I am trying to learn how to interface Arduino with python. I have come across some resources which describe pyfirmata and pyserial packages. Which one is better and why?
Also, I was trying to run a simple LED blink code from python. The result is that:
1.) RX led of arduino blinks
2.) LED connected to pin 10 and breadboard doesn’t
So I am trying to run a simple code to run in python to make the LED ligh on bread board blink. The two codes i have used are as follows:
1.) pySerial: Here I have to run the code in the arduino first and next when i run it in python, it executes the code but when I stop it still keeps on blinking. The code is:
import serial
import time
ser = serial.Serial('/dev/cu.usbmodem142101',9600)
time.sleep(1)
def led_on():
while True:
while ser.in_waiting==0:
pass
data = ser.readline()
data = str(data,'utf-8')
print(data)
led_on()
print("done")
2.)Here I try to use pyfirmata. First, I run the standardFirmata through the Arduino IDE and then try to run this python code. But all that happens is that the RX keeps blinking:
import pyfirmata
import time
board = pyfirmata.Arduino('/dev/cu.usbmodem142101')
pin = 12
while True:
board.digital[pin].write(1)
time.sleep(1)
board.digital[pin].write(0)
time.sleep(1)
