Hello everyone, I hope your smmer is going great. I was bored on a previous afternoon and as someone who has a whole arduino kit i thought I should put my Engineering degree to work so i can occupy my time. The project I am embarking on involves me sending IR signals mimicing the ON/OFF code of the SONY bravia tv model kdl-32m3000 which is a pretty old flat screen model.
I made sure the circuitry of my miniboard is wired properly (including a 220 ohm resistor, IR LED operating at 940 nm wavelength). To verify functionality I turned off the lights in my room and directed my phone camera at the LED. With my phone camera I was able to see the purple light from the LED transmitting the code so it was working.
The TV was still not coming on so I added 2 more LEDs in parallel to enhance signal strength but still no avail. My well commented code is below along with the SONY codes I tried so you can take a peak.
#include <IRremote.h>
const int irPin = 3; // My pin for the IR LED transmission
// I intentionally chose a pin for PWM since the SONY encoding scheme is based on PWM (.eg width of 2ns followed by 1ns = 0, 2ns followed by 3ns = 1
IRsend irsend; // Create an IRsend object
// Sony power ON/OFF code (12-bit Sony protocol)
unsigned long sonyPowerOffCodes[] = {
0xA90UL, // Common power ON/OFF code for Sony TVs
0x290UL, // Another Sony power ON/OFF code
0x490UL // Yet another Sony power ON/OFF code
int numCodes = sizeof(sonyPowerOffCodes) / sizeof(sonyPowerOffCodes[0]);
irsend.begin(irPin); // Initialize the IRsend library with the specified pin
Serial.println("IR Remote Test Initialized");
Serial.println("Starting send cycle...");
for (int i = 0; i < numCodes; i++) {
Serial.print("Sending code: 0x");
Serial.println(sonyPowerOffCodes[i], HEX);
// Send the same code multiple times to ensure reception
for (int j = 0; j < 3; j++) { // Sending each code 3 times for trial
irsend.sendSony(sonyPowerOffCodes[i], 0, 12); // Send Sony code with the updated function signature
delay(50); // Short delay between repeats so there is no overload
Serial.println("Send cycle complete.");
delay(5000); // Waiting 5 seconds before repeating the sending cycle
Yes I was close enoughto the TV incase anyone is thinking about that ![]()
