Hi , i got an issue using the arduino with the ethernet shield and sonar sensor , when i use the ethernet shield alone to turn on - off leds using the netio app it works great with no problems but when i add a function to detect motion with the sonar and turn the led , the networking part stops working , i just got destination unreachable , tested shield and sonar using the same enviroment (router , ports)
Im using this code
#include <SPI.h>
#include <Ethernet.h>
#define DEBUG 0
#define trigPin 12
#define echoPin 13
//int Buzzer = 9;
byte mac[] = { 0xDA, 0xA2, 0xDA, 0x00, 0x4A, 0x10 };
IPAddress ip(192,168,100,20);
IPAddress gateway(192,168,100,1);
#define BUFSIZ 64
EthernetServer teserver(1479);
void setup(){
Ethernet.begin(mac, ip, gateway);
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
pinMode(3, OUTPUT);
digitalWrite(3, LOW);
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
pinMode(8, OUTPUT);
digitalWrite(8, LOW);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
//pinMode(Buzzer, OUTPUT);
teserver.begin();
luces();
sensor();
void luces()
int index = 0;
char Remote[BUFSIZ];
EthernetClient client = teserver.available();
if (client) {
if (client.connected()) {
while (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
Remote[index] = c;
index++;
if (index >= BUFSIZ)
index = BUFSIZ -1;
continue;
Remote[index] = 0;
//if(DEBUG){
// Serial.println(" ");
// Serial.print("string recieved from phone: ");
// Serial.println(Remote);
if (strstr(Remote, "ctmaster_on")) {
client.println("OK");
digitalWrite(2, HIGH );
//if(DEBUG)Serial.println("> turned led2 on!");
if (strstr(Remote, "ctmaster_off")) {
digitalWrite(2, LOW );
//if(DEBUG)Serial.println("> turned led2 off!");
if (strstr(Remote, "ctinvitado_on")) {
digitalWrite(3, HIGH );
//if(DEBUG)Serial.println("> turned led3 on!");
if (strstr(Remote, "ctinvitado_off")) {
digitalWrite(3, LOW );
//if(DEBUG)Serial.println("> turned led3 off!");
if (strstr(Remote, "sala_on")) {
digitalWrite(4, HIGH );
//if(DEBUG)Serial.println("> turned led4 on!");
if (strstr(Remote, "sala_off")) {
digitalWrite(4, LOW );
//if(DEBUG)Serial.println("> turned led4 off!");
if (strstr(Remote, "comedor_on")) {
digitalWrite(5, HIGH );
//if(DEBUG)Serial.println("> turned led5 on!");
if (strstr(Remote, "comedor_off")) {
digitalWrite(5, LOW );
//if(DEBUG)Serial.println("> turned led5 off!");
if (strstr(Remote, "luzfrontal_on")) {
digitalWrite(6, HIGH );
//if(DEBUG)Serial.println("> turned led6 on!");
if (strstr(Remote, "luzfrontal_off")) {
digitalWrite(6, LOW );
//if(DEBUG)Serial.println("> turned led6 off!");
if (strstr(Remote, "luzpatio_on")) {
digitalWrite(7, HIGH );
//if(DEBUG)Serial.println("> turned led7 on!");
if (strstr(Remote, "luzpatio_off")) {
digitalWrite(7, LOW );
//if(DEBUG)Serial.println("> turned led7 off!");
if (strstr(Remote, "all_off")) {
//if(DEBUG)Serial.println("> apagar todas las luces!");
if (strstr(Remote, "night_on")) {
//if(DEBUG)Serial.println("> luces de noche!");
void sensor()
int duration, cm;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
cm = duration / 29 / 2;
if (cm < 20)
digitalWrite(8, HIGH );
//tone(Buzzer, 400);
digitalWrite(8,LOW);
//noTone(Buzzer);
//Serial.print(cm);
//Serial.print("cm");
//Serial.println();
//delay(1000);
thanks in advance for any help on this , im doing a project for college grad and im stuck on this part
Fernando
