Arduino is skipping through lines of code - not a coding issue
Hi, when I run my program through tinkercad it works just fine. When I run it through my arduino, however, it skips a whole block of code (the for() loop that blinks the yellow LED). I’ve tried multiple Arduinos with the same result. Any suggestions?
int yellowPin = 13;
int redPin = 12;
int redBlinkNumber;
int yellowBlinkNumber;
  Serial.begin (9600);
pinMode (redPin, OUTPUT);
pinMode (yellowPin, OUTPUT);
  Serial.println ("How many times do you want the red LED to blink?"); while (Serial.available () == 0) {} redBlinkNumber = Serial.parseInt(); delay (2000);
  Serial.println ("How many times do you want the yellow LED to blink?"); while (Serial.available () == 0) { } yellowBlinkNumber = Serial.parseInt(); delay (2000);
  Serial.println("The Red Light is Blinking!");
  for (int x = 1; x <= redBlinkNumber; x++) {
    Serial.print ("This is blink #: ");
    Serial.println(x);
    digitalWrite (redPin, HIGH);
    delay (1000);
    digitalWrite (redPin, LOW);
    delay (100);
  Serial.println("The Yellow Light is Blinking!"); delay (1000);
  for (int y = 1; y <= yellowBlinkNumber; y++) {
    Serial.println(y);
    digitalWrite (yellowPin, HIGH);
    delay (1000);
    digitalWrite (yellowPin, LOW);
    delay (100);
Add some debug prints and find out that the number of times that you blink the yellow LED is in fact zero?
Real-world trumps simulation, every time.
I don’t understand…If you have a real Arduino, then why would you run on tinkercad? By the way you gotta organize your code. It’s all over the place. Use Ctrl + t to Auto Format…
As this is your first post, it’s better if you learn how to use the forum
