Arduino IoT is not detecting my ESP32
I'm using ESP32 Devkit V1 (device is new, first time I'm using it)
When trying to connect the device to Arduino IoT it can't detect the device via USB
Did you download Arduino Create Agent
yeah, it's already downloaded
When you connect the board to pc does anything pop like board connected something like that
no, I'm using mac
I'm pretty sure the issue is not from the micro USB nor the ESP32 device itself because I tried to upload a sketch to the ESP32 and it worked
Does anything like this popup
No
Can you try it in another browser. Which one are you currently using
I tried, nothing changed
I don't know much about this topic . As i searched people suggest using firefox am not sure if the problem still persist check out this Post
Try out the Alternative solution provided by ptillisch
Alright, thank you for your time
:+1:
I noticed that when the web editor is loading I can click select device for 5 seconds and get this screen but it disappears suddenly
Did you figure out the cause
Hi @devhq. This is caused by a bug recently introduced into Arduino Cloud that affects ESP32 boards. I have submitted a formal report to the Arduino Cloud Developers and will report back here if I have any news to share regarding a resolution.
For now, please use Arduino IDE when you need to upload Arduino Cloud IoT Thing sketches to your ESP32 board via the serial port.
You can use the Arduino Cloud sketchbook integration feature of Arduino IDE 2.x to get convenient access to all your Arduino Cloud sketches (including Thing sketches) for use in Arduino IDE:
https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-cloud-sketch-sync
Hello again @devhq. The bug that caused Cloud Editor to not recognize the serial ports of ESP32 and ESP8266 boards has now been fixed. I apologize for any inconvenience this has caused you.
There is one remaining problem you should be aware of: if you have multiple Arduino boards (or other devices that produce serial ports) connected to your computer, Cloud Editor might pick the wrong port to use. I have submitted a report about this problem to the developers. For now, please disconnect any additional Arduino boards from your computer before opening an Arduino Cloud IoT Thing sketch in Cloud Editor when using a serial port to upload to the board.
Please give it a try and let us know if you still have any problems.
