Arduino ISP and ATtiny 45-20
Hello all, I like to program a ATtiny 45-20 chip via Arduino ISP and Arduino IDE. The hardware setup is :
Arduino ATTiny 45 + 5V 8 GND 4 pin 10 1 pin 11 5 pin 12 6 pin 13 7
I placed the new ATTiny cores in the Arduino 022/hardware folder I used the ATtiny45 via Arduino ISP option and compiling is OK
But sending to MCU stops , sending message unknown MCU You can ignore by using -F option.
Anyone knows how to solve this ?
Thanks in advange
André Koopman
Compiling is not a problem
Ok I was a little bit to fast! There is some info on how to program the ATtiny25 on the web and this forum. I managed to load the blink sketch into the ATtiny25 with ArduinoISP !!!
I added to board.txt the following lines:
attiny25.name=ATtiny25
attiny25.upload.using=arduino:arduinoisp
attiny25.upload.maximum_size=2048
attiny25.build.mcu=attiny25
attiny25.build.f_cpu=8000000L
attiny25.build.core=attiny45_85
But one thing is still a question, is attiny25.build.f_cpu=8000000L the right way to tell the compiler to run the ATtiny25 on 8 Mc on his internal oscilator? Or have I add lines for low and high_fuses?
attiny25.bootloader.low_fuses=0xE2
attiny25.bootloader.high_fuses=0xFF
attiny25.bootloader.extended fuses=0xFF
pse any advice!
andré
f_cpu tells the compiler to compile the code for a specific processor speed (so that timings in the code are correct), but does not tell the micro itself to run at a specific speed. The fuse bits are what tells the micro what speed to run at.
Jraskell, thanks for the information. I will look at the datasheet to learn how to use the fusebits!
No need to monkey with the fuses. Just switch to a different core and execute Tools / Burn Bootloader...
http://arduino.cc/forum/index.php/topic,8878.0.html http://arduino.cc/forum/index.php?topic=51984.0 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1289363279
