Arduino JSON and struct datatypes
Hi all,
I’m playing arround with the ArduinoJson.h and getting into troubles with struct datatypes. I wrote a little program:
#include <ArduinoJson.h>
struct data
	int counter;
	int number;
	char text;
typedef data dataset;
void JSON()
	StaticJsonBuffer<200> jsonBuffer;
	JsonObject& root = jsonBuffer.createObject();
	root["number"] = dataset.number;
	dataset.number = 10;
	JSON()
I would like to pass a variable of the type data named dataset to the JSON function, but it shows me this error message:
JSON.ino: In function void JSON()
JSON.ino: 34:26: error: expected primary-expression before '.' token
Error compiling project sources
Build failed for project 'JSON'
JSON.ino: In function void setup()
JSON.ino: 40:9: error: expected unqualified-id before '.' token
   dataset.number = 10
JSON.ino: In function void loop()
JSON.ino: 51:1: error: expected ';' before '}' token
Can anybody give me a hint to fix it?
Thank you very much!
BR
Chris
Fire up a text editor, and fix the problem(s).
Without seeing your code, you can't expect us to help you.
ard24:
struct data
int counter;
int number;
char text;
You have created a type called dataset, but not an instance of that type - a concrete variable or object.
Just remove the typedef keyword, and don’t forget the semicolon after JSON().
But not a valid type.
The type that OP seems to trying to alias is struct data, not data.
Hi all,
thank you very much for your help. I understand now. My mistake was, I created just a new name for the datatype “data” but not an instance due to using typedef.
But now I would like to create an array of the type data called dataset[10] for example.
struct data
	int counter;
	int number;
	char text;
data dataset[10];
void JSON()
	root["number"] = dataset.number[0];
	JSON();
But this now generates a error message non-class type:
Compiling 'test' for 'ATmega1284'
test.ino: In function void JSON()
test.ino: 19:27: error: request for member 'number' in 'dataset', which is of non-class type 'data [10]
Build failed for project 'test'
test.ino: In function void setup()
test.ino: 24:10: error: request for member 'number' in 'dataset', which is of non-class type 'data [10]
   dataset.number = 10
Is there a trick to solve this?
Chris
Your type is NOT data. It is struct data.
struct data dataset[10];
Hi PaulS,
thank you very much for your fast reply. It's a bit complicated for me, but I guess i've got it so far.
There is a difference between a datatype and a struct. I mixed it. But also by writing:
the compiler gives me the same error message like above?
Is that a question or a statement?
The array of objects does not have a member named number. ONE element of the array would.
