Arduino in Linux can't find .h file in sketch folder
I know this question has been asked before but I didn't see my particular case. The IDE is able to find it if I include the full path to the header. Without the full path, you can hover over the #include statement and see that it is looking for the header in /tmp/arduino-language-server3357825155/sketch/myheaderfiler.h. Any suggestions on how to fix it without including the full path?
Welcome to the forum
Please post a sketch that illustrates the problem
#include <myHeader.h> will look for the .h file in the standard locations
#include "myHeader.h" will look for the .h file in the sketch folder first then the standard locations. You can also use a relative path in the quote marks
Which version are you using ?
Version 2.2.1 running on Linux mint 21.2 Cinnamon. The sketch is very basic and seems somewhat irrelevant.
3f313622eb5c55637b21b515a2a0ae9f9a3815d4
It goes away when I type the full path,
#include </home/david/Arduino/XIAO_RP2040/arduino_secrets.h>
try
#include "arduino_secrets.h"
do not use the angle brackets < > for local files
That's strange, I was sure I already tried that but I guess not.
No pictures of code, please
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
The picture was to illustrate the popup message, not the code, so I cropped it out:). I did use code tags for the include statement. I'm still unsure why it seems to be looking in that folder. Oh well. I do appreciate you answering the question. I'm unsure why these forums are so worried about procedure. They will probably all get replaced by AI soon anyway :frowning: I'm not sure if I would rather get beat up by code or a real person:):slight_smile: The stack overflow guys can be harsh.
