Arduino IDE Stuck on uploading
I have a problem when uploading sketch to Arduino Board. It cannot completely upload and this is what verbose show.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\Russb\AppData\Local\Temp\arduino_build_96942/Blink.ino.hex"
avrdude: writing flash (1446 bytes):
Writing | ################################################## | 100% 0.23s
avrdude: 1446 bytes of flash written
avrdude: verifying flash memory against C:\Users\Russb\AppData\Local\Temp\arduino_build_96942/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Russb\AppData\Local\Temp\arduino_build_96942/Blink.ino.hex:
avrdude: input file C:\Users\Russb\AppData\Local\Temp\arduino_build_96942/Blink.ino.hex contains 1446 bytes
avrdude: reading on-chip flash data:
Reading |
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
How can I solve it? I have been tried to change the cable and computer but not solved!
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
I already removed connections to pins 0 and 1 and selected correct port and board but cannot be solved
But sometime Arduino IDE verbose show
Using Port : COM4
Using Programmer : arduino
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
The two outputs you posted come from different Tools > Board menu selections. Which Arduino board are you using?
Arduino Mega 2560 Board
Then you need to be sure to select Tools > Board > Arduino Mega or Mega 2560 and Tools > Processor ATmega2560 (Mega 2560).
This is what Arduino IDE show when I selected Arduino Mega in Tools>Board
Using Port : COM4
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: reading input file "C:\Users\Russb\AppData\Local\Temp\arduino_build_76825/Blink.ino.hex"
avrdude: writing flash (1448 bytes):
Writing | ################################################## | 100% 0.24s
avrdude: 1448 bytes of flash written
avrdude: verifying flash memory against C:\Users\Russb\AppData\Local\Temp\arduino_build_76825/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Russb\AppData\Local\Temp\arduino_build_76825/Blink.ino.hex:
avrdude: input file C:\Users\Russb\AppData\Local\Temp\arduino_build_76825/Blink.ino.hex contains 1448 bytes
Reading | avrdude: stk500v2_ReceiveMessage(): timeout
In the Tools > Port menu, is the port of your Mega identified as "{port name} (Arduino Mega or Mega 2560)", where {port name} is the name of the port?
No. not show anything
What is written on top of the largest black chip near the USB socket on the Mega board near the USB socket? It will probably say either "MEGA16U2" or "CH340".
CH340G
I was going to suggest you do a loopback test, but I believe that test will give a false failure on the boards that use the CH340, so it wouldn't be helpful.
The only thing I can suggest for you to try to resolve this problem is to try burning the bootloader.
You will need an ISP programmer. If you don’t have a programmer, you can use a spare Arduino board as an "Arduino as ISP" programmer. Although the "Arduino as ISP" only works for programming targets of the AVR architecture, you can use boards of any architecture as an "Arduino as ISP" programmer.
The following instructions are for using an Arduino board as an "Arduino as ISP" programmer. If you have a dedicated programmer, you can skip to the next set of instructions.
  1. Make the following connections between the Arduino board you will be using as the programmer and the target. Refer to the "Connections" table on the SPI library reference page to determine the pins:
    Programmer Target
    MISO MISO
    VCC 5V
    (VCC on 3.3 V boards)
    SCK SCK
    MOSI MOSI
    10 RESET
    GND GND
  2. Connect the programmer board to your computer with a USB cable.
  3. File > Examples > 11.ArduinoISP > Arduino ISP
  4. Select the port of your board from the Tools > Port menu.
  5. Sketch > Upload
  6. Wait for the upload to finish.
You are now ready to burn the bootloader using your "Arduino as ISP" programmer.
Instructions for burning the bootloader:
  1. Connect an ISP programmer to the ICSP header on your Arduino board.
  2. Select the target board from the Tools > Board menu and any other custom Tools menus (e.g. Tools > Processor).
  3. Select the appropriate programmer from the Tools > Programmer menu.
  4. Tools > Burn Bootloader
  5. Wait for the process to finish successfully.
