I installed grbl v0.9, and when I access the serial port from Tools/Serial Monitor, in arduino app , or the app "Universal Gcode Sender", the arduino returns me:
Grbl 0.9j [ '$' for help]
[ '$ H' | '$ X' to unlock]
Perfect. This is how it has to work.
I made a program in c++ to handle the serial port. If I close the port and I open them again, the arduino is not reset and not the blocking message appears.
#include "MyForm.h"
using namespace Project1;
System::Void MyForm::findPorts()
// get port names
array<Object^>^ objectArray = SerialPort::GetPortNames();
this->ComSelect->Items->AddRange(objectArray);
System::Void MyForm::OpenButton_Click(System::Object^ sender, System::EventArgs^ e)
if (this->ComSelect->Text == String::Empty || this->BaudSelect->Text == String::Empty)
this->LogBox->AppendText("Please Select Port Settings\r\n");
else {
try {
// make sure port isn't open
if (!this->serialPort1->IsOpen) {
this->serialPort1->PortName = this->ComSelect->Text;
this->serialPort1->BaudRate = Int32::Parse(this->BaudSelect->Text);
this->serialPort1->Parity = IO::Ports::Parity::None;
this->serialPort1->StopBits = IO::Ports::StopBits::One;
this->serialPort1->DataBits = 8;
this->serialPort1->Open();
this->CommandBar->Text = "Enter Message Here";
this->LogBox->AppendText("\r\n**** Connected to " + ComSelect->Text + " at " + BaudSelect->Text + " Baud ****\r\n");
//open serial port
this->progressBar1->Value = 100;
// Disable the init button
this->OpenButton->Enabled = false;
this->ComSelect->Enabled = false;
this->BaudSelect->Enabled = false;
this->CloseButton->Enabled = true;
this->SendButton->Enabled = true;
AfterEvent(); // Send ctrl-x
this->LogBox->AppendText("\r\nPort isn't openned\r\n");
catch (UnauthorizedAccessException^) {
this->LogBox->AppendText("\r\nUnauthorizedAccess\r\n");
System::Void MyForm::AfterEvent()
auto data = gcnew array<System::Byte> {0x18}; //send ctrl-x
this->serialPort1->Write(data, 0, data->Length);
System::Void MyForm::CloseButton_Click(System::Object^ sender, System::EventArgs^ e)
//close serialPort
if (this->serialPort1->IsOpen)
//this->serialPort1->WriteLine("\u0018"); //Send ctrl-x to reset
this->serialPort1->Close();
// update progress bar
this->progressBar1->Value = 0;
// Enable the init button
this->OpenButton->Enabled = true;
this->ComSelect->Enabled = true;
this->BaudSelect->Enabled = true;
this->CloseButton->Enabled = false;
this->SendButton->Enabled = false;
this->LogBox->AppendText("\r\n**** Connection Closed ****\r\n\r\n");
//this->LogBox->Text = String::Empty;
this->LogBox->AppendText("\r\nPort Not Opened\r\n");
System::Void MyForm::CommandBar_click(System::Object^ sender, System::EventArgs^ e)
this->CommandBar->Text = String::Empty;
System::Void MyForm::EnterKeyBar(System::Object^ sender, System::Windows::Forms::KeyEventArgs^ e)
if (e->KeyCode == Keys::Enter)
// add sender name
//String^ name = this->serialPort1->PortName;
// grab text and store in send buffer
String^ message = this->CommandBar->Text;
// write to serial
//this->_serialPort->WriteLine(String::Format("<{0}>: {1}",name,message));
this->serialPort1->WriteLine(message);
this->LogBox->AppendText(">>>> " + message + "\r\n");
System::Void MyForm::SendButton_Click(System::Object^ sender, System::EventArgs^ e)
// write to serial
System::Void MyForm::serialPort1_DataReceived(System::Object^ sender, System::IO::Ports::SerialDataReceivedEventArgs^ e)
// richLogBox->Text = "Received Event";
String^ myString = serialPort1->ReadExisting();
DelegateType ^pfnDelegate = gcnew DelegateType(this, &MyForm::DataReceived);
this->LogBox->BeginInvoke(pfnDelegate, myString);
System::Void MyForm::DataReceived(String ^myString)
try
this->LogBox->AppendText(myString);
//LogBox->ScrollToCaret();
catch (Win32Exception^ ex)
this->LogBox->Text = ex->Message;
System::Void MyForm::ResetButton_Click(System::Object^ sender, System::EventArgs^ e)
AfterEvent(); // send ctrl-x
/*auto data = gcnew array<System::Byte> {0x18};
this->serialPort1->Write(data, 0, data->Length);*/
this->LogBox->Text = "Port Not Opened\r\n";
All files are here.
¿Someone knows why can it be?
