Arduino ISP R3 not working
Hi all,
I would like to program an ATtiny45 or 85. So I got me one of these:
ArduinoISP R3
So I read the info and followed the instructions on these pages:
There is also a getting started guide: https://www.arduino.cc/en/Guide/ArduinoISP
But it says “Retired”
Basicaly I think it’s a driver installation problem ?
I am using: ArduinoISP_WindowsDrivers.zip
(https://www.arduino.cc/en/uploads/Guide/ArduinoISP_WindowsDrivers.zip)
Before driver installation:
After driver installation I see this in device manager:
However, in the IDE port selection is greyed out :
Is it supposed to be when using ArduinoISP or should it be connected to a (virtual ?) com port ?
I have tried:
  • different USB cables, different ports
  • installing, rebooting
  • restarting IDE
  • connecting and disconnecting ArduinoISP
  • tried with and without an attiny connected
  • tried another attiny chip
Uploading a sketch “using programmer” give me an avrdude error:
avrdude: Error: Could not find USBtiny device (0x2341/0x49)
I’m running Arduino IDE 1.6.8
windows 7 32bits
connecting my genuine Arduino micro/uno/mega is not a problem
I’m kinda stuck on this.
Thanks for any help !
(deleted)
spycatcher2k: Choose arduinoISP from tools - programmer.
Tried that too, error message is:
I tried "burn bootloader":
avrdude: Error: Could not find USBtiny device (0x2341/0x49) Error while burning bootloader.
Should I even be using burn bootloader ?
EDIT: Seems I do
Each AVR microcontroller (inluding our ATMEGA328P) has a small chunk of permanent memory called 'Fuses' that control how the chip will behave. These Fuses need to be set in a specific configuration to make the chip Arduino compatible. When you buy a brand new ATMEGA chip from your favorite electronics store, they may not be set correctly. When you 'Burn the Bootloader' to a chip, part of the process includes setting the Fuses. It is a dead simple way to configure a new chip.
Also when trying to upload the blink example: avrdude: Error: Could not find USBtiny device (0x2341/0x49)
I found this post :
if you download the driver (ArduinoISP_WindowsDrivers) on Arduino.cc the file arduinoISP.inf content : DeviceID = "VID_2341&PID_0049"
even hardware can comes with the hardware "VID_2A03&PID_0049"
so change 2341 by 2A03 on this file and start again and it's magic !!!!!
Bad English but it seems like you should replace the VID_ in the arduinoisp.inf file ? I tried both and reinstalled selecting the inf as driver, no luck
thnx for any suggestions
Anyone ?
Pretty please :)
(deleted)
