Arduino isn't work at all in windows 10 anymore.
I install various versions and even change installation folder to my documents path and installed and install uninstalled arduino ide several times, then I installed arduino driver and many other work such change its permission to full administrator… but It only give following error… I spend a lot of money and time on arduino and now I have nothing… but on-line version work but I m not sure online version is proper for complicated and professional programs. My OS is windows 10 and my laptop is asus x541uv. It works in last few days but suddenly it give following error…
Arduino: 1.8.4 (Windows 10), Board: “Arduino/Genuino Uno”
avr-g++: error: cannot access device-specs for ‘atmega328p’ expected at ‘device-specs/specs-atmega328p’
avr-g++: note: devices natively supported: ata5272 ata5505 ata5702m322 ata5782 ata5790 ata5790n ata5791 ata5795 ata5831 ata6285 ata6286 ata6289 ata6612c ata6613c ata6614q ata6616c ata6617c ata664251 ata8210 ata8510 atmega103 atmega128 atmega128a atmega128rfa1 atmega128rfr2 atmega1280 atmega1281 atmega1284 atmega1284p atmega1284rfr2 atmega16 atmega16a atmega16hva atmega16hva2 atmega16hvb atmega16hvbrevb atmega16m1 atmega16u2 atmega16u4 atmega161 atmega162 atmega163 atmega164a atmega164p atmega164pa atmega165 atmega165a atmega165p atmega165pa atmega168 atmega168a atmega168p atmega168pa atmega168pb atmega169 atmega169a atmega169p atmega169pa atmega256rfr2 atmega2560 atmega2561 atmega2564rfr2 atmega32 atmega32a atmega32c1 atmega32hvb atmega32hvbrevb atmega32m1 atmega32u2 atmega32u4 atmega32u6 atmega323 atmega324a atmega324p atmega324pa atmega325 atmega325a atmega325p atmega325pa atmega3250 atmega3250a atmega3250p atmega3250pa atmega328 atmega328p atmega328pb atmega329 atmega329a atmega329p atmega329pa atmega3290 atmega3290a atmega3290p atmega3290pa atmega406 atmega48 atmega48a atmega48p atmega48pa atmega48pb atmega64 atmega64a atmega64c1 atmega64hve atmega64hve2 atmega64m1 atmega64rfr2 atmega640 atmega644 atmega644a atmega644p atmega644pa atmega644rfr2 atmega645 atmega645a atmega645p atmega6450 atmega6450a atmega6450p atmega649 atmega649a atmega649p atmega6490 atmega6490a atmega6490p atmega8 atmega8a atmega8hva atmega8u2 atmega8515 atmega8535 atmega88 atmega88a atmega88p atmega88pa atmega88pb attiny10 attiny11 attiny12 attiny13 attiny13a attiny15 attiny1634 attiny167 attiny20 attiny22 attiny2313 attiny2313a attiny24 attiny24a attiny25 attiny26 attiny261 attiny261a attiny28 attiny4 attiny40 attiny43u attiny4313 attiny44 attiny44a attiny441 attiny45 attiny461 attiny461a attiny48 attiny5 attiny828 attiny84 attiny84a attiny841 attiny85 attiny861 attiny861a attiny87 attiny88 attiny9 atxmega128a1 atxmega128a1u atxmega128a3 atxmega128a3u atxmega128a4u atxmega128b1 atxmega128b3 atxmega128c3 atxmega128d3 atxmega128d4 atxmega16a4 atxmega16a4u atxmega16c4 atxmega16d4 atxmega16e5 atxmega192a3 atxmega192a3u atxmega192c3 atxmega192d3 atxmega256a3 atxmega256a3b atxmega256a3bu atxmega256a3u atxmega256c3 atxmega256d3 atxmega32a4 atxmega32a4u atxmega32c3 atxmega32c4 atxmega32d3 atxmega32d4 atxmega32e5 atxmega384c3 atxmega384d3 atxmega64a1 atxmega64a1u atxmega64a3 atxmega64a3u atxmega64a4u atxmega64b1 atxmega64b3 atxmega64c3 atxmega64d3 atxmega64d4 atxmega8e5 at43usb320 at43usb355 at76c711 at86rf401 at90can128 at90can32 at90can64 at90c8534 at90pwm1 at90pwm161 at90pwm2 at90pwm2b at90pwm216 at90pwm3 at90pwm3b at90pwm316 at90pwm81 at90scr100 at90s1200 at90s2313 at90s2323 at90s2333 at90s2343 at90s4414 at90s4433 at90s4434 at90s8515 at90s8535 at90usb1286 at90usb1287 at90usb162 at90usb646 at90usb647 at90usb82 at94k m3000
avr-g++: note: supported core architectures: avr2 avr25 avr3 avr31 avr35 avr4 avr5 avr51 avr6 avrxmega2 avrxmega4 avrxmega5 avrxmega6 avrxmega7 avrtiny avr1
avr-g++: note: you can provide your own specs files, see http://gcc.gnu.org/onlinedocs/gcc/Spec-Files.html for details
exit status 1
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
option enabled in File → Preferences.
Please do this:
  • File > Preferences > Show verbose output during: > compilation (check) > OK
  • Sketch > Verify/Compile
  • After the compilation fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
My 1.8.2 is still working on Windows 10. Just FYI.
