Arduino ignition but rpm count not stable
A few days ago, I try arduino calculate rpm and delayed ignition in the event dwell 10 us it's normal, but I increased dwell = 1500 us it has not stabilized, I use the hall effect the sensor, use a fan to simulate the rotation of the engin and flash. light simulation timing light
I might improve it to make it stable. Please help me
This is my code
#include <Wire.h>
 LiquidCrystal_I2C lcd(0x27, 16, 2);
const byte flash = 11;
int coilOut = 7; //Coil output on pin 7
int led = 13; //arduino led
int trigger = 3;
volatile byte rpmcount;
unsigned long rpm;
unsigned long timeold;
volatile int advance = 0; //testing stuff
int degree;
//** 800,850,900,950,1000,1050,1100,1150,1200,1250**\\
int delay_1[9]={8333,7843,7407,6666,6349,6060,5797,5555,5333};
pinMode(trigger,INPUT);
attachInterrupt(0, rpm_cal, FALLING);
pinMode(coilOut, OUTPUT); //Coil output
Serial.begin(9600); //Initialize serial port
lcd.begin();
pinMode(flash, OUTPUT);
    rpmcount = 0;
    Serial.println(rpm,DEC);
    //Serial.println(advance,DEC);
    //Serial.println(" RPM");
    lcd_show();
    speed_fan();
void lcd_show()
  lcd.setCursor(0,0);
  lcd.print(rpm);
  lcd.setCursor(5, 0);
  lcd.print("RPM");
  lcd.setCursor(9, 0);
  lcd.print(advance);
  lcd.setCursor(11, 0);
  //lcd.print(" deg");
  lcd.clear();
   // Clear LCD
    unsigned long last_t;
    if (rpm < 150)
      if (millis()-last_t >= 50000ul)
      rpm = 0; advance = 0;
     last_t = millis();
void rpm_cal() //Interrupt routine run when tach pulse goes high
   if (rpm <= 1200) // LOW RPM
  table();
   if (rpm >= 1250  ) // HIGH RPM
   advance = map(rpm,1250,2400,5333,100) ;
     if (advance < 76 )
       advance = 76;
  delayMicroseconds(advance);
  digitalWrite (coilOut, HIGH); //Charge coil
  delayMicroseconds(1500);
  digitalWrite (coilOut, LOW);
  rpm = (60000000ul)/(micros() - timeold);
  timeold = micros(); //save current since-on microseconds
  rpmcount++;
void speed_fan()
  const byte POTENTIOMETER = 0;
  int reading;
  int value;
  reading = analogRead(POTENTIOMETER);
  value = map(reading, 0, 1024, 0, 255);
  analogWrite(flash, value);
void table() // map advance  for low rpm
  if (rpm <= 800)
    advance = delay_1[0];
   if (rpm > 800 && rpm <= 850 )
    advance = delay_1[1];
   if (rpm > 850 && rpm <= 900 )
    advance = delay_1[2];
   if (rpm > 900 && rpm <= 950 )
    advance = delay_1[3];
   if (rpm > 950 && rpm <= 1000 )
    advance = delay_1[4];
   if (rpm > 1000 && rpm <= 1050 )
    advance = delay_1[5];
  if (rpm > 1050 && rpm <= 1100 )
    advance = delay_1[6];
  if (rpm > 1100 && rpm <= 1150 )
    advance = delay_1[7];
  if (rpm > 1150 && rpm <= 1200 )
    advance = delay_1[8];
  if (rpm > 1200 && rpm <= 1250 )
    advance = delay_1[9];
Thank you.
