Arduino Infrared (IR) and Radio libraries timer conflict
We use two Uno's:
Board1 = Radio(sender+receiver) + IR(sender)
Board2 = Radio(sender+receiver) + IR(receiver)
Both libraries (IRremote and RH_ASK) use timers to send/receive. Initially they used the same timer - so sketches obviously didn't upload. Then we customized libraries to force them to use different timers - that solved upload failures, but invoked the following new issue:
Radio Driver (RH_ASK) requires init() function to prepare itself and start working.
When we do init() on Board1 (it has IR sender), and then send IR signal - is sends wrong IR data. If we do not init() Radio - IR sends correct data all right.
Board2 (with IR receiver) receives IR data correct - regardless of Radio driver on Board2 being inited or not inited.
If this is unsolvable - let it be :slight_smile: but any idea is welcome.
  • all used libraries and libraries with customized TIMERs can be found in attachment
IRremote_TIMER1.zip (13.4 KB)
IRremote_TIMER2.zip (13.4 KB)
RadioHead.zip (9.22 KB)
RH_ASK.zip (12.2 KB)
RH_ASK_TIMER1.zip (12.2 KB)
RH_ASK_TIMER2.zip (12.2 KB)
RHGenericDriver.zip (4.64 KB)
wiring.zip (1.97 KB)
Most likely a conflict with the timers of both libraries. IRremote uses timers to receive signals & send(PWM).
Why not try IRLib, it is a lot more configurable out of the box & good documentation.
Sorry, not feeling up to looking thru so much code.
