I hope someone can help me out here.... this has ruined my day. So close but something aint right... ![]()
I have been trying to get this to work:
Everything seems to be as it should but my Arduino doesn't seem to receive the 0's and 1's sent from Flash.
What works:
My flash file runs and serproxy displays "Server thread launched" and "server(7) - thread started"
I did a little idiot testing and found that this failed if the Arduino wasn't connected or if I changed the settings in the serproxy config file, so it seems to be connected.
My flash trace statements show up when I push and release the button, proving that the functions are being called.
Another thing I have done to test my Arduino is OK is to not use serproxy, changed my "if(incoming == 0)" to "if(incoming == 50)" and used the serial monitor to send keystrokes... the LED will switch off if I send it "2" and on if I send it anything else....
So that leads me to think that the all important 0's and 1's aren't getting from Flash to the Arduino and are being squished by the proxy somehow.
Here's my code:
AS3
package
import flash.display.Sprite;
import com.greensock.*;
import flash.net.Socket;
import flash.events.Event;
import flash.events.ProgressEvent;
import flash.events.MouseEvent;
public class myArduinoFlash extends Sprite
public var test
public static const PORT:Number = 5337;
public static const LOCALHOST:String = "127.0.0.1";
private var socket:Socket = null;
public function myArduinoFlash()
trace ("myArduinoFlash is Running!");
super();
init();
private function init():void
socket = new Socket();
socket.addEventListener(Event.CONNECT, doSocketConnect);
socket.addEventListener(Event.CLOSE, doSocketClose);
socket.connect(LOCALHOST, PORT);
protected function doArcadeDown(event:MouseEvent):void
{ trace ("doArcadeDown");
socket.writeInt( 1 );
trace("down");
protected function doArcadeUp(event:MouseEvent):void
{ trace ("doArcadeUp");
socket.writeInt( 0 );
trace("up");
protected function doSocketConnect(event:Event):void
trace ("doSocketConnect");
btnarcade.addEventListener(MouseEvent.MOUSE_DOWN, doArcadeDown);
btnarcade.addEventListener(MouseEvent.MOUSE_UP, doArcadeUp);
protected function doSocketClose(event:Event):void
{ trace ("doSocketClose");
btnarcade.removeEventListener(MouseEvent.MOUSE_DOWN, doArcadeDown);
btnarcade.removeEventListener(MouseEvent.MOUSE_UP, doArcadeUp);
serproxy.cfg
# Config file for serproxy
# See serproxy's README file for documentation
# Transform newlines coming from the serial port into nils
# true (e.g. if using Flash) or false
newlines_to_nils=true
# on a mac you will need to add this
#serial_device1=/dev/tty.usbserial-A6004osh
# Comm ports used
#comm_ports=1,2,3,4,5,6,7
comm_ports=7
# Default settings
comm_baud=9600
comm_databits=8
comm_stopbits=1
comm_parity=none
# Idle time out in seconds
timeout=300
# Port 1 settings (ttyS0)
net_port1=5331
# Port 2 settings (ttyS1)
net_port2=5332
# Port 3 settings (ttyS2)
net_port3=5333
# Port 4 settings (ttyS3)
net_port4=5334
# Port 7 settings (ttyS6)
net_port7=5337
Arduino
int ledPin = 13;
Serial.begin( 9600 );
pinMode(ledPin, OUTPUT);
int incoming = 0;
if( Serial.available() > 0)
incoming = Serial.read();
Serial.print("I received: "); // used for testing in Serial Monitor
Serial.println(incoming, DEC);
if(incoming == 0)
digitalWrite(ledPin, LOW); // set the LED off
digitalWrite(ledPin, HIGH); // set the LED on
Serial.println(incoming);
delay(200); // wait for a second
I am a bit of a noob so I wouldn't be surprised if it was something obvious..... but after 7 hours, I have given up.
Any ideas?
Thanks.
TDG.
