon is now listening on 127.0.0.1:54283
{"IP":"127.0.0.1","Port":"54283"}
2024-04-20T21:42:21.452Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.453Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.453Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.462Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.473Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.475Z daemon INFO Daemon is now listening on 127.0.0.1:54284
{"IP":"127.0.0.1","Port":"54284"}
2024-04-20T21:42:21.507Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.507Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.507Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.528Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.530Z daemon INFO Daemon is now listening on 127.0.0.1:54285
{"IP":"127.0.0.1","Port":"54285"}
2024-04-20T21:42:21.565Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.565Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.565Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.565Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.586Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.588Z daemon INFO Daemon is now listening on 127.0.0.1:54286
{"IP":"127.0.0.1","Port":"54286"}
2024-04-20T21:42:21.613Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.613Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.613Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.622Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.640Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.640Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:21.645Z daemon INFO Daemon is now listening on 127.0.0.1:54287
{"IP":"127.0.0.1","Port":"54287"}
2024-04-20T21:42:21.674Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.674Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.674Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.675Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.695Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.696Z daemon INFO Daemon is now listening on 127.0.0.1:54288
{"IP":"127.0.0.1","Port":"54288"}
2024-04-20T21:42:21.723Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.723Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.723Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.742Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.744Z daemon INFO Daemon is now listening on 127.0.0.1:54289
{"IP":"127.0.0.1","Port":"54289"}
2024-04-20T21:42:21.777Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.777Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.777Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.777Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.803Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.804Z daemon INFO Daemon is now listening on 127.0.0.1:54290
{"IP":"127.0.0.1","Port":"54290"}
2024-04-20T21:42:21.828Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.828Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.828Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.838Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.849Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.850Z daemon INFO Daemon is now listening on 127.0.0.1:54291
{"IP":"127.0.0.1","Port":"54291"}
2024-04-20T21:42:21.882Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.882Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.882Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.891Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.901Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.901Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:21.902Z daemon INFO Daemon is now listening on 127.0.0.1:54292
{"IP":"127.0.0.1","Port":"54292"}
2024-04-20T21:42:21.930Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.930Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.930Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.939Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:21.950Z daemon INFO time="2024-04-21T03:12:21+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:21.951Z daemon INFO Daemon is now listening on 127.0.0.1:54293
{"IP":"127.0.0.1","Port":"54293"}
2024-04-20T21:42:21.981Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.981Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:21.981Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:21.990Z daemon INFO time="2024-04-21T03:12:21+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:22.000Z daemon INFO time="2024-04-21T03:12:22+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-21T03:12:22+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-21T03:12:22+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-04-20T21:42:22.001Z daemon INFO Daemon is now listening on 127.0.0.1:54294
{"IP":"127.0.0.1","Port":"54294"}
2024-04-20T21:42:22.027Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.027Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.027Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:22.027Z daemon INFO time="2024-04-21T03:12:22+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:22.047Z daemon INFO time="2024-04-21T03:12:22+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:22.048Z daemon INFO Daemon is now listening on 127.0.0.1:54295
{"IP":"127.0.0.1","Port":"54295"}
2024-04-20T21:42:22.075Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.075Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.075Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:22.083Z daemon INFO time="2024-04-21T03:12:22+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:22.097Z daemon INFO time="2024-04-21T03:12:22+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:22.099Z daemon INFO Daemon is now listening on 127.0.0.1:54296
{"IP":"127.0.0.1","Port":"54296"}
2024-04-20T21:42:22.125Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.125Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.125Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:22.126Z daemon INFO time="2024-04-21T03:12:22+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:22.146Z daemon INFO time="2024-04-21T03:12:22+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:22.147Z daemon INFO Daemon is now listening on 127.0.0.1:54297
{"IP":"127.0.0.1","Port":"54297"}
2024-04-20T21:42:22.173Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.173Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-04-20T21:42:22.173Z daemon INFO Starting daemon from C:\Users\omtaj\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-20T21:42:22.173Z daemon INFO time="2024-04-21T03:12:22+05:30" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-04-20T21:42:22.193Z daemon INFO time="2024-04-21T03:12:22+05:30" level=info msg="Using config file: c:\\Users\\omtaj\\.arduinoIDE\\arduino-cli.yaml"
2024-04-20T21:42:22.194Z daemon INFO Daemon is now listening on 127.0.0.1:54298
{"IP":"127.0.0.1","Port":"54298"}
69 errors searching for remote files. Is the internet connection up?
If you have / had OneDrive installed, here are a number of search results (filtered for @ptillisch) : Search results for 'onedrive @ptillisch #software:ide-2-x' - Arduino Forum
You will have to dig through them to try to find the solution.
Yeah, it was connected to internet while opening
Yeah, I had Onedrive. But I uninstalled it, and it may be causing the file path error. I will look into it. Thanks
https://forum.arduino.cc/t/arduino-ide-2-1-0-only-pulsing-arduino-symbol-after-launching-the-app/1121605/26?u=om101
This post helped me, I changed the OneDrive/documents location to user/documents via registry editor. Thank you @sterretje @xfpd @ptillisch
