I have a panasonic remote here, and the power button seems to output 2 sets of data, but the problem is, I don't understand what its doing. The values seem to change each time I press the button :o
This is the code I am using:
// 0.1 by pmalmsten http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176098434
// 0.2 by farkinga
// 0.3 by farkinga - adds cool behaviors
#define IR_BIT_LENGTH 12 // number of bits sent by IR remote
#define BIT_1 1000 // Binary 1 threshold (Microseconds)
#define BIT_0 400 // Binary 0 threshold (Microseconds)
#define BIT_START 2000 // Start bit threshold (Microseconds)
#define IR_PIN 7 // Sensor pin 1 wired through a 220 ohm resistor
#define LED_PIN 10 // first LED output
#define POWER_PIN 11 // second LED output, corresponds to power button
#define DEBUG 1 // Serial connection must be started to debug
int runtime_debug = 0; // flag to output raw IR pulse data
int output_key = 0; // flag to print decoded key integers
int power_button = 0; // flag to indicate if power LED is on
int power_level = 128; // value (0-255) for power LED intensity
pinMode(LED_PIN, OUTPUT); //This shows when we're ready to recieve
pinMode(POWER_PIN, OUTPUT); //This is the "power on" indicator
pinMode(IR_PIN, INPUT);
digitalWrite(LED_PIN, LOW);
digitalWrite(LED_PIN, HIGH);
int key = get_ir_key();
digitalWrite(LED_PIN, LOW); // turn LED off while processing response
do_response(key);
delay(100); // short delay to cancel duplicate keypresses
wait for a keypress from the IR remote, and return the
integer mapping of that key (e.g. power button on remote returns
the integer 1429)
int get_ir_key()
int pulse[IR_BIT_LENGTH];
int bits[IR_BIT_LENGTH];
do {} //Wait for a start bit
while(pulseIn(IR_PIN, LOW) < BIT_START);
read_pulse(pulse, IR_BIT_LENGTH);
pulse_to_bits(pulse, bits, IR_BIT_LENGTH);
return bits_to_int(bits, IR_BIT_LENGTH);
respond to specific remote-control keys with different behaviors
void do_response(int key)
switch (key)
case 1437: // record button
Serial.println("toggle debug pulse");
runtime_debug = 1 - runtime_debug;
case 1498: // display button
Serial.println("Toggle key output");
output_key = 1 - output_key;
case 1429: // power button
Serial.println("Power");
power_button = 1 - power_button;
set_power();
case 1424: // channel up button
Serial.println("Channel Up");
case 1425: // channel down button
Serial.println("Channel Down");
case 3342: // up rocker/pause
power_level+=1;
set_power();
case 3343: // down rocker/stop
power_level-=1;
set_power();
case 3344: // left rocker/rewind
if (power_level < 50)
power_level-=3;
power_level-=10;
set_power();
case 3345: // right rocker/fast forward
power_level+=3;
power_level+=10;
set_power();
case 3352: // play button
blip_power();
default:
if (output_key)
Serial.print("Key ");
Serial.print(key);
Serial.println(" not programmed");
use pulseIn to receive IR pulses from the remote.
Record the length of these pulses (in ms) in an array
void read_pulse(int pulse[], int num_bits)
for (int i = 0; i < num_bits; i++)
pulse[i] = pulseIn(IR_PIN, LOW);
IR pulses encode binary "0" as a short pulse, and binary "1"
as a long pulse. Given an array containing pulse lengths,
convert this to an array containing binary values
void pulse_to_bits(int pulse[], int bits[], int num_bits)
if (DEBUG || runtime_debug) { Serial.println("-----"); }
for(int i = 0; i < num_bits ; i++)
if (DEBUG || runtime_debug) { Serial.println(pulse[i]); }
if(pulse[i] > BIT_1) //is it a 1?
bits[i] = 1;
else if(pulse[i] > BIT_0) //is it a 0?
bits[i] = 0;
else //data is invalid...
Serial.println("Error");
convert an array of binary values to a single base-10 integer
int bits_to_int(int bits[], int num_bits)
int result = 0;
int seed = 1;
//Convert bits to integer
for(int i = 0 ; i < num_bits ; i++)
if(bits[i] == 1)
result += seed;
seed *= 2;
return result;
set the brightness of the "power LED" depending on the power_level
variable.
void set_power()
power_level = constrain(power_level, 0, 200);
analogWrite(POWER_PIN, power_level * power_button);
// if the power level is above the max or below the min...
if ((power_level == 200) || (power_level == 0))
blink_led();
make LED blink rapidly
void blink_led()
for (int i = 0; i < 5; i++)
analogWrite(LED_PIN, 0);
delay(50);
analogWrite(LED_PIN, 1);
delay(50);
neat little routine to fade both LEDs in a sequence. Currently,
this is called by do_response() when the "play" button is pressed.
void blip_power()
int max_val = 100;
for (int i = 0; i < max_val; i++)
analogWrite(POWER_PIN, max_val-i);
analogWrite(LED_PIN, i);
delay(15);
for (int i = max_val; i >= 0; i--)
delay(15);
set_power();
And I get a few different results from the power button on my remote:
543
544
541
537
537
537
543
543
544
543
538
537
544
544
538
538
538
544
544
544
538
537
538
538
538
538
539
544
543
544
538
537
538
538
544
544
538
538
545
544
538
538
538
538
545
544
544
538
Any idea's how I can make it work with my remote?
Thanks ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
