Arduino_iot_cloud Python Module issues - 23:35:35.538 Connection failed module 'ssl' has no attribute 'wrap_socket', retrying after 1.0s
Trying to do this example but getting the errors:
`23:35:35.538 Connection failed module 'ssl' has no attribute 'wrap_socket', retrying after 1.0s
C:\Python312\Lib\site-packages\cbor2\decoder.py:7: UserWarning: The cbor.decoder module has been deprecated. Instead import everything directly from cbor2.
warn("The cbor.decoder module has been deprecated. Instead import everything directly from cbor2.")
in Python.
import time
import logging
import sys
sys.path.append("lib")
from arduino_iot_cloud import ArduinoCloudClient
DEVICE_ID = b"words"
SECRET_KEY = b"words"
def logging_func():
logging.basicConfig(
datefmt="%H:%M:%S",
format="%(asctime)s.%(msecs)03d %(message)s",
level=logging.INFO,
This function is executed each time the "test_switch" variable changes
def on_switch_changed(client, value):
print("Switch Pressed! Status is: ", value)
if name == "main":
logging_func()
client = ArduinoCloudClient(device_id=DEVICE_ID, username=DEVICE_ID, password=SECRET_KEY)
client.register("test_value")
client["test_value"] = 20
client.register("test_switch", value=None, on_write=on_switch_changed)
client.start()
I am facing the same issue. is it working for you now?
