Arduino IDE won't load a sketch into the editor
I have been working on a project in Arduino IDE version 2.0.4. It is a rather large project with about 30+ files. Last night I restarted the IDE after many weeks of continuous running, and it refuses to open the project sketch. It opens a brand new blank sketch every time. It does open other, smaller projects, but not the one I am working on. Any pointers how to fix this is appreciated.
This is on Windows 10. Windows Feature Experience Pack 120.2212.4190.0
It had been working okay, until I restarted the IDE last night.
Is there a projectname.ino file inside a directory named projectname (or whatever).
That naming convention has been part of arduino for a long time.
Yes, there is. This is an old project I have been working on for a long time now. It just suddently stopped working.
It appears to be related to the sketchbook location. I have set my preferences to an alternate directory and this sketch is located in there. This has always been true, so that did not change when it stopped working. And I am able to open other sketches in that location. But when I copy this particular sketch to the default /Arduino, it will load. But not in the sketchbook location directory set in preferences.
Thank you.
Hi @tenchiro. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<username>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  7. Wait for Arduino IDE to finish starting.
  8. Attempt to open the sketch from the problematic location, just as you did before.
  9. After opening the sketch fails, switch back to the PowerShell window.
  10. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  11. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  12. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  13. Open a forum reply here by clicking the Reply button.
  14. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  15. Press Ctrl+V.
    This will paste the output into the code block.
  16. Move the cursor outside of the code block markup before you add any additional text to your reply.
  17. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.4
Starting backend process. PID: 21084
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/john_4bbk5we/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-04-02T10:20:48.258Z root INFO Backend Object.initialize: 4.1 ms [Finished 1.395 s after backend start]
2023-04-02T10:20:48.258Z root INFO Backend Object.configure: 3.4 ms [Finished 1.395 s after backend start]
2023-04-02T10:20:48.260Z root INFO Backend MessagingContribution.onStart: 1.4 ms [Finished 1.395 s after backend start]
2023-04-02T10:20:48.261Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.435 s after backend start]
2023-04-02T10:20:48.262Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.436 s after backend start]
2023-04-02T10:20:48.264Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.436 s after backend start]
2023-04-02T10:20:48.265Z root INFO Backend PluginLocalizationBackendContribution.initialize: 40.5 ms [Finished 1.436 s after backend start]
2023-04-02T10:20:48.265Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.436 s after backend start]
2023-04-02T10:20:48.267Z root INFO Backend ElectronTokenBackendContribution.configure: 3.5 ms [Finished 1.439 s after backend start]
2023-04-02T10:20:48.267Z config INFO >>> Initializing CLI configuration...
2023-04-02T10:20:48.268Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 1.440 s after backend start]
2023-04-02T10:20:48.268Z root INFO Backend ConfigServiceImpl.onStart: 1.0 ms [Finished 1.441 s after backend start]
2023-04-02T10:20:48.269Z config INFO Loading CLI configuration from c:\Users\john_4bbk5we\.arduinoIDE\arduino-cli.yaml...
2023-04-02T10:20:48.270Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.6 ms [Finished 1.442 s after backend start]
2023-04-02T10:20:48.270Z root INFO Backend ArduinoDaemonImpl.onStart: 1.6 ms [Finished 1.443 s after backend start]
2023-04-02T10:20:48.271Z root INFO Backend NodeFileUploadService.configure: 3.0 ms [Finished 1.444 s after backend start]
2023-04-02T10:20:48.271Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-04-02T10:20:48.271Z discovery-log INFO start
2023-04-02T10:20:48.271Z discovery-log INFO start new deferred
2023-04-02T10:20:48.271Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 1.445 s after backend start]
2023-04-02T10:20:48.271Z root INFO Backend BoardDiscovery.onStart: 1.5 ms [Finished 1.446 s after backend start]
2023-04-02T10:20:48.272Z root INFO Backend FileDownloadEndpoint.configure: 1.4 ms [Finished 1.447 s after backend start]
2023-04-02T10:20:48.272Z root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 1.449 s after backend start]
2023-04-02T10:20:48.272Z root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 1.449 s after backend start]
2023-04-02T10:20:48.274Z root INFO Backend HostedPluginReader.configure: 0.5 ms [Finished 1.450 s after backend start]
2023-04-02T10:20:48.274Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.450 s after backend start]
2023-04-02T10:20:48.274Z root INFO Backend PlotterBackendContribution.configure: 1.6 ms [Finished 1.452 s after backend start]
2023-04-02T10:20:48.277Z root INFO Theia app listening on http://localhost:64053.
2023-04-02T10:20:48.280Z root INFO Finished starting backend application: 5.8 ms [Finished 1.455 s after backend start]
2023-04-02T10:20:48.281Z root WARN The local plugin referenced by local-dir:/c%3A/Users/john_4bbk5we/.arduinoIDE/plugins does not exist.
2023-04-02T10:20:48.282Z root WARN The local plugin referenced by local-dir:/c%3A/Users/john_4bbk5we/.arduinoIDE/extensions does not exist.
2023-04-02T10:20:48.283Z root WARN The local plugin referenced by local-dir:C:\Users\john_4bbk5we\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\john_4bbk5we\Arduino\mavlight_land
isTempSketch: false. Input was c:\Users\john_4bbk5we\Arduino\mavlight_land\mavlight_land.ino
2023-04-02T10:20:48.313Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.313Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-04-02T10:20:48.314Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.7" with engines:
2023-04-02T10:20:48.314Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.315Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-04-02T10:20:48.316Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.316Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-04-02T10:20:48.317Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.317Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-04-02T10:20:48.319Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.320Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-04-02T10:20:48.322Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.325Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-04-02T10:20:48.327Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.328Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-04-02T10:20:48.329Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.329Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-04-02T10:20:48.330Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.330Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-04-02T10:20:48.331Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.332Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-04-02T10:20:48.332Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.333Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-04-02T10:20:48.333Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.334Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-04-02T10:20:48.335Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.337Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-04-02T10:20:48.343Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.343Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-04-02T10:20:48.344Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.345Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-04-02T10:20:48.345Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.346Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-04-02T10:20:48.347Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.347Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-04-02T10:20:48.348Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.348Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-04-02T10:20:48.349Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.349Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-04-02T10:20:48.350Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-02T10:20:48.350Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-04-02T10:20:48.358Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://dl.espressif.com/dl/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\staging","user":"\\\\tenchiro-souko\\dev-souko\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-04-02T10:20:48.359Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-04-02T10:20:48.360Z config INFO Loaded the CLI configuration.
2023-04-02T10:20:48.389Z root INFO Resolve plugins list: 120.2 ms [Finished 1.567 s after backend start]
2023-04-02T10:20:48.394Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 4.9 ms [Finished 1.572 s after backend start]
2023-04-02T10:20:48.397Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.7" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.8 ms [Finished 1.575 s after backend start]
2023-04-02T10:20:48.407Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 9.8 ms [Finished 1.585 s after backend start]
2023-04-02T10:20:48.409Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.4 ms [Finished 1.588 s after backend start]
2023-04-02T10:20:48.410Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.0 ms [Finished 1.589 s after backend start]
2023-04-02T10:20:48.500Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 90.1 ms [Finished 1.679 s after backend start]
2023-04-02T10:20:48.523Z daemon INFO INFO[0000] Using config file: c:\Users\john_4bbk5we\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.31.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"64054"}
2023-04-02T10:20:48.524Z daemon INFO Daemon is running.
2023-04-02T10:20:48.644Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 143.6 ms [Finished 1.822 s after backend start]
2023-04-02T10:20:48.796Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 152.3 ms [Finished 1.975 s after backend start]
2023-04-02T10:20:48.797Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/john_4bbk5we/AppData/Local/Arduino15","sketchDirUri":"file://tenchiro-souko/dev-souko/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://dl.espressif.com/dl/package_esp32_index.json"],"network":"none","locale":"en"}
2023-04-02T10:20:48.797Z config INFO Validating the CLI configuration...
2023-04-02T10:20:48.800Z daemon INFO INFO[0000] Loading hardware from: c:\Users\john_4bbk5we\AppData\Local\Arduino15\packages
INFO[0000] Loading package arduino from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json.sig"
INFO[0000] Loaded platform                               platform="arduino:samd@1.8.13"
INFO[0000] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool                                   tool="arduino:CMSIS@4.5.0"
INFO[0000] Loaded tool                                   tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0000] Loaded tool                                   tool="arduino:arduinoOTA@1.2.1"
INFO[0000] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool                                   tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0000] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool                                   tool="arduino:bossac@1.7.0-arduino3"
INFO[0000] Loaded tool                                   tool="arduino:openocd@0.10.0-arduino7"
INFO[0000] Loading package builtin from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.3.3"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.12.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loading package esp32 from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json.sig"
INFO[0000] Loaded platform                               platform="esp32:esp32@1.0.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loaded tool                                   tool="esp32:esptool_py@3.0.0"
INFO[0000] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
INFO[0000] Loading package esp8266 from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json.sig"
INFO[0000] Loaded platform                               platform="esp8266:esp8266@3.1.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0000] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0000] Loaded tool                                   tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
INFO[0000] Loaded tool                                   tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
INFO[0000] Loaded tool                                   tool="esp8266:python3@3.7.2-post1"
INFO[0000] Loaded tool                                   tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
INFO[0000] Checking signature                            index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Checking signature                            error="opening signature file: open c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json.sig: The system cannot find the file specified." index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json.sig"
INFO[0000] Checking signature                            error="opening signature file: open c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified." index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig"
INFO[0000] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
INFO[0000] Loading libraries index file                  index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\library_index.json"
2023-04-02T10:20:48.958Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 160.8 ms [Finished 2.135 s after backend start]
2023-04-02T10:20:48.959Z config INFO The CLI config is valid.
2023-04-02T10:20:48.960Z config INFO <<< Initialized the CLI configuration.
2023-04-02T10:20:49.109Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 151.5 ms [Finished 2.287 s after backend start]
2023-04-02T10:20:49.116Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="\\\\tenchiro-souko\\dev-souko\\Arduino\\libraries" location=user
2023-04-02T10:20:49.193Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 83.7 ms [Finished 2.371 s after backend start]
2023-04-02T10:20:49.303Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 109.8 ms [Finished 2.481 s after backend start]
2023-04-02T10:20:49.424Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 121.3 ms [Finished 2.602 s after backend start]
2023-04-02T10:20:49.540Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 115.2 ms [Finished 2.718 s after backend start]
2023-04-02T10:20:49.586Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 46.7 ms [Finished 2.764 s after backend start]
2023-04-02T10:20:49.689Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 102.8 ms [Finished 2.867 s after backend start]
2023-04-02T10:20:49.786Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 96.8 ms [Finished 2.964 s after backend start]
2023-04-02T10:20:49.904Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 118.2 ms [Finished 3.082 s after backend start]
2023-04-02T10:20:49.996Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 91.6 ms [Finished 3.174 s after backend start]
2023-04-02T10:20:50.063Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 66.8 ms [Finished 3.241 s after backend start]
2023-04-02T10:20:50.163Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 99.5 ms [Finished 3.341 s after backend start]
2023-04-02T10:20:50.163Z root INFO Deploy plugins list: 120.2 ms [Finished 3.341 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-04-02T10:20:50.963Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 272.0 ms [Finished 2.576 s after frontend start]
2023-04-02T10:20:51.532Z discovery-log INFO start request start watch
2023-04-02T10:20:51.533Z discovery-log INFO start requested start watch
2023-04-02T10:20:51.538Z discovery-log INFO start resolved watching
2023-04-02T10:20:51.540Z daemon INFO INFO[0003] starting discovery builtin:mdns-discovery process
2023-04-02T10:20:51.541Z daemon INFO INFO[0003] starting discovery builtin:serial-discovery process
2023-04-02T10:20:51.553Z daemon INFO INFO[0003] started discovery builtin:serial-discovery process
INFO[0003] sending command HELLO 1 "arduino-cli 0.31.0" to discovery builtin:serial-discovery
2023-04-02T10:20:51.580Z daemon INFO INFO[0003] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
2023-04-02T10:20:51.581Z daemon INFO INFO[0003] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0003] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-04-02T10:20:51.584Z daemon INFO INFO[0003] started discovery builtin:mdns-discovery process
INFO[0003] sending command HELLO 1 "arduino-cli 0.31.0" to discovery builtin:mdns-discovery
2023-04-02T10:20:51.600Z daemon INFO INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM4
2023-04-02T10:20:51.601Z daemon INFO INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM63
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM64
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM5
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM60
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM62
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM65
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM61
2023-04-02T10:20:51.619Z daemon INFO INFO[0003] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
2023-04-02T10:20:51.619Z daemon INFO INFO[0003] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0003] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-04-02T10:20:51.624Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM64","label":"COM64","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.629Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.631Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM60","label":"COM60","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.633Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM62","label":"COM62","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.639Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM65","label":"COM65","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.641Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM61","label":"COM61","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.643Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.645Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM63","label":"COM63","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-04-02T10:20:51.745Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\john_4bbk5we\Arduino\mavlight_land\mavlight_land.ino>, response: <c:\Users\john_4bbk5we\Arduino\mavlight_land>.
2023-04-02T10:20:51.796Z root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 698.6 ms [Finished 3.470 s after frontend start]
2023-04-02T10:20:51.856Z root INFO Start frontend contributions: 1292.5 ms [Finished 3.484 s after frontend start]
2023-04-02T10:20:51.857Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-04-02T10:20:51.903Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-04-02T10:20:51.904Z root INFO >>> Restoring the layout state...
2023-04-02T10:20:51.912Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-04-02T10:20:51.912Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mavlight_land.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":7,\"column\":129},\"position\":{\"lineNumber\":7,\"column\":129}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":597,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/app_globaldefs.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":342,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/app_hwdefs.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":110,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/app_paramdefs.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":414,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/blueport.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":333,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/blueport.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":57,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashlight.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":504,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashlight.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":632,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashpanel.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":202,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashpanel.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":53,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashpwm.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":69,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/flashpwm.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":25,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/font_flags.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":51,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":23,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_aircraft.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1056,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_aircraft.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":124,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_iot.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":257,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_iot.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":38,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_light.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1374,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_light.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":218,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_param.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":702,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_param.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":117,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_sys.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1138,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mav_sys.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":187,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mavlink.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":41,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/pwmctl.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":293,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/pwmctl.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":137,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":314,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"},\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///c%3A/Users/john_4bbk5we/Arduino/mavlight_land/mavlight_land.ino:0"}
2023-04-02T10:20:51.916Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-04-02T10:20:52.016Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7] Waiting for backend deployment: 207.4 ms [Finished 3.681 s after frontend start]
2023-04-02T10:20:52.757Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640) starting instance
2023-04-02T10:20:53.354Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7] Sync of 21 plugins: 1350.4 ms [Finished 5.032 s after frontend start]
2023-04-02T10:20:56.889Z root INFO <<< The layout has been successfully restored.
2023-04-02T10:21:00.322Z root INFO Initialize the workbench layout: 5014.1 ms [Finished 8.567 s after frontend start]
2023-04-02T10:21:00.324Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-04-02T10:21:00.326Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][marus25.cortex-debug]: Loaded contributions.
2023-04-02T10:21:00.328Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][arduino.vscode-arduino-tools]: Loaded contributions.
2023-04-02T10:21:00.331Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.cpp]: Loaded contributions.
2023-04-02T10:21:00.331Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.json]: Loaded contributions.
2023-04-02T10:21:00.332Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.json-language-features]: Loaded contributions.
2023-04-02T10:21:00.333Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-04-02T10:21:00.334Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-04-02T10:21:00.334Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-04-02T10:21:00.335Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-04-02T10:21:00.340Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-04-02T10:21:00.345Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-04-02T10:21:00.345Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-04-02T10:21:00.346Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-04-02T10:21:00.347Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-04-02T10:21:00.347Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-04-02T10:21:00.348Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-04-02T10:21:00.349Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-04-02T10:21:00.350Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-04-02T10:21:00.350Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-04-02T10:21:00.355Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-04-02T10:21:00.359Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-04-02T10:21:00.360Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7] Load contributions of 21 plugins: 3430.3 ms [Finished 11.999 s after frontend start]
2023-04-02T10:21:00.464Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-04-02T10:21:00.464Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-04-02T10:21:00.922Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): PluginManagerExtImpl/init()
2023-04-02T10:21:00.926Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.935Z root INFO [hosted-plugin: 14640] Debugger contribution has been registered: cortex-debug
2023-04-02T10:21:00.937Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-arduino-tools@0.0.2-beta.7 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.938Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.946Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.947Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.948Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.953Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.954Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.960Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(14640): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.961Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.962Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.962Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.963Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:00.972Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-04-02T10:21:01.078Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-04-02T10:21:01.139Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][marus25.cortex-debug]: Started plugin.
2023-04-02T10:21:01.141Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][arduino.vscode-arduino-tools]: Started plugin.
2023-04-02T10:21:01.142Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.cpp]: Started plugin.
2023-04-02T10:21:01.144Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.json]: Started plugin.
2023-04-02T10:21:01.144Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][vscode.json-language-features]: Started plugin.
2023-04-02T10:21:01.145Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-04-02T10:21:01.146Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-04-02T10:21:01.146Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-04-02T10:21:01.146Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-04-02T10:21:01.147Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-04-02T10:21:01.148Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-04-02T10:21:01.149Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-04-02T10:21:01.150Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-04-02T10:21:01.150Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-04-02T10:21:01.151Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-04-02T10:21:01.151Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-04-02T10:21:01.156Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-04-02T10:21:01.156Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-04-02T10:21:01.157Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-04-02T10:21:01.160Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-04-02T10:21:01.161Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-04-02T10:21:01.176Z root INFO [hosted-plugin: 14640] PLUGIN_HOST(14640): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-04-02T10:21:01.222Z root INFO [hosted-plugin: 14640] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-04-02T10:21:01.227Z root INFO [hosted-plugin: 14640] GDB server console created
2023-04-02T10:21:01.969Z root INFO Frontend application start: 11082.2 ms [Finished 15.144 s after backend start]
2023-04-02T10:21:01.978Z root INFO Replace loading indicator with ready workbench UI (animation): 919.5 ms [Finished 12.919 s after frontend start]
2023-04-02T10:21:02.030Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-04-02T10:21:02.030Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
Checking for update
2023-04-02T10:21:02.091Z root INFO [3e2b33d2-db3f-46cd-8cea-ff239e2e0bd7] Start of 21 plugins: 1726.0 ms [Finished 13.733 s after frontend start]
2023-04-02T10:21:02.538Z daemon INFO INFO[0014] Updating libraries index
INFO[0014] Updating index                                url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-04-02T10:21:02.597Z daemon INFO INFO[0014] Starting download                             url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-04-02T10:21:02.614Z root INFO core-client-provider [platform-index]
2023-04-02T10:21:02.625Z root INFO core-client-provider [library-index]
2023-04-02T10:21:02.626Z daemon INFO INFO[0014] Starting download                             url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
Update for version 2.0.4 is not available (latest version: 2.0.4, downgrade is allowed).
2023-04-02T10:21:04.093Z root ERROR ---- !!!SLOW!!! DURATION: search took 1863.101 ms. Args: [{"type":"Updatable"}] ----
2023-04-02T10:21:04.095Z root INFO core-client-provider [platform-index]
2023-04-02T10:21:04.098Z root INFO Starting language server: esp32:esp32:d1_mini32:FlashFreq=80,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600
2023-04-02T10:21:04.102Z daemon INFO INFO[0015] Updating index                                url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
INFO[0015] Starting download                             url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
2023-04-02T10:21:04.734Z daemon INFO INFO[0016] Updating index                                url="https://dl.espressif.com/dl/package_esp32_index.json"
2023-04-02T10:21:04.736Z daemon INFO INFO[0016] Starting download                             url="https://dl.espressif.com/dl/package_esp32_index.json"
2023-04-02T10:21:04.739Z root INFO core-client-provider [platform-index]
2023-04-02T10:21:04.743Z daemon INFO INFO[0016] Required tool                                 tool="esp32:esptool_py@3.0.0"
INFO[0016] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0016] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
INFO[0016] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0016] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" location=platform
2023-04-02T10:21:04.744Z daemon INFO INFO[0016] Adding libraries dir                          dir="\\\\tenchiro-souko\\dev-souko\\Arduino\\libraries" location=user
2023-04-02T10:21:07.698Z daemon INFO INFO[0019] Loading hardware from: c:\Users\john_4bbk5we\AppData\Local\Arduino15\packages
2023-04-02T10:21:07.701Z daemon INFO INFO[0019] Loading package arduino from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\hardware
2023-04-02T10:21:07.705Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
2023-04-02T10:21:07.708Z daemon INFO INFO[0019] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0019] Loaded platform                               platform="arduino:avr@1.8.6"
2023-04-02T10:21:07.712Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json.sig"
2023-04-02T10:21:07.717Z daemon INFO INFO[0019] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0019] Loaded platform                               platform="arduino:samd@1.8.13"
2023-04-02T10:21:07.719Z daemon INFO INFO[0019] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\tools
INFO[0019] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\arduino\tools
INFO[0019] Loaded tool                                   tool="arduino:CMSIS@4.5.0"
INFO[0019] Loaded tool                                   tool="arduino:CMSIS-Atmel@1.2.0"
2023-04-02T10:21:07.722Z daemon INFO INFO[0019] Loaded tool                                   tool="arduino:arduinoOTA@1.2.1"
INFO[0019] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0019] Loaded tool                                   tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0019] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0019] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0019] Loaded tool                                   tool="arduino:bossac@1.7.0-arduino3"
INFO[0019] Loaded tool                                   tool="arduino:openocd@0.10.0-arduino7"
2023-04-02T10:21:07.722Z daemon INFO INFO[0019] Loading package builtin from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin
2023-04-02T10:21:07.724Z daemon INFO INFO[0019] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin\tools
2023-04-02T10:21:07.724Z daemon INFO INFO[0019] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\builtin\tools
2023-04-02T10:21:07.725Z daemon INFO INFO[0019] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
2023-04-02T10:21:07.726Z daemon INFO INFO[0019] Loaded tool                                   tool="builtin:mdns-discovery@1.0.6"
INFO[0019] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0019] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
2023-04-02T10:21:07.727Z daemon INFO INFO[0019] Loaded tool                                   tool="builtin:serial-discovery@1.3.2"
INFO[0019] Loaded tool                                   tool="builtin:serial-discovery@1.3.3"
INFO[0019] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0019] Loaded tool                                   tool="builtin:serial-monitor@0.10.0"
INFO[0019] Loaded tool                                   tool="builtin:serial-monitor@0.11.0"
2023-04-02T10:21:07.727Z daemon INFO INFO[0019] Loaded tool                                   tool="builtin:serial-monitor@0.12.0"
INFO[0019] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
2023-04-02T10:21:07.728Z daemon INFO INFO[0019] Loading package esp32 from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\hardware
2023-04-02T10:21:07.733Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\installed.json.sig"
2023-04-02T10:21:07.758Z daemon INFO INFO[0019] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0019] Loaded platform                               platform="esp32:esp32@1.0.6"
2023-04-02T10:21:07.759Z daemon INFO INFO[0019] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\tools
INFO[0019] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp32\tools
2023-04-02T10:21:07.762Z daemon INFO INFO[0019] Loaded tool                                   tool="esp32:esptool_py@3.0.0"
INFO[0019] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0019] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
INFO[0019] Loading package esp8266 from: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\hardware
2023-04-02T10:21:07.767Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json" signatureFile="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json.sig"
2023-04-02T10:21:07.802Z daemon INFO INFO[0019] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0019] Loaded platform                               platform="esp8266:esp8266@3.1.2"
2023-04-02T10:21:07.804Z daemon INFO INFO[0019] Checking existence of 'tools' path: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0019] Loading tools from dir: C:\Users\john_4bbk5we\AppData\Local\Arduino15\packages\esp8266\tools
2023-04-02T10:21:07.807Z daemon INFO INFO[0019] Loaded tool                                   tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
INFO[0019] Loaded tool                                   tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
INFO[0019] Loaded tool                                   tool="esp8266:python3@3.7.2-post1"
INFO[0019] Loaded tool                                   tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2023-04-02T10:21:07.815Z daemon INFO INFO[0019] Checking signature                            index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-04-02T10:21:07.820Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json.sig: The system cannot find the file specified." index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp8266com_index.json.sig"
2023-04-02T10:21:07.826Z daemon INFO INFO[0019] Checking signature                            error="opening signature file: open c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified." index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json" signatureFile="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig"
2023-04-02T10:21:09.617Z daemon INFO INFO[0021] Resolving include BluetoothSerial.h for arch esp32
2023-04-02T10:21:09.618Z daemon INFO INFO[0021]   found better lib                            lib=BluetoothSerial prio=64C
2023-04-02T10:21:10.601Z daemon INFO INFO[0022] Resolving include Freenove_WS2812_Lib_for_ESP32.h for arch esp32
INFO[0022]   found better lib                            lib="Freenove WS2812 Lib for ESP32" prio=64D
2023-04-02T10:21:15.517Z daemon INFO INFO[0027] Resolving include WiFi.h for arch esp32
INFO[0027]   found better lib                            lib=WiFi prio=64C
2023-04-02T10:21:17.643Z daemon INFO INFO[0029] Resolving include EEPROM.h for arch esp32
INFO[0029]   found better lib                            lib=EEPROM prio=64C
2023-04-02T10:21:31.737Z daemon INFO INFO[0043] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
2023-04-02T10:21:31.740Z daemon INFO INFO[0043] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
2023-04-02T10:21:31.743Z daemon INFO INFO[0043] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-04-02T10:21:31.748Z daemon INFO INFO[0043] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" location=platform
INFO[0043] Loading libraries index file                  index="c:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\library_index.json"
2023-04-02T10:21:31.886Z daemon INFO INFO[0043] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-04-02T10:21:31.954Z daemon INFO INFO[0043] Adding libraries dir                          dir="\\\\tenchiro-souko\\dev-souko\\Arduino\\libraries" location=user
2023-04-02T10:21:32.126Z daemon INFO INFO[0043] Required tool                                 tool="esp32:esptool_py@3.0.0"
INFO[0043] Required tool                                 tool="esp32:mkspiffs@0.2.3"
2023-04-02T10:21:32.126Z daemon INFO INFO[0043] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2023-04-02T10:21:44.102Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <\\tenchiro-souko\dev-souko\Arduino\mavlight_land\mavlight_land.ino>, response: <\\tenchiro-souko\dev-souko\Arduino\mavlight_land>.
2023-04-02T10:21:48.499Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 284.3 ms [Finished 3.740 s after frontend start]
2023-04-02T10:21:48.765Z root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 150.7 ms [Finished 4.055 s after frontend start]
2023-04-02T10:21:48.819Z root INFO Start frontend contributions: 757.2 ms [Finished 4.066 s after frontend start]
2023-04-02T10:21:48.819Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-04-02T10:21:48.963Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-04-02T10:21:48.965Z root INFO >>> Restoring the layout state...
2023-04-02T10:21:48.966Z root INFO <<< Nothing to restore.
2023-04-02T10:21:49.022Z root INFO Initialize the workbench layout: 44.9 ms [Finished 4.303 s after frontend start]
2023-04-02T10:21:49.048Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-04-02T10:21:49.065Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d] Waiting for backend deployment: 300.3 ms [Finished 4.358 s after frontend start]
2023-04-02T10:21:49.745Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008) starting instance
2023-04-02T10:21:50.439Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d] Sync of 21 plugins: 1331.8 ms [Finished 5.690 s after frontend start]
2023-04-02T10:21:50.447Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][marus25.cortex-debug]: Loaded contributions.
2023-04-02T10:21:50.447Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][arduino.vscode-arduino-tools]: Loaded contributions.
2023-04-02T10:21:50.451Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.cpp]: Loaded contributions.
2023-04-02T10:21:50.452Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.json]: Loaded contributions.
2023-04-02T10:21:50.453Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.json-language-features]: Loaded contributions.
2023-04-02T10:21:50.454Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-04-02T10:21:50.454Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-04-02T10:21:50.455Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-04-02T10:21:50.455Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-04-02T10:21:50.456Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-04-02T10:21:50.456Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-04-02T10:21:50.457Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-04-02T10:21:50.457Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-04-02T10:21:50.458Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-04-02T10:21:50.458Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-04-02T10:21:50.459Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-04-02T10:21:50.459Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-04-02T10:21:50.460Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-04-02T10:21:50.461Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-04-02T10:21:50.461Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-04-02T10:21:50.467Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-04-02T10:21:50.468Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d] Load contributions of 21 plugins: 42.6 ms [Finished 5.733 s after frontend start]
2023-04-02T10:21:51.247Z root INFO Replace loading indicator with ready workbench UI (animation): 1690.9 ms [Finished 6.008 s after frontend start]
2023-04-02T10:21:51.247Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-04-02T10:21:51.252Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-04-02T10:21:51.252Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-04-02T10:21:51.253Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-04-02T10:21:51.298Z root INFO Frontend application start: 2814.9 ms [Finished 64.411 s after backend start]
2023-04-02T10:21:51.448Z root INFO Executing startup tasks:
2023-04-02T10:21:51.449Z root INFO  - 'arduino-use-inherited-boards-config' , args: [{"selectedBoard":{"name":"WEMOS D1 MINI ESP32","fqbn":"esp32:esp32:d1_mini32"}}]
2023-04-02T10:21:53.650Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): PluginManagerExtImpl/init()
2023-04-02T10:21:53.657Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.671Z root INFO [hosted-plugin: 18008] Debugger contribution has been registered: cortex-debug
2023-04-02T10:21:53.676Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(vscode-arduino-tools@0.0.2-beta.7 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.678Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.681Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.683Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.684Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.687Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.706Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(18008): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-04-02T10:21:53.760Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-04-02T10:21:53.846Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][marus25.cortex-debug]: Started plugin.
2023-04-02T10:21:53.849Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][arduino.vscode-arduino-tools]: Started plugin.
2023-04-02T10:21:53.852Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.cpp]: Started plugin.
2023-04-02T10:21:53.852Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.json]: Started plugin.
2023-04-02T10:21:53.856Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][vscode.json-language-features]: Started plugin.
2023-04-02T10:21:53.857Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-04-02T10:21:53.857Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-04-02T10:21:53.858Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-04-02T10:21:53.859Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-04-02T10:21:53.860Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-04-02T10:21:53.860Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-04-02T10:21:53.861Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-04-02T10:21:53.862Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-04-02T10:21:53.862Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-04-02T10:21:53.863Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-04-02T10:21:53.864Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-04-02T10:21:53.865Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-04-02T10:21:53.869Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-04-02T10:21:53.877Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-04-02T10:21:53.879Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-04-02T10:21:53.879Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-04-02T10:21:53.930Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-04-02T10:21:54.017Z root INFO [hosted-plugin: 18008] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-04-02T10:21:54.028Z root INFO [hosted-plugin: 18008] GDB server console created
2023-04-02T10:21:54.052Z root INFO [5146d5ed-aefd-4b90-9379-e0d35f24316d] Start of 21 plugins: 3584.2 ms [Finished 9.342 s after frontend start]
2023-04-02T10:21:54.116Z root INFO Starting language server: esp32:esp32:d1_mini32:FlashFreq=80,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600
2023-04-02T10:21:54.127Z root INFO [hosted-plugin: 18008] PLUGIN_HOST(18008): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-04-02T10:21:54.671Z daemon INFO INFO[0066] Required tool                                 tool="esp32:esptool_py@3.0.0"
INFO[0066] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0066] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2023-04-02T10:21:54.672Z daemon INFO INFO[0066] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0066] Adding libraries dir                          dir="C:\\Users\\john_4bbk5we\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" location=platform
2023-04-02T10:21:54.708Z daemon INFO INFO[0066] Adding libraries dir                          dir="\\\\tenchiro-souko\\dev-souko\\Arduino\\libraries" location=user
2023-04-02T10:21:59.053Z daemon INFO INFO[0070] Required tool                                 tool="esp32:esptool_py@3.0.0"
INFO[0070] Required tool                                 tool="esp32:mkspiffs@0.2.3"
2023-04-02T10:21:59.054Z daemon INFO INFO[0070] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
Thank you for your response and request for more information. I have provided above.
The problem is caused by the sketch being under a UNC path. There is a known bug that causes the IDE to fail to open sketches from these paths:
You already found the workaround of moving the sketch to a different location that is not under a UNC path. Alternatively, if you would like to continue to open sketches from the network share, you can map it to a drive on your computer. Then make sure to open the sketches from that drive instead of from the network location:
Thank you very much @ptillisch for taking the time to provide this evaluation. And for the link to mapping network drives. Very helpful. (It's curious it actually worked for a while.) But I will try this mapping. Yes, the local files are working, and I've been able to continue my work for now, but I'd like to get the files back on the server where they belong. So thank you, that is helpful. Kind regards.
You are welcome. I'm glad if I was able to be of assistance.
That is indeed interesting. If you ever find what changed, please let us know (either here or on the GitHub issue) as that information might help the developers in their investigation.
I know that there are reports that some of the ways of opening sketches do work, while others don't. For example:
So maybe you changed the way you open the sketch (e.g., file association, File > Sketchbook menu, "SKETCHBOOK" view)?
