I am working with Arduino and ADS1231. But I am not able to find any library for ADS1231. I have tried to read MISO pin but it gives 0 0nly. So, I am not able to write code from data sheet also. I have attached datasheet below.
I would be great to have some guidance to start it.
ads1231_datasheet.pdf (978.5 KB)
I tried the above library and also code as per below. but the result is same.
it does not increases value according output. it gives constant value that is 0.
#define POWERDOWN 8 //POWERDOWN -LOW TO POWER DOWN
//#define SPEED 11 //Chip selection pin
#define DATAPIN 52 //Data pin
#define CLOCK 50 //ADS 7817 clock
#define ZEROSWITCH 7 // FOR ZERO ERROR
unsigned long adcvalue;
short int i;
float c,y;
initspi();
Serial.begin(9600); //Initialize serial for debugging
//pinMode(ZEROSWITCH, INPUT_PULLUP);
caliberate();
displaydata();
//delay(200);
if(!digitalRead(ZEROSWITCH))
caliberate();
//float c=y;
void readADS1231(void)
adcvalue=0;
//digitalWrite(POWERDOWN, HIGH); //POWER ON
while(digitalRead(DATAPIN));//WAIT UNTIL DATA IS READY
//24-->21
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X800000;} //24
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X400000;}//23
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X200000;}//22
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X100000;}//21
//20-->17
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X80000;} //20
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X40000;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X20000;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X10000;}//17
//16-->13
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X8000;} //16
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X4000;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X2000;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X1000;}//13
//12-->9
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X800;} //12
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X400;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X200;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X100;}//9
//8-->5
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X80;} //8
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X40;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X20;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X10;}//5
//4-->1
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X8;} //4
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X4;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X2;}//
clock ();
if(digitalRead(DATAPIN)){adcvalue=adcvalue+0X1;}//1
clock ();//TO PULL DATA READY TO HIGH STATE --PAGE No.14 ON ADS1231 DATASHEET
digitalWrite(CLOCK, LOW);
//digitalWrite(POWERDOWN, LOW);
void caliberate(void)
readADS1231();
c=(adcvalue/100000.0);
Serial.print("caliber=");Serial.println(c);
void displaydata(void)
readADS1231();
y=(adcvalue/100000.0);
y=y-c;
Serial.print("adcvalue=");Serial.println(y);
void clock (void)
digitalWrite(CLOCK, HIGH);
delayMicroseconds(10);
void initspi(void)
pinMode(POWERDOWN, OUTPUT);
pinMode(DATAPIN, INPUT);
pinMode(CLOCK, OUTPUT);
//pinMode(SPEED, OUTPUT);
digitalWrite(POWERDOWN, HIGH); //0--> POWERDOWN(SLEEPING -NO CONVERSION) ,1-->WORKING MODE
//digitalWrite(SPEED, 0);//0--> 10SPS ,1-->80SPS
Did you try the example sketch that comes with the library ?
Yes, I have tried that one only with library.
I have changed nothing. neither in the above code nor in hardware. but at the time when I change input value output value changes and goes zero again and then gives zero continuously again.
system
Closed
June 19, 2022, 10:05am
8
