I am trying to integrate the vesc with arduino and I am running a simple code to print the voltage and other data into the serial monitor. Below is the code for reference. When I check the output, it doesnt seem to be failing all the time. I am using the the library by solidgeek: SolidGeek/VescUart: An Arduino library for interfacing with the VESC over UART (github.com)
and here is the code I have on it:
Created: 19-08-2018
Author: SolidGeek
Description: This example is made using a Arduino Micro (Atmega32u4) that has a HardwareSerial port (Serial1) separated from the Serial port.
A Arduino Nano or Uno that only has one Serial port will not be able to display the data returned.
#include "VescUart.h"
#include <Adafruit_Fingerprint.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if defined(ARDUINO_FEATHER_ESP32) // Feather Huzzah32
#define TFT_CS 14
#define TFT_RST 15
#define TFT_DC 32
#elif defined(ESP8266)
#define TFT_CS 4
#define TFT_RST 16
#define TFT_DC 5
#else
// For the breakout board, you can use any 2 or 3 pins.
// These pins will also work for the 1.8" TFT shield.
#define TFT_CS 1 // D v25 changes to use pin 1 for CS in MKR1500
#define TFT_RST -1 // Or set to -1 and connect to Arduino RESET pin // D v25 changes to use built in reset pinout in MKR1500
#define TFT_DC 2 // D v25 changes to use pin 2 for CS in MKR1500
#endif
//D v15 for audrino to connect to fingerprint sensor
//D v2
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 4);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
const int DIN_PIN = 7;
int LedPin=6;
// OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
// to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
// SCLK = pin 13. This is the fastest mode of operation and is required if
// using the breakout board's microSD card.
// For 1.44" and 1.8" TFT with ST7735 use:
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST); // D v21 uncomment this and comment the line below to use 1.44inch display.Need to change the display font in case I use 1.44"
// For 1.14", 1.3", 1.54", and 2.0" TFT with ST7789:
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST); // D v22 uncommment to use this display
/** Initiate VescUart class */
VescUart UART;
/** Setup Serial port to display data */
//Serial.begin(9600);
/** Setup UART port (Serial1 on Atmega32u4) */
Serial1.begin(115200); // Serial1.begin(19200);
while (!Serial1) {;}
/** Define which ports to use as UART */
UART.setSerialPort(&Serial1);
pinMode( DIN_PIN, INPUT_PULLUP );
// tft.initR(INITR_144GREENTAB); // Init ST7735R chip, green tab
// OR use this initializer (uncomment) if using a 1.3" or 1.54" 240x240 TFT:
tft.init(240, 240); // Init ST7789 240x240 // D v22 uncommment to use this display
// tft print function!
tftPrintTest();
tft.println("Test display ");
/** Call the function getVescValues() to acquire data from VESC */
if ( UART.getVescValues() ) {
tft.println(UART.data.rpm);
tft.println(UART.data.inpVoltage);
tft.println(UART.data.ampHours);
tft.println(UART.data.tachometerAbs);
tft.println("Failed to get data!");
delay(50);
void tftPrintTest() {
tft.setTextWrap(true);
tft.fillScreen(ST77XX_BLACK);
tft.setCursor(0, 0);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(2);
