Hello,
I recently wanted to update the firmware on my ender 3 pro using an Arduino, but I have run into an error. I installed the Sanguino boards library (Using this URL:
https://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json
) and now the Arduino IDE won't start. I ran the debug file and took a screenshot. Here it is:
Why?
Hi @charleychap . It looks like you might have made a typo when adding the URL:
charleychap:
unknown protocol: tps
So I think the URL you added looked something like:
Instead of starting with https:// as intended.
To fix the problem, you can open this file in a text editor:
C:\Users\Boing\AppData\Local\Arduino15\preferences.txt
ⓘ If looking for it with your file browser or command line, note that the C:\Users\Boing\AppData folder is hidden by default. On Windows "File Explorer ", you can make it visible by opening the "View " menu, then checking the box next to "☐ Hidden items ".
You will see a line in the file that looks something like this:
boardsmanager.additional.urls=tps://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json
Correct the error in the file. So it looks something like this:
boardsmanager.additional.urls=https://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json
Save the file in the text editor.
Now try starting the IDE again.
Thanks! I would have never been able to figure that out.
You are welcome. I'm glad if I was able to be of assistance.
Regards, Per
system
Closed
January 9, 2023, 10:16am
5
