Arduino IDE
Hello,
I am using the ultimate starter's kit for Arduino UNO R3 and currently working on circuit #2 (potentiometer). I finished wiring the circuit and the next step is to go to the Arduino IDE, click on File>Examples>USK Guide>Circuit #2. I opened the IDE, went to File>Examples, but there was nothing called USK Guide so I am stuck. Can somebody help me with this issue?
Thanks.
You have to add it to your arduino Ide GitHub - christiangenco/uskcode: Vilrus Ultimate Starter Kit (USK) Arduino Code
You download them this is no2
// Welcome back! In this sketch we'll start using "variables".
// A variable is a named number. We'll often use these to store
// numbers that change, such as measurements from the outside
// world, or to make a sketch easier to understand (sometimes a
// descriptive name makes more sense than looking at a number).
// Variables can be different "data types", which is the kind of
// number we're using (can it be negative? Have a decimal point?)
// We'll introduce more data types later, but for the moment we'll
// stick with good old "integers" (called "int" in your sketch).
// Integers are whole numbers (0, 3, 5643), can be negative, and
// for reasons we won't go into right now, can range from -32768
// to 32767. (Don't worry, if you need to work with larger numbers,
// there are other data types for that. See:
// http://arduino.cc/en/Reference/VariableDeclaration
// for a list of all the data types you can use).
// You must "declare" variables before you use them, so that the
// computer knows about them. Here we'll declare two integer
// variables, and at the same time, initialize them to specific
// values. We're doing this so that further down, we can refer to
// the pins by name rather than number.
// Note that variable names are case-sensitive! If you get an
// "(variable) was not declared in this scope" error, double-check
// that you typed the name correctly.
// Here we're creating a variable called "sensorPin" of type "int"
// and initializing it to have the value "0":
int sensorPin = 0;    // The potentiometer is connected to
                      // analog pin 0
int ledPin = 13;      // The LED is connected to digital pin 13
// One more thing. If you declare variables outside of a function,
// as we have here, they are called "global variables" and can be
// seen by all the functions. If you declare variables within a
// function, they can only be seen within that function. It's good
// practice to "limit the scope" of a variable whenever possible,
// but as we're getting started, global variables are just fine.
void setup() // this function runs once when the sketch starts up
  // We'll be using pin 13 to light a LED, so we must configure it
  // as an output.
  // Because we already created a variable called ledPin, and
  // set it equal to 13, we can use "ledPin" in place of "13".
  // This makes the sketch easier to follow.
  pinMode(ledPin, OUTPUT);
  // The above line is the same as "pinMode(13, OUTPUT);"
  // You might be wondering why we're not also configuring
  // sensorPin as an input. The reason is that this is an
  // "analog in" pin. These pins have the special ability to
  // read varying voltages from sensors like the potentiometer.
  // Since they're always used as inputs, there is no need to
  // specifically configure them.
void loop() // this function runs repeatedly after setup() finishes
  // First we'll declare another integer variable
  // to store the value of the potentiometer:
  int sensorValue;
  // The potentiometer is set up as a voltage divider, so that
  // when you turn it, the voltage on the center pin will vary
  // from 0V to 5V. We've connected the center pin on the
  // potentiometer to the Arduino's analog input 0.
  // The Arduino can read external voltages on the analog input
  // pins using a built-in function called analogRead(). This
  // function takes one input value, the analog pin we're using
  // (sensorPin, which we earlier set to 0). It returns an integer
  // number that ranges from 0 (0 Volts) to 1023 (5 Volts).
  // We're sticking this value into the sensorValue variable:
  sensorValue = analogRead(sensorPin);
  // Now we'll blink the LED like in the first example, but we'll
  // use the sensorValue variable to change the blink speed
  // (the smaller the number, the faster it will blink).
  // Note that we're using the ledPin variable here as well:
  digitalWrite(ledPin, HIGH);     // Turn the LED on
  delay(sensorValue);             // Pause for sensorValue
                                  // milliseconds
  digitalWrite(ledPin, LOW);      // Turn the LED off
                                  // milliseconds
  // Remember that loop() repeats forever, so we'll do all this
  // again and again.
