Arduino IoT Cloud reliablility
I am experiencing an issue where my MKR 1500 NB boards run perfectly for a few days and then become disconnected and unresponsive.
I can tell the Void Loop() is still running so the board hasn't frozen/crashed.
Is there code that I can run perhaps every hour using millis() to refresh the connection?
Perhaps, disconnect and reconnect again?
Best,
M
Hi, Im using callback, if ArduinoCloud is disconnected, I reset my board and it connects again.. It works good for months now.. Btw its ESP8266, but never mind, the concept is the same.
add this to setup loop:
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::DISCONNECT, doThisOnDisconnect);
and then make fuction
doThisOnDisconnect();
with command to reset the board.
Thank you for this @noobmastha
Do you reset by connecting the reset pin to a digital pin or do you do it in software?
Best,
M
I`m doing it in software, it is ESP.restart(); for Espressif chips, try to find something simmilar for your arduino board.
Cheers.
Contact Arduino Tech Support via https://www.arduino.cc/en/contact-us/ to have your board's Ublox module firmware upgraded.
Thank you @noobmastha
I think you have been helpful on two of my posts now!
Best,
M
Hi @Dozie
Why do you say this? Is this a known issue?
Best,
Matt
Youre welcome, Its noob to noob solidarity :smiley:
@bigdingo your board might have an old Ublox firmware, the tech support will help you check this and assist you to upgrade to newer one that is more efficient.
