arduino joystick and ir receiver
hi,
i'm using my arduino uno as a joystick and it's working fine
but now i want to know if it's possible to add an ir receiver and remote controller to the same card just to use the button for gaming???
thank you
It's not clear to me what you have and what you want to add how. Have you a schematic drawing of your intended system with all external connections?
i use this sketch to use my arduino as a joystick :
/* Arduino USB Joystick HID demo */
/* Author: Darran Hunt
  Released into the public domain.
  Update by RICLAMER in 25/03/2014 to use Analog ports and digital ports
  This code is to be used with Arduino UNO (6 axis and 13 Button )
  This code is compatible with Arduino Mega.
/* INSTALATION
 Just install POT in each analog port. Using the _Grnd _Analog _5V Arduino.
 Like this image: http://arduino.cc/en/uploads/Tutorial/joy_sch_480.jpg
 To setup the buttons, just install you prefered button switch under GND and Port Digital 02~13.
 Use Flip to erease and burn this firmware DFU: https://github.com/harlequin-tech/arduino-usb/blob/master/firmwares/Arduino-big-joystick.hex
 I used Arduino R3 with Atmega 16U2.
#undef DEBUG
#define NUM_BUTTONS  40             // you don't need to change this value
#define NUM_AXES  8        // 6 axes to UNO, and 8 to MEGA. If you are using UNO, don't need to change this value.
typedef struct joyReport_t {
 int16_t axis[NUM_AXES];
 uint8_t button[(NUM_BUTTONS + 7) / 8]; // 8 buttons per byte
} joyReport_t;
joyReport_t joyReport;
uint8_t btn[12];
int fulloff = 0;
void setup(void);
void loop(void);
void setButton(joyReport_t *joy, uint8_t button);
void clearButton(joyReport_t *joy, uint8_t button);
void sendJoyReport(joyReport_t *report);
 //set pin to input Button
 for ( int portId = 02; portId < 13; portId ++ )
   pinMode( portId, INPUT_PULLUP);
 delay(200);
 for (uint8_t ind = 0; ind < 8; ind++) {
   joyReport.axis[ind] = ind * 1000;
 for (uint8_t ind = 0; ind < sizeof(joyReport.button); ind++) {
   joyReport.button[ind] = 0;
// Send an HID report to the USB interface
void sendJoyReport(struct joyReport_t *report)
#ifndef DEBUG
 Serial.write((uint8_t *)report, sizeof(joyReport_t));
#else
 // dump human readable output for debugging
 for (uint8_t ind = 0; ind < NUM_AXES; ind++) {
   Serial.print("axis[");
   Serial.print(ind);
   Serial.print("]= ");
   Serial.print(report->axis[ind]);
   Serial.print(" ");
 for (uint8_t ind = 0; ind < NUM_BUTTONS / 8; ind++) {
   Serial.print("button[");
   Serial.print(ind);
   Serial.print(report->button[ind], HEX);
   Serial.print(" ");
#endif
// turn a button on
 uint8_t index = button / 8;
 uint8_t bit = button - 8 * index;
 joy->button[index] |= 1 << bit;
// turn a button off
 joy->button[index] &= ~(1 << bit);
  Read Digital port for Button
  Read Analog port for axis
 // Create Matriz with value off switch button
 for (int bt = 1; bt < 13; bt ++)
   btn[bt] = digitalRead(bt + 1);
 // Power ON button if it is press. buton 17 at 28
 for (int on = 01; on < 13; on++)
   if (btn[on] == LOW)
     setButton(&joyReport, on + 16);
     //  Serial.println("botao ON");
     //  Serial.println(on+16);
     delay(1);
     if (btn[on] == HIGH)
       clearButton(&joyReport, on + 16);
     //  Serial.println("Every buttons is off");
 /* Move all of the Analogic axis */
 /* Arduino UNO have only 6 port. Will be necessary set to 0; the not used port */
 /* In this example, i will use just 3 axis. X, Y, Z */
 /* if you will use all 6 analog ports, set axis < 3, to axis < 5 */
 for (uint8_t axis = 0; axis < 2; axis++) // 1 - A0 == Wheel == X axis
   joyReport.axis[axis] = map(analogRead(axis), 0, 1023, -32768, 32767 );
 for (uint8_t axis = 1; axis < 3; axis++) // 2 - A3 = Gas Pedal
 for (uint8_t axis = 2; axis < 4; axis++)  // 3 - A2 == Brake Pedal
 for (uint8_t axis = 3; axis < 5; axis++) // 1 - A0 == Wheel == X axis
 for (uint8_t axis = 4; axis < 6; axis++) // 1 - A0 == Wheel == X axis
 for (uint8_t axis = 5; axis < 7; axis++) // 1 - A0 == Wheel == X axis
 //Set to 0; the not used analog port.
 //if you will use all 6 analog ports, exclude the lines, axis[3] at axis [5] */
 //Report.axis[3] = 0;
// You need to ground A1 pin, because its the Y axis and if you dont use it, need to ground.
 //joyReport.axis[4] = A0;
 //joyReport.axis[5] = A3;
 //joyReport.axis[6] = A2;
 joyReport.axis[7] = 0;
 joyReport.axis[8] = 0;
 //Send Data to HID
 sendJoyReport(&joyReport);
 delay(35);
 fulloff = 0;
the idea is ti edit this sketch so i can use the button of ir remote as joystick button
thank you for your help
It does not help to show what you have, more interesting is what you do not yet have. You even missed to tell your Arduino model.
hi,
when i use the sketch above and i press all button in the ir remote , it show that i'm using the same button on the joystick interface , so i want to use each button of the ir remote as an individual joystick button .
so can someone edit the sketch above for me??(i dont know how to integrate ir mapping to it or if it's possible)
thank you
You can use the IRRemote library for reading IR signals.
i did but now i want to know how to assign each button on the ir remote to a joystick button
You can use a case statement to assign a button number to each IR code. Or a number of if statements...
