Arduino IFTTT Webhook Value Update
I will preface that I am a noobie. I have my arduino wifi rev2 connecting successfully with my wifi and I am able to get events sent to my email via IFTTT webhooks, but I am having trouble figuring out how to get a value based on a variable sent to myself rather than text. If you see in the code below, where I commented beside, I can send that text to my email, but I want it to be a variable based on a sensor I have.
I realize it says String, which I think may be a problem, but I'm unsure how to write it to send the variable either :\ TIA
void send_event(const char *event)
    Serial.print("Connection to ");
    Serial.println(IFTTT_HOST);
    WiFiClient client;
    const int httpPort = 80;
    if(!client.connect(IFTTT_HOST, httpPort))
        Serial.print("Connection failed");
        return;
    String url = "/trigger/";
    url += event;
    url += "/with/key/";
    url += IFTTT_KEY;
    String mJson = String("{\"value1\":\"") + "I want a variable here instead\" }"; // ISSUE IS RIGHT HERE
    Serial.print("Requesting URL: ");
    Serial.println(url);
    client.println(String("POST ") + url + " HTTP/1.1");
    client.println(String("Host: ") + IFTTT_HOST);
    client.println("Content-Type: application/json");
    client.print("Content-Length: ");
    client.println(mJson.length());
    client.println();
    client.println(mJson);
    while(client.connected())
        if(client.available())
            String line = client.readStringUntil('\r');
            Serial.print(line);
          }else{delay(50);};
    Serial.println("closing connection");
    client.stop();
Do you mean something like this?
float f = 123.45;
String mJson = String("{ \"value1\": \"") + f + "\" }";
Serial.println(mJson);
Result:
{ "value1": "123.45" }
[edit]
You can leave out the second pair of quotes when you want to put a number in the JSON object instead of a string.
