Hello I am a student Arduino Programmer! ![]()
I am using Arduino UNO (later I will use MEGA) with Some buttons to make a voting machine. Now the machine has one glitch that when two buttons are pressed around the same time ( within 1 second ) , Arduino is Picking up the systematically set up first as in the circuit not the one which has been pressed first in the instance of 1-0.5 second.
I am not sure that is it due to high delay between the vote time or so
Thank you Before
I Appreciate your replies ![]()
CODE
int s1 = 2;
int s2 = 3;
int s3 = 4;
int s4 = 5;
int b = 6;
int r = 8;
int t = 5000;
int vc = 0;
int t2 = 3000;/*Delay Time after each vote*/
int l1 = 9;
int l2 =10;
int l3 = 11;
int l4 = 12;
pinMode(s1,INPUT_PULLUP);
pinMode(s2,INPUT_PULLUP);
pinMode(s3,INPUT_PULLUP);
pinMode(s4,INPUT_PULLUP);
pinMode(6,OUTPUT);
pinMode(r,INPUT_PULLUP);
pinMode(l1,OUTPUT);
pinMode(l2,OUTPUT);
pinMode(l3,OUTPUT);
pinMode(l4,OUTPUT);
if(digitalRead(s1) == LOW)
Serial.println("Candidate 1 Vote Registered");
vc = vc + 1;
Serial.println("Total Vote polled");
Serial.println(vc);
digitalWrite(b,HIGH);
digitalWrite(l1,HIGH);
delay(t);
else if(digitalRead(s2) == LOW)
Serial.println("Candidate 2 Vote Registered");
vc = vc + 1;
Serial.println(vc);
digitalWrite(l2,HIGH);
delay(t);
else if(digitalRead(s3) == LOW)
Serial.println("Candidate 3 Vote Registered");
vc = vc + 1;
Serial.println(vc);
digitalWrite(l3,HIGH);
delay(t);
else if(digitalRead(s4) == LOW)
Serial.println("Candidate 4 Vote Registered");
vc = vc + 1;
Serial.println(vc);
digitalWrite(l4,HIGH);
delay(t);
digitalWrite(b,LOW);
digitalWrite(l1,LOW);
digitalWrite(l2,LOW);
digitalWrite(l3,LOW);
digitalWrite(l4,LOW);
delay(t2);
if(digitalRead(r) == LOW)
vc = 0;
Serial.println("Votecount has been reset");
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
