Arduino IGC logger too much ram and rom used
Hello, I made a code that is not finished yet, but its main purpose is to log GPS data to SD with IGC format. The problem is that I was hopping to add many more functionalities to it, but it’s already taking almost all the memory the Nano has. I wonder where is my mistake, and how can I reduce the memory usage.
//Libraries
#include <SoftwareSerial.h>
#include <TinyGPS++.h>             //http://arduiniana.org/libraries/tinygpsplus/
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Arduino.h>  //"Arduino.h" for eepromex?
#include <U8x8lib.h>  //text only for OLED
#include <EEPROMex.h>              //https://github.com/thijse/Arduino-EEPROMEx
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
//Initializations
TinyGPSPlus gps;
SoftwareSerial ss(4, 3);           // GPS  RXpin,TXpin
Adafruit_BME280 bme;            // Hey BME
U8X8_SH1106_128X64_NONAME_4W_HW_SPI u8x8(/* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); //MOSI 11 SCK 13 OLED stufff
//functions
void Error();
void UpdateGps();
void LogIGC();
//Declarations
#define SEALEVELPRESSURE_HPA (1013.25)
#define chipSelect 7 //SD module CS to Pin 7,MOSI-pin 11,MISO-pin 12,CLK - pin 13;
#define ErrorLed A0
#define Button0Pin 8
#define Button1Pin 5
#define Button2Pin 6
#define interval 1000
boolean StartLoging = true;
byte LoggerPeriod = 2;//(1s to 5s);
unsigned long previousMillis = 0;                         //B185209 2302718S 04546811W  A-0056 00 583
String IGCdata = "B1852092302718S04546811WA-005600583";                                           // UTC      Lat     Long     QFEbaro // GpsH
long Lat;
long Long;
int GpsAlt;
int BarAlt;
  pinMode(ErrorLed, OUTPUT);
  pinMode(Button0Pin, INPUT_PULLUP);
  pinMode(Button1Pin, INPUT_PULLUP);
  pinMode(Button2Pin, INPUT_PULLUP);
  bme.begin();
  //display stuff not here yet .................
  if (!SD.begin(chipSelect)) {
    while (digitalRead(Button1Pin) == HIGH) {     // press button to ignore SD error
      Error();        //Check SD and indicate status with LED,it should also show SD error on display
  //Tell here SD is fine or has been ignored
  ss.begin(4800);    //GPS receiver serial baudrate
  Serial.begin(115200);  //Serial for debugging
}//end of setup
  UpdateGps();
  if (millis() - previousMillis >= (interval * LoggerPeriod) && StartLoging == true ) {
    LogIGC();
}//end of loop
void LogIGC() {
  previousMillis = millis();
  ///////////////////////////Handle GPS time/////////////////////////////
  IGCdata = "";        //Clears string then starts building a new
  IGCdata += "B";
  if (gps.time.hour() > 9) {
    IGCdata += gps.time.value();
    IGCdata.remove(7, 2);        //removes 00 after seconds.
  else {
    IGCdata += "0";                   //add the 00 if hour Z is 9, 8, 7...
  ///////////////////////////Handle latitude///////////////////////////////
  Lat = (gps.location.lat() * 100000); //remove decimal point from float
  if (Lat >= 0) {              // if NORTH
    if (Lat < 1000000) {
      IGCdata += "0";
      IGCdata += Lat;
    else {                    // if more than 9 degrees
      IGCdata += Lat;
    IGCdata += "N";
  else {                       // if SOUTH
    if (Lat > -1000000) {
      IGCdata += "0";
      IGCdata += Lat;
      IGCdata.remove(8, 1);    //remove minus for IGC
    else {                     //if less than -9 degrees
      IGCdata += Lat;
      IGCdata.remove(7, 1);     //remove minus for IGC
    IGCdata += "S";
  ///////////////////////////Handle longitude/////////////////////////////
  Long = (gps.location.lng() * 100000); //remove decimal point from float
  if (Long >= 0) {            //if EAST
    if (Long < 1000000) {     //if less than 9 degrees
      IGCdata += "00";
      IGCdata += Long;
    else if (Long >= 1000000 && Long < 10000000) {  //if less than 100 degrees & more than 9
      IGCdata += "0";
      IGCdata += Long;
    else {                   // if more than 99 degrees
      IGCdata += Long;
    IGCdata += "E";
  else {                       //if WEST
    if (Long > -1000000) {     //if more than -10 degrees
      IGCdata += "00";
      IGCdata += Long;
      IGCdata.remove(17, 1);
    else if (Long <= -1000000 && Long > -10000000) {  //if more than -100 degrees & less than -9
      IGCdata += "0";
      IGCdata += Long;
      IGCdata.remove(16, 1);
    else {                   // if less than -99 degrees
      IGCdata += Long;
      IGCdata.remove(15, 1);
    IGCdata += "W";
  ///////////////////////////Handle altimetry////////////////////////////////
  IGCdata += "A";
  BarAlt = (bme.readAltitude(SEALEVELPRESSURE_HPA));
  if (BarAlt < 10000 && BarAlt > 1000 ) {
    IGCdata += "0";
    IGCdata += BarAlt;
  else if (BarAlt < 1000 && BarAlt > 99) {
    IGCdata += "00";
    IGCdata += BarAlt;
  else if (BarAlt < 100 && BarAlt > 9) {
    IGCdata += "000";
    IGCdata += BarAlt;
  else if (BarAlt < 10 && BarAlt > -1) {
    IGCdata += "0000";
    IGCdata += BarAlt;
  else if (BarAlt < 0 && BarAlt > -10 ) {
    IGCdata += "-000";
    IGCdata += BarAlt;
    IGCdata.remove(29, 1);
  else if (BarAlt > -100 && BarAlt < -9) {
    IGCdata += "-00";
    IGCdata += BarAlt;
    IGCdata.remove(28, 1);
  else if (BarAlt > -1000 && BarAlt < -99) {
    IGCdata += "-0";
    IGCdata += BarAlt;
    IGCdata.remove(27, 1);
  GpsAlt = ((gps.altitude.meters() - 0));  // calibrate gps altitude error here
  if (GpsAlt < 10000 && GpsAlt > 1000 ) {
    IGCdata += "0";
    IGCdata += GpsAlt;
  else if (GpsAlt < 1000 && GpsAlt > 99) {
    IGCdata += "00";
    IGCdata += GpsAlt;
  else if (GpsAlt < 100 && GpsAlt > 9) {
    IGCdata += "000";
    IGCdata += GpsAlt;
  else if (GpsAlt < 10 && GpsAlt > -1) {
    IGCdata += "0000";
    IGCdata += GpsAlt;
  else if (GpsAlt < 0 && GpsAlt > -10 ) {
    IGCdata += "-000";
    IGCdata += GpsAlt;
    IGCdata.remove(34, 1);
  else if (GpsAlt > -100 && GpsAlt < -9) {
    IGCdata += "-00";
    IGCdata += GpsAlt;
    IGCdata.remove(33, 1);
  else if (GpsAlt > -1000 && GpsAlt < -99) {   // Lowest place on earth is about - 450m
    IGCdata += "-0";
    IGCdata += GpsAlt;
    IGCdata.remove(32, 1);
  File dataFile = SD.open("log.igc", FILE_WRITE);
  if (dataFile) {
    dataFile.println"";
    dataFile.println(IGCdata);
    dataFile.close();
  // print to the serial port for debbuging
  Serial.println(IGCdata);
void UpdateGps() {
  while (ss.available() > 0) {
    gps.encode(ss.read());
void Error() {
  digitalWrite(ErrorLed, HIGH);
  delay(80);                      //Here only to be used before code starts
  digitalWrite(ErrorLed, LOW);
  delay(80);
Maybe a library is using lots of memory? Or just my String… I don’t know.
Sketch uses 28010 bytes (86%) of program storage space. Maximum is 32256 bytes.
Global variables use 1734 bytes (84%) of dynamic memory, leaving 314 bytes for local variables. Maximum is 2048 bytes.
AFAIR the SD card uses a large buffer array. With the few RAM bytes left it's unlikely that any String handling will succeed. You better use a bigger Arduino, with more memory. And try to avoid the String class on Arduinos.
Get rid of the big-S String. Just print each item to the file directly.
86% memory usage is no big deal, so long as you know you aren't using lots of dynamic memory with Strings.
It didn’t work at first, but then I declared a dumb equivalent string in order to allocate the memory and it succeeded after that.
I can’t use a bigger Arduino otherwise it will be too big for my purpose.
About writing directly to sd that would mean having more smaller strings wouldn’t it? Because I need to manipulate the variables in a way that they are always written with the same number of characters due to the IGC format, thus having to remove “-” and add 00 to the left sometimes.
A Teensy 3.2 is physically smaller than a Nano and it has a lot more memory.
For writing leading zeroes, use something like…
  if(value<100) datafile.print("0");
  if(value<10) datafile.print("0");
  datafile.print(value);
I am trying to switch to an stm32 but after loading the usb bootloader it seems like it stopped working.
IDE gives me this error when trying to upload via usb:
maple_loader v0.1
Resetting to bootloader via DTR pulse
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=12076, tid=7356
JRE version: Java(TM) SE Runtime Environment (9.0+11) (build 9.0.4+11)
Java VM: Java HotSpot(TM) 64-Bit Server VM (9.0.4+11, mixed mode, tiered, compressed oops, g1 gc, windows-amd64)
Problematic frame:
C [jSSC-2.8_x86_64.dll+0xb5db]
No core dump will be written. Minidumps are not enabled by default on client versions of Windows
An error report file with more information is saved as:
C:\Users\Caio\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2018.7.2\win\hs_err_pid12076.log
If you would like to submit a bug report, please visit:
Crash Report
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
I did everything correctly...
I gave up on the STM, but found this: https://robotdyn.com/mega-2560-pro-embed-ch340g-atmega2560-16au.html That's a great Mini arduino mega 2560 board. It will do the job I need.
