Normally everything works fine, but with the sketch below, I can upload it to Arduino Uno just fine, but when I click on serial monitor, I get the error:
Serial port '/dev/ttyACM0' not found. Did you select the right one from...
Here's the sketch, which reads data from a GPS device, and then stores the highest altitude it sees in an array. When it sees a higher altitude, it moves everything in the array over by 1, so it can keep track of the 10 highest altitudes registered. Then it just prints the altitude array.
#include "TinyGPS.h"
#include <NewSoftSerial.h>
TinyGPS gps;
NewSoftSerial nss(2,4,true);
int maxaltitude[10] = {0};
int testalt = 0;
char byteGPS;
int i = 0;
int j = 0;
nss.begin(4800);
pinMode(13,OUTPUT);
if (nss.available())
digitalWrite(13, HIGH);
byteGPS = nss.read();
if (gps.encode(byteGPS))
testalt = gps.f_altitude();
if (testalt > maxaltitude[0])
i = 9;
while (i > 0)
maxaltitude[i] = maxaltitude[i-1];
i--;
maxaltitude[0] = testalt;
Serial.println("New altitude string:");
j = 0;
while (j < 9)
Serial.println(maxaltitude[j]);
j++;
On this code, it works fine: (this code just reads data from the GPS device and prints it to the screen)
char bytegps;
nss.begin(4800);
bytegps = nss.read();
Serial.print(bytegps);
Is it an issue with my code or is there something else going on? Thanks in advance.
