Arduino-IRremote-master
Does anyone have a trouble with this library, there are so many websites with examples using this library, but I have dowlonaded the library(several time from the same places where teh examples are), and I cant compile anything, when I use an exmplem from the library,It's annoying.
One of the error the compilefr gives to me is :
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope
Anyone knows anything about this??
So delete that file. Unless you have a robot that is. And, of you do, why are you not using its IR?
I have been reading about that fault, and what people have found was is that there is a conficlt with other libraries in arduino IDE, I have done what the say to fix it but the trouble still keep going, I dont k now what to do....I'll try to find it...thanks!!
If you post the complete code that is causing the problem it might be easier to help.
...R
see https://github.com/shirriff/Arduino-IRremote/issues/91 for a solution.
Thank I'll have a look on that
