I really don't enjoy using the web editor and I would like to use Platformio. I made a new project and copied the the contents of the sketch (from the arduino web editor) into main.cpp and from thigProperties.h files to a new file called thingProperties.h and replaced the credentials.
Then I added the ArduinoIoTCloud library to the project.
While compiling I get a ton of errors.
Then I tried doing the same thing in the Arduino IDE 1.18.13 and it works as it should. The code compiles and uploads to the ESP32 and the board connects to the cloud and it works the same way as it does with the web editor. However I would really prefer using platformio.
I have also tried deleting everything from the .pio/libdebs folder and copying the ones downloaded by the arduino IDE with the same outcome.
Here the terminal while buliding:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32doit-devkit-v1.html
PLATFORM: Espressif 32 (3.2.0) > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 40 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <ArduinoIoTCloud> 1.3.1
| |-- <Arduino_DebugUtils> 1.1.0
| |-- <Arduino_ConnectionHandler> 0.6.5
| | |-- <WiFiNINA> 1.8.13
| | | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| |-- <WiFiClientSecure> 1.0
| | | |-- <SPI> 1.0
| |-- <ArduinoMqttClient> 0.1.5
| | |-- <SPI> 1.0
Building in release mode
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib9de\libArduino_DebugUtils.a
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFi.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiClient.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiStorage.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiUdp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\utility\spi_drv.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\utility\wifi_drv.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_ConnectionHandler.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_GSMConnectionHandler.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_NBConnectionHandler.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_WiFiConnectionHandler.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf81\WiFiClientSecure\WiFiClientSecure.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf81\WiFiClientSecure\ssl_client.cpp.o
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src/WiFiStorage.h:23:0,
from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src/WiFi.h:38,
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src/Arduino_ConnectionHandler.h:120,
from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:27,
from src\thingProperties.h:3,
from src\main.cpp:22:
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src/utility/wifi_drv.h:293:12: error: 'PinStatus' does not name a type
static PinStatus digitalRead(uint8_t pin);
In file included from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/../property/PropertyContainer.h:27:0,
from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/CBORDecoder.h:35,
from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:35,
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/../property/types/automation/CloudTelevision.h: In member function 'virtual void CloudTelevision::setAttributesFromCloud()':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/../property/types/automation/CloudTelevision.h:229:39: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
setAttribute((int&)_cloud_value.pbc);
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/../property/Property.h:52:42: note: in definition of macro 'setAttribute'
#define setAttribute(x) setAttributeReal(x, getAttributeName(#x, '.'))
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/cbor/../property/types/automation/CloudTelevision.h:230:39: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
setAttribute((int&)_cloud_value.inp);
In file included from src\thingProperties.h:3:0,
src\thingProperties.h: In function 'void initProperties()':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:104:64: warning: 'void ArduinoIoTCloudClass::addPropertyReal(int&, String, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
#define addProperty( v, ...) addPropertyReal(v, #v, __VA_ARGS__)
src\thingProperties.h:33:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(sensor5, READWRITE, 1 * SECONDS, onSensor5Change);
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:113:10: note: declared here
void addPropertyReal(int& property, String name, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
src\thingProperties.h:34:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(sensor1, READWRITE, 1 * SECONDS, onSensor1Change);
src\thingProperties.h:35:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(sensor2, READWRITE, 1 * SECONDS, onSensor2Change);
src\thingProperties.h:36:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(sensor3, READWRITE, 1 * SECONDS, onSensor3Change);
src\thingProperties.h:37:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(sensor4, READWRITE, ON_CHANGE, onSensor4Change);
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:104:64: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
src\thingProperties.h:38:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(activeTime, READWRITE, ON_CHANGE, onActiveTimeChange, 1);
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:110:10: note: declared here
void addPropertyReal(Property& property, String name, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFi.cpp:21:0:
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility/wifi_drv.h:293:12: error: 'PinStatus' does not name a type
Compiling .pio\build\esp32doit-devkit-v1\libedc\ArduinoMqttClient\MqttClient.cpp.o
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFiClient.cpp:30:0:
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFiStorage.h:23:0,
from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFi.h:38,
from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFiServer.cpp:28:
from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFiStorage.cpp:20:
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\WiFiUdp.cpp:29:0:
In file included from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\wifi_drv.cpp:27:0:
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\wifi_drv.cpp:1063:1: error: 'PinStatus' does not name a type
PinStatus WiFiDrv::digitalRead(uint8_t pin)
from .pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp:25:
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static void SpiDrv::begin()':
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp:94:24: error: 'PINS_COUNT' was not declared in this scope
if (SLAVERESET > PINS_COUNT) {
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp:103:15: error: 'NINA_GPIO0' was not declared in this scope
pinMode(NINA_GPIO0, OUTPUT);
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static int SpiDrv::available()':
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp:66:25: error: 'NINA_GPIO0' was not declared in this scope
#define NINA_GPIOIRQ NINA_GPIO0
.pio\libdeps\esp32doit-devkit-v1\WiFiNINA\src\utility\spi_drv.cpp:597:25: note: in expansion of macro 'NINA_GPIOIRQ'
return (digitalRead(NINA_GPIOIRQ) != LOW);
Compiling .pio\build\esp32doit-devkit-v1\lib8b1\ArduinoIoTCloud\ArduinoIoTCloud.cpp.o
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFi.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiClient.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiServer.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiStorage.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\WiFiUdp.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\utility\spi_drv.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib204\WiFiNINA\utility\wifi_drv.cpp.o] Error 1
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_ConnectionHandler.h:120,
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_ConnectionHandler.cpp:22:
*** [.pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_ConnectionHandler.cpp.o] Error 1
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_GSMConnectionHandler.h:25,
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_GSMConnectionHandler.cpp:22:
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_NBConnectionHandler.h:25,
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_NBConnectionHandler.cpp:22:
*** [.pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_GSMConnectionHandler.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_NBConnectionHandler.cpp.o] Error 1
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_WiFiConnectionHandler.h:25,
from .pio\libdeps\esp32doit-devkit-v1\Arduino_ConnectionHandler\src\Arduino_WiFiConnectionHandler.cpp:22:
*** [.pio\build\esp32doit-devkit-v1\lib067\Arduino_ConnectionHandler\Arduino_WiFiConnectionHandler.cpp.o] Error 1
from C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.h:25,
from C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:21:
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In constructor 'WiFiClientSecure::WiFiClientSecure()':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:33:5: error: '_connected' was not declared in this scope
_connected = false;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In constructor 'WiFiClientSecure::WiFiClientSecure(int)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:51:5: error: '_connected' was not declared in this scope
_connected = false;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'WiFiClientSecure& WiFiClientSecure::operator=(const WiFiClientSecure&)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:81:5: error: '_connected' was not declared in this scope
_connected = other._connected;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:81:24: error: 'const class WiFiClientSecure' has no member named '_connected'
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual void WiFiClientSecure::stop()':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:90:9: error: '_connected' was not declared in this scope
_connected = false;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'int WiFiClientSecure::connect(const char*, uint16_t, const char*, const char*, const char*)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:137:5: error: '_connected' was not declared in this scope
_connected = true;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'int WiFiClientSecure::connect(const char*, uint16_t, const char*, const char*)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:157:5: error: '_connected' was not declared in this scope
_connected = true;
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual size_t WiFiClientSecure::write(const uint8_t*, size_t)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:186:10: error: '_connected' was not declared in this scope
if (!_connected) {
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual int WiFiClientSecure::available()':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:230:10: error: '_connected' was not declared in this scope
if (!_connected) {
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual uint8_t WiFiClientSecure::connected()':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:246:12: error: '_connected' was not declared in this scope
return _connected;
from C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\ssl_client.cpp:20:
*** [.pio\build\esp32doit-devkit-v1\libf81\WiFiClientSecure\WiFiClientSecure.cpp.o] Error 1
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\ssl_client.cpp: In function 'int start_ssl_client(sslclient_context*, const char*, uint32_t, int, const char*, const char*, const char*, const char*, const char*, bool)':
C:\Users\gyano\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\ssl_client.cpp:75:9: error: 'WiFiGenericClass' has not been declared
if(!WiFiGenericClass::hostByName(host, srv)){
*** [.pio\build\esp32doit-devkit-v1\libf81\WiFiClientSecure\ssl_client.cpp.o] Error 1
from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:22:
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:52:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
addPropertyReal(property, name, -1, permission_type, seconds, fn, minDelta, synFn);
In file included from .pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:22:0:
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:130:10: note: declared here
void addPropertyReal(Property& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(bool&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:85:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(bool&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:131:10: note: declared here
void addPropertyReal(bool& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(bool&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:91:79: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
addPropertyReal(*p, name, tag, permission_type, seconds, fn, minDelta, synFn);
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:55:6: note: declared here
void ArduinoIoTCloudClass::addPropertyReal(Property& property, String name, int tag, permissionType permission_type, long seconds, void(*fn)(void), float minDelta, void(*synFn)(Property & property))
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(float&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:107:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(float&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:132:10: note: declared here
void addPropertyReal(float& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(float&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:113:79: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(int&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:129:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(int&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:133:10: note: declared here
void addPropertyReal(int& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(int&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:135:79: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(unsigned int&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:151:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(unsigned int&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:134:10: note: declared here
void addPropertyReal(unsigned int& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(unsigned int&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:157:79: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(String&, String, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:173:84: warning: 'void ArduinoIoTCloudClass::addPropertyReal(String&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src/ArduinoIoTCloud.h:135:10: note: declared here
void addPropertyReal(String& property, String name, int tag, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp: In member function 'void ArduinoIoTCloudClass::addPropertyReal(String&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))':
.pio\libdeps\esp32doit-devkit-v1\ArduinoIoTCloud\src\ArduinoIoTCloud.cpp:179:79: warning: 'void ArduinoIoTCloudClass::addPropertyReal(Property&, String, int, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
*** [.pio\build\esp32doit-devkit-v1\lib8b1\ArduinoIoTCloud\ArduinoIoTCloud.cpp.o] Error 1
=================================================================================================================================================================== [FAILED] Took 2.68 seconds ===================================================================================================================================================================
Der Terminalprozess "C:\Users\gyano\.platformio\penv\Scripts\platformio.exe 'run'" wurde mit folgendem Exitcode beendet: 1.
