At the moment I have just the complex code whre all stuff is includet
I thought it would be easyer just to develope the fade sequenze
#include <TimerOne.h>
#include <IRremote.h>
int RECV_PIN = 11; // IR-Receiver PIN
int led = 12; // Satus-LED PIN
int modus; // Modus for Interrupt-Querry
int ledr = 6; // RGB LED red PIN
int ledg = 7; // RGB LED green PIN
int ledb = 8; // RGB LED blue PIN
int SerialBuffer = 0;
int RedVal=1; // Variablen for fader
int BlueVal=1; // "
int GreenVal=1; // "
int i=1; // Counter for fader
int timerwert = 50; // Timer time for Interrupt in ms
int fadespeed = 10; // Speed for Fade --> 1: extrem fast
// --> 10: normal
// --> 100: extrem slow
String readString;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(ledr, OUTPUT); // Set RGB LED Pins as Output
pinMode(ledg, OUTPUT); // Set RGB LED Pins as Output
pinMode(ledb, OUTPUT); // Set RGB LED Pins as Output
pinMode(led, OUTPUT); // set Status-LED as Output
irrecv.enableIRIn(); // Start of IR-Recive
Timer1.initialize(timerwert); // Initialisation of Timer-Interrupts
Timer1.attachInterrupt(leseIR); // IR-Read from Interrupt
void leseIR(){
//Permanent Querry if value of IR-Recieve, Althought loop
if (irrecv.decode(&results)){
switch (results.value) {
case 0xFF10EF: // Modus Fade (DIY 4)
modus = 1;
case 0xFF906F: // Modus pcambi (DIY 5)
modus = 2;
// DIY 1 FF30CF
// DIY 2 FBB04F
// DIY 3 FF708F
// DIY 4 FF10EF
// DIY 5 FF906F
// DIY 6 FF50AF
case 0xFF02FD: //Power
modus = 0;
digitalWrite(led, HIGH); // Status LED ON
delay(500); // Pause 0,5s
digitalWrite(led, LOW); // Status LED OFF
setColor(0, 0, 0); // RGB LEDs Off
//Standart RGB Remote
case 0xFFA25D: //Blau 0,0,255
modus = 0;
setColor(0, 0, 255);
case 0xFF1AE5: //Rot
modus = 0;
setColor(255, 0, 0);
case 0xFF9A65://Grün
modus = 0;
setColor(0, 255, 0);
case 0xFF22DD: //Weiss
modus = 0;
setColor(255, 255, 255);
case 0xFF2AD5: //orange
modus = 0;
setColor(255, 165, 0);
case 0xFFAA55://Grün mitrtel
modus = 0;
setColor(124, 252, 0);
case 0xFF926D: //blau mittel
modus = 0;
setColor(92, 172, 238);
case 0xFF12ED: //rosa
modus = 0;
setColor(255, 228, 196);
} // Switch END
} // Empfange IR END
irrecv.resume(); // Receive the next value
} // Read IR END
void setColor (int red, int green, int blue) {
// RGB LED: write inverted value for each color
analogWrite(ledr, 255 - red);
analogWrite(ledg, 255 - green);
analogWrite(ledb, 255 - blue);
/// Fade //////////
void fade(int Speed){
analogWrite(ledr,255-RedVal);
analogWrite(ledb,255-BlueVal);
analogWrite(ledg,255-GreenVal);
RedVal =((i<255)*i)+((i>=255)*255)+((i>511)*(512-i))+((i>766)*(i-766))+((i>=1276)*(i-1276))+((i>1530)*(1530-i))+((i>1786)*(1786-i));
GreenVal =(i<256)*(1)+(i>255)*(i-255)+(i>510)*(510-i)+(i>1020)*(1020-i)+(i>1274)*(i-1274)+(i>1530)*(i-1531)+(i>1785)*(3571-(2*i));
BlueVal =(i<764)*(1)+(i>765)*(i-765)+(i>1020)*(1020-i)+(i>1786)*(1786-i);
if(i>2040){
i = 1;
i++;
delay(Speed);
} // Fade ENDE
digitalWrite(led, HIGH); // Status LED EIN
delay(50); // Pause 0,5s
digitalWrite(led, LOW); // Status LED AUS
delay(50);
delay(50);
if(modus==1){ // Querry pb Modus:1
fade(fadespeed); // Starte Fade
if(modus==2){ // Querry pb Modus:2
pcambi(); // pcaMBIwill be used for further project
if(modus==3){ // Querry pb Modus:3 in Interrupt gesetzt
//starteServer();
} // LOOP Ende
