Arduino IDE (Ubuntu 12.04) Error with including .ino files & java
Hello everyone.
I currently have a total of four .ino files in my sketch.
Main sketch: "hub.ino"
Includes:
#include <Memory.ino>
#include <RF24.ino>
#include <WiFi.ino>
Directories:
./hub:
Credentials.h  hub.ino  Memory.ino  RF24.ino  WiFi.ino
When I try to compile, I get the error:
hub.cpp: fatal error: Memory.ino: No such file or directory
I then also get a whole bunch of Java errors:
My version of Java:
~$ > update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      auto mode
* 1            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      manual mode
  2            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java   1051      manual mode
Press enter to keep the current choice[*], or type selection number:
Any help would be much appreciated.
That is not how the IDE "includes" other sketch code. Remove the .ino includes from hub.ino. On the menu bar, select "Sketch - Add File". Find "Memory.ino" and add it. It will be loaded into a second tab. Do the same for the other .ino files. They will also be in separate tabs. Then it should compile ok.
thanks!
