arduino input pin to another arduino output pin via bt
hi guys and gals this is my first question ever on any forum little nervous i will get blasted off
i am having trouble with my project i would like to get two arduinos to talk via bt i got that to work tho just with serialprint i want to control without a pc in other simple words
high input on a pin #6 on mega(A) corresponds to a high output on pin#6 mega(B) via bluetooth
with no pc connection
please any help will be greatly appreciated
this is a arduino pairing challenge! :slight_smile:
if you are using HC05/06 modules for bt comms there are some example out there... just google pairing 2 arduinos via bt.
here's one link:
http://www.martyncurrey.com/connecting-2-arduinos-by-bluetooth-using-a-hc-05-and-a-hc-06-pair-bind-and-link/
sherzaad:
here's one link:
Connecting 2 Arduinos by Bluetooth using a HC-05 and a HC-06: Pair, Bind, and Link | Martyn Currey
Hi thank you for your response I appreciate it the Bluetooth pairing I found online and I got two hco5 modules to pair and bind together that was the easy part I just don't know what code to put to allow me to input a logic level high on one Arduino and it transfers that information as an output on the other Arduino as a logic level high all you find on the internet and on these sites is mostly how to serial print and not actually transmit a control a high logic level or a low logic level output or an input from one board to the next via Bluetooth
monza:
With bluetooth connections you can send what ever data uou like and in what ever format you like.
So if you want to send the state of a digital pin to the other arduino via bluetooth serial then you could just send a string, e.g. "6HIGH" (pin size is high).
Does that answer your question......was not entirely clear on what you were asking.
