Arduino IR Servo Controller
I would like to make a servo IR controlled by my TV remote. I would like to control my surround sound system which doesn’t have a remote to control volume. The code i use is from someone else but i am trying to modify to work for me.
The code will detach the servo but will now attach the servo.
Here I am trying to detach the servo and attach the servo back when the button is pressed again:
            case SELECT_BUTTON:
              ++OnOff;
              if (OnOff > 0; OnOff <= 1) {
                My_Servo.detach();
              }else if (OnOff > 1) {
                My_Servo.attach(9);
                OnOff = 0;
                My_Servo.write(pos);
I would also like to put a LED in there so that i know whether it is on or not. Please help. This is one the first Arduino projects I’ve done and is the first with a servo.
Can you tell when this condition is true:
I had guessed that it never compiles.
As a general hint: always add an unconditional “else” to every if-else-if construct, where you can place diagnostic output when this unexpected branch is taken.
Looks like you're doing a long wrong complicated thing when you're just trying to make a boolean toggle with a flag.
DrDiettrich:
The code compiles just fine. the statement will be true when 1 is added to the OnOff int. The servo will also shut off when i press the button but not turn on again.
INTP: Looks like you're doing a long wrong complicated thing when you're just trying to make a boolean toggle with a flag.
As I have stated I'm very new to this. Could you please explain?
Not for me, using IDE 1.6.11
  int OnOff=0;
  if (OnOff > 0; OnOff <= 1) Serial.print("true");
Result:
C:\Users\Justme\Desktop\Arduino\sketch_oct01a\sketch_oct01a.ino: In function 'void setup()':
sketch_oct01a:5: error: expected ')' before ';' token
C:\Users\Justme\Desktop\Arduino\sketch_oct01a\sketch_oct01a.ino:5:16: warning: suggest braces around empty body in an 'if' statement [-Wempty-body]
sketch_oct01a:5: error: expected ';' before ')' token
C:\Users\Justme\Desktop\Arduino\sketch_oct01a\sketch_oct01a.ino:5:24: warning: statement has no effect [-Wunused-value]
exit status 1
I think you mean
   if (OnOff == 1) {
jremington:
  int OnOff=0;
  if (OnOff > 0; OnOff <= 1) Serial.print(“true”);
Result:
C:\Users\Justme\Desktop\Arduino\sketch_oct01a\sketch_oct01a.ino: In function ‘void setup()’:
sketch_oct01a:5: error: expected ‘)’ before ‘;’ token
C:\Users\Justme\Desktop\Arduino\sketch_oct01a\sketch_oct01a.ino:5:16: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
sketch_oct01a:5: error: expected ‘;’ before ‘)’ token
exit status 1
I think you mean
if (OnOff == 1) {
The code here is only part of the full code. I just cant get this part to function when uploaded. And I am using Arduino IDE 1.6.12
jremington: I think you mean
   if (OnOff == 1) {
This fixed the problem. I am a programmer and forgot to do the == thing. I am completely stupid.
